Update an FPolicy configuration for an SVM
Updates an FPolicy policy configuration for a specified SVM to enable or disable the policy as needed.
HTTP method and endpoint
PATCH /protocols/fpolicy/{svm.uuid}/policies/{name}
Introduced in
ONTAP 9.6
Usage notes
Updates a particular FPolicy policy configuration for a specified SVM. PATCH can be used to enable or disable the policy. When enabling a policy, you must specify the policy priority. The policy priority of the policy is not required when disabling the policy. If the policy is enabled, the FPolicy policy engine cannot be modified.
Related ONTAP commands
fpolicy policy modify -
fpolicy policy scope modify -
fpolicy enable -
fpolicy disable
Learn more
name |
string |
path |
True |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
allow_privileged_access |
boolean |
Specifies whether privileged access is required for FPolicy servers. Privileged access is used when the FPolicy server requires direct access to the cluster nodes. When this parameter is set to true, FPolicy servers can access files on the cluster using a separate data channel with privileged access. |
enabled |
boolean |
Specifies if the policy is enabled on the SVM or not. If no value is mentioned for this field but priority is set, then this policy will be enabled. |
engine |
FPolicy external engine |
events |
array[fpolicy_event_reference] |
mandatory |
boolean |
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances. |
passthrough_read |
boolean |
Specifies whether passthrough-read should be allowed for FPolicy servers registered for the policy. Passthrough-read is a way to read data for offline files without restoring the files to primary storage. Offline files are files that have been moved to secondary storage. |
priority |
integer |
Specifies the priority that is assigned to this policy. |
privileged_user |
string |
Specifies the privileged user name for accessing files on the cluster using a separate data channel with privileged access. The input for this field should be in "domain\username" format. |
scope |
svm |
Example request
"engine": {
"name": "string"
"events": [
"event_nfs_close",
"event_open"
"privileged_user": "mydomain\\testuser",
"scope": {
"exclude_export_policies": [
"string"
"exclude_extension": [
"string"
"exclude_shares": [
"string"
"exclude_volumes": [
"vol1",
"vol_svm1",
"include_export_policies": [
"string"
"include_extension": [
"string"
"include_shares": [
"sh1",
"share_cifs"
"include_volumes": [
"vol1",
"vol_svm1"
"svm": {
"uuid": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9765026 |
The priority must be specified when enabling the FPolicy policy |
9765025 |
Cannot disable an FPolicy policy when the priority is specified |
9764899 |
Cannot modify an FPolicy engine when the policy is enabled |
9764899 |
Deletion of a cluster policy is not supported |
9764908 |
An FPolicy policy is already enabled |
9764907 |
An FPolicy policy is already disabled |
9765029 |
An FPolicy was modified but disable/enable failed as the policy is already disabled/enabled |
9765036 |
Cannot modify an FPolicy policy as passthrough-read policies are not supported without privileged user |
9765038 |
Passthrough-read policies are not supported with an external engine of type "asynchronous" |
9765039 |
Passthrough-read policies are not supported with native engine |
9765040 |
Cannot modify an FPolicy policy as passthrough-read could not be enabled/disabled when the policy is enabled |
href |
string |
_links
fpolicy_engine_reference
name |
string |
The name of the FPolicy external engine. |
FPolicy events
name |
string |
scope
check_extensions_on_directories |
boolean |
Specifies whether the file name extension checks also apply to directory objects. If this parameter is set to true, the directory objects are subjected to the same extension checks as regular files. If this parameter is set to false, the directory names are not matched for extensions and notifications are sent for directories even if their name extensions do not match. Default is false. |
exclude_export_policies |
array[string] |
exclude_extension |
array[string] |
exclude_shares |
array[string] |
exclude_volumes |
array[string] |
include_export_policies |
array[string] |
include_extension |
array[string] |
include_shares |
array[string] |
include_volumes |
array[string] |
object_monitoring_with_no_extension |
boolean |
Specifies whether the extension checks also apply to objects with no extension. If this parameter is set to true, all objects with or without extensions are monitored. Default is false. |
svm
uuid |
string |
SVM UUID |
fpolicy_policy
boolean |
enabled |
boolean |
engine |
events |
mandatory |
boolean |
passthrough_read |
boolean |
priority |
integer |
privileged_user |
string |
scope |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
