REST API reference
Update a CIFS share
Updates a CIFS share to modify its configuration or properties within your storage environment. This helps you manage access and settings for your CIFS shares effectively.
HTTP method and endpoint
PATCH /protocols/cifs/shares/{svm.uuid}/{name}
Introduced in
ONTAP 9.6
  • vserver cifs share modify
  • vserver cifs share properties add
  • vserver cifs share properties remove
name
string
path
True
Share Name
svm.uuid
string
path
True
Request Body
Name Type Description
_links
_links
access_based_enumeration
boolean
If enabled, all folders inside this share are visible to a user based on that individual user access right; prevents the display of folders or other shared resources that the user does not have access to.
allow_unencrypted_access
boolean
Specifies whether or not the SMB2 clients are allowed to access the encrypted share.
change_notify
boolean
Specifies whether CIFS clients can request for change notifications for directories on this share.
comment
string
Specify the CIFS share descriptions.
continuously_available
boolean
Specifies whether or not the clients connecting to this share can open files in a persistent manner. Files opened in this way are protected from disruptive events, such as, failover and giveback.
dir_umask
integer
Directory Mode Creation Mask to be viewed as an octal number.
encryption
boolean
Specifies that SMB encryption must be used when accessing this share. Clients that do not support encryption are not able to access this share.
file_umask
integer
File Mode Creation Mask to be viewed as an octal number.
force_group_for_create
string
Specifies that all files that CIFS users create in a specific share belong to the same group (also called the "force-group"). The "force-group" must be a predefined group in the UNIX group database. This setting has no effect unless the security style of the volume is UNIX or mixed security style.
namespace_caching
boolean
Specifies whether or not the SMB clients connecting to this share can cache the directory enumeration results returned by the CIFS servers.
no_strict_security
boolean
Specifies whether or not CIFS clients can follow a unix symlinks outside the share boundaries.
offline_files
string
Offline Files The supported values are:
  • none - Clients are not permitted to cache files for offline access.
  • manual - Clients may cache files that are explicitly selected by the user for offline access.
  • documents - Clients may automatically cache files that are used by the user for offline access.
  • programs - Clients may automatically cache files that are used by the user for offline access and may use those files in an offline mode even if the share is available.
oplocks
boolean
Specify whether opportunistic locks are enabled on this share. "Oplocks" allow clients to lock files and cache content locally, which can increase performance for file operations.
path
string
The fully-qualified pathname in the owning SVM namespace that is shared through this share. If this is a home directory share then the path should be dynamic by specifying the pattern %w (Windows user name), %u (UNIX user name), or %d (domain name) variables in any combination. ONTAP generates the path dynamically for the connected user and this path is appended to each search path to find the full Home Directory path.
  • example: /volume_1/eng_vol/
  • maxLength: 256
  • minLength: 1
  • Introduced in: 9.6
show_snapshot
boolean
Specifies whether or not the Snapshot copies can be viewed and traversed by clients.
svm
svm
unix_symlink
string
Controls the access of UNIX symbolic links to CIFS clients. The supported values are:
  • local - Enables only local symbolic links which is within the same CIFS share.
  • widelink - Enables both local symlinks and widelinks.
  • disable - Disables local symlinks and widelinks.
volume
volume
vscan_profile
string
Vscan File-Operations Profile The supported values are:
  • no_scan - Virus scans are never triggered for accesses to this share.
  • standard - Virus scans can be triggered by open, close, and rename operations.
  • strict - Virus scans can be triggered by open, read, close, and rename operations.
  • writes_only - Virus scans can be triggered only when a file that has been modified is closed.
Example request
  "comment": "HR Department Share",
  "dir_umask": 22,
  "file_umask": 22,
  "force_group_for_create": "string",
  "home_directory": null,
  "offline_files": "string",
  "path": "/volume_1/eng_vol/",
  "svm": {
    "name": "svm1",
  "unix_symlink": "string",
  "volume": {
    "name": "volume1",
  "vscan_profile": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655628
'SMB_ENCRYPTION' property cannot be set on CIFS share because the CIFS server does not support SMB3.0
655551
CIFS Share modification failed because the specified path does not exist
655620
Cannot set symlink properties for admin shares
656420
Cannot modify the standard share ipc$
656421
Cannot modify the standard share admin$
656422
Failed to modify the home directory share because the directory shares must specify a path relative to one or more home directory search paths
656423
Failed to modify CIFS share. The Shares must define an absolute share path
656425
Failed to modify the CIFS share because the path for an administrative share cannot be modified
655395
Failed to modify the CIFS share because share cannot be made continuously available unless running SMB3 or later.
4849678
Failed to modify the CIFS share because the specified UNIX group does not exist
string
acls
The permissions that users and groups have on a CIFS share.
_links
_links
permission
string
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
  • no_access - User does not have CIFS share access
  • read - User has only read access
  • change - User has change access
  • full_control - User has full_control access
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
cifs_share
CIFS share is a named access point in a volume. Before users and applications can access data on the CIFS server over SMB, a CIFS share must be created with sufficient share permission. CIFS shares are tied to the CIFS server on the SVM. When a CIFS share is created, ONTAP creates a default ACL for the share with Full Control permissions for Everyone.
_links
_links
boolean
boolean
change_notify
boolean
comment
string
boolean
dir_umask
integer
encryption
boolean
file_umask
integer
string
namespace_caching
boolean
no_strict_security
boolean
offline_files
string
oplocks
boolean
path
string
  • maxLength: 256
  • minLength: 1
show_snapshot
boolean
svm
svm
unix_symlink
string
volume
volume
vscan_profile
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
