Update a CIFS share
Updates a CIFS share to modify its properties or configuration, aligning it with your specific requirements. This function is typically used to adjust settings for accessibility or security purposes.
HTTP method and endpoint
PATCH /protocols/cifs/shares/{svm.uuid}/{name}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver cifs share modify -
vserver cifs share properties add -
vserver cifs share properties remove
Learn more
name |
string |
path |
True |
Share Name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
_links |
access_based_enumeration |
boolean |
If enabled, all folders inside this share are visible to a user based on that individual user access right; prevents the display of folders or other shared resources that the user does not have access to. |
allow_unencrypted_access |
boolean |
Specifies whether or not the SMB2 clients are allowed to access the encrypted share. |
change_notify |
boolean |
Specifies whether CIFS clients can request for change notifications for directories on this share. |
comment |
string |
Specify the CIFS share descriptions. |
continuously_available |
boolean |
Specifies whether or not the clients connecting to this share can open files in a persistent manner. Files opened in this way are protected from disruptive events, such as, failover and giveback. |
dir_umask |
integer |
Directory Mode Creation Mask to be viewed as an octal number. |
encryption |
boolean |
Specifies that SMB encryption must be used when accessing this share. Clients that do not support encryption are not able to access this share. |
file_umask |
integer |
File Mode Creation Mask to be viewed as an octal number. |
force_group_for_create |
string |
Specifies that all files that CIFS users create in a specific share belong to the same group (also called the "force-group"). The "force-group" must be a predefined group in the UNIX group database. This setting has no effect unless the security style of the volume is UNIX or mixed security style. |
namespace_caching |
boolean |
Specifies whether or not the SMB clients connecting to this share can cache the directory enumeration results returned by the CIFS servers. |
no_strict_security |
boolean |
Specifies whether or not CIFS clients can follow a unix symlinks outside the share boundaries. |
offline_files |
string |
Offline Files The supported values are:
oplocks |
boolean |
Specify whether opportunistic locks are enabled on this share. "Oplocks" allow clients to lock files and cache content locally, which can increase performance for file operations. |
path |
string |
The fully-qualified pathname in the owning SVM namespace that is shared through this share. If this is a home directory share then the path should be dynamic by specifying the pattern %w (Windows user name), %u (UNIX user name), or %d (domain name) variables in any combination. ONTAP generates the path dynamically for the connected user and this path is appended to each search path to find the full Home Directory path.
show_snapshot |
boolean |
Specifies whether or not the Snapshot copies can be viewed and traversed by clients. |
svm |
unix_symlink |
string |
Controls the access of UNIX symbolic links to CIFS clients. The supported values are:
volume |
vscan_profile |
string |
Vscan File-Operations Profile The supported values are:
Example request
"comment": "HR Department Share",
"dir_umask": 22,
"file_umask": 22,
"force_group_for_create": "string",
"home_directory": true,
"offline_files": "string",
"path": "/volume_1/eng_vol/",
"svm": {
"name": "svm1",
"unix_symlink": "string",
"volume": {
"name": "volume1",
"vscan_profile": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655628 |
'SMB_ENCRYPTION' property cannot be set on CIFS share because the CIFS server does not support SMB3.0 |
655551 |
CIFS Share modification failed because the specified path does not exist |
655620 |
Cannot set symlink properties for admin shares |
656420 |
Cannot modify the standard share ipc$ |
656421 |
Cannot modify the standard share admin$ |
656422 |
Failed to modify the home directory share because the directory shares must specify a path relative to one or more home directory search paths |
656423 |
Failed to modify CIFS share. The Shares must define an absolute share path |
656425 |
Failed to modify the CIFS share because the path for an administrative share cannot be modified |
655395 |
Failed to modify the CIFS share because share cannot be made continuously available unless running SMB3 or later. |
4849678 |
Failed to modify the CIFS share because the specified UNIX group does not exist |
href |
string |
_links
acls
The permissions that users and groups have on a CIFS share.
_links |
permission |
string |
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
CIFS share is a named access point in a volume. Before users and applications can access data on the CIFS server over SMB, a CIFS share must be created with sufficient share permission. CIFS shares are tied to the CIFS server on the SVM. When a CIFS share is created, ONTAP creates a default ACL for the share with Full Control permissions for Everyone.
_links |
boolean |
boolean |
change_notify |
boolean |
comment |
string |
boolean |
dir_umask |
integer |
encryption |
boolean |
file_umask |
integer |
string |
namespace_caching |
boolean |
boolean |
offline_files |
string |
oplocks |
boolean |
path |
string |
show_snapshot |
boolean |
svm |
unix_symlink |
string |
volume |
vscan_profile |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
