REST API reference
Update an FPolicy configuration for an SVM
Updates an FPolicy configuration for a specified SVM to modify policy settings. Use this to enable or disable a policy, adjusting the policy priority as needed.
HTTP method and endpoint
PATCH /protocols/fpolicy/{svm.uuid}/policies/{name}
Introduced in
ONTAP 9.6
Usage notes
Updates a particular FPolicy policy configuration for a specified SVM. PATCH can be used to enable or disable the policy. When enabling a policy, you must specify the policy priority. The policy priority of the policy is not required when disabling the policy. If the policy is enabled, the FPolicy policy engine cannot be modified.
  • fpolicy policy modify
  • fpolicy policy scope modify
  • fpolicy enable
  • fpolicy disable
name
string
path
True
svm.uuid
string
path
True
Request Body
Name Type Description
enabled
boolean
Specifies if the policy is enabled on the SVM or not. If no value is mentioned for this field but priority is set, then this policy will be enabled.
engine
fpolicy_engine_reference
FPolicy external engine
events
array[fpolicy_event_reference]
mandatory
boolean
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances.
passthrough_read
boolean
Specifies whether passthrough-read should be allowed for FPolicy servers registered for the policy. Passthrough-read is a way to read data for offline files without restoring the files to primary storage. Offline files are files that have been moved to secondary storage.
priority
integer
Specifies the priority that is assigned to this policy.
privileged_user
string
Specifies the privileged user name for accessing files on the cluster using a separate data channel with privileged access. The input for this field should be in "domain\username" format.
scope
scope
svm
svm
Example request
  "engine": {
    "name": "string"
  "events": [
    "event_nfs_close",
    "event_open"
  "privileged_user": "mydomain\\testuser",
  "scope": {
    "exclude_export_policies": [
      "string"
    "exclude_extension": [
      "string"
    "exclude_shares": [
      "string"
    "exclude_volumes": [
      "vol1",
      "vol_svm1",
    "include_export_policies": [
      "string"
    "include_extension": [
      "string"
    "include_shares": [
      "sh1",
      "share_cifs"
    "include_volumes": [
      "vol1",
      "vol_svm1"
  "svm": {
    "uuid": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
9765026
The priority must be specified when enabling the FPolicy policy
9765025
Cannot disable an FPolicy policy when the priority is specified
9764899
Cannot modify an FPolicy engine when the policy is enabled
9764899
Deletion of a cluster policy is not supported
9764908
An FPolicy policy is already enabled
9764907
An FPolicy policy is already disabled
9765029
An FPolicy was modified but disable/enable failed as the policy is already disabled/enabled
9765036
Cannot modify an FPolicy policy as passthrough-read policies are not supported without privileged user
9765038
Passthrough-read policies are not supported with an external engine of type "asynchronous"
9765039
Passthrough-read policies are not supported with native engine
9765040
Cannot modify an FPolicy policy as passthrough-read could not be enabled/disabled when the policy is enabled
string
name
string
The name of the FPolicy external engine.
FPolicy events
name
string
scope
check_extensions_on_directories
boolean
Specifies whether the file name extension checks also apply to directory objects. If this parameter is set to true, the directory objects are subjected to the same extension checks as regular files. If this parameter is set to false, the directory names are not matched for extensions and notifications are sent for directories even if their name extensions do not match. Default is false.
array[string]
exclude_extension
array[string]
exclude_shares
array[string]
exclude_volumes
array[string]
array[string]
include_extension
array[string]
include_shares
array[string]
include_volumes
array[string]
object_monitoring_with_no_extension
boolean
Specifies whether the extension checks also apply to objects with no extension. If this parameter is set to true, all objects with or without extensions are monitored. Default is false.
svm
uuid
string
SVM UUID
fpolicy_policy
enabled
boolean
engine
events
mandatory
boolean
passthrough_read
boolean
priority
integer
privileged_user
string
scope
scope
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
