Update an NVMe subsystem
Updates an NVMe subsystem to modify its configuration or attributes as needed. This is useful for managing NVMe storage resources effectively.
HTTP method and endpoint
PATCH /protocols/nvme/subsystems/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver nvme subsystem modify
Learn more
uuid |
string |
path |
True |
The unique identifier of the NVMe subsystem. |
Request Body
| Name | Type | Description |
comment |
string |
A configurable comment for the NVMe subsystem. Optional in POST and PATCH. |
delete_on_unmap |
boolean |
An option that causes the subsystem to be deleted when the last subsystem map associated with it is deleted. This property defaults to false when the subsystem is created. |
io_queue |
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller. |
serial_number |
string |
The serial number of the NVMe subsystem. |
subsystem_maps |
array[subsystem_maps] |
The NVMe namespaces mapped to the NVMe subsystem. There is an added cost to retrieving property values for |
svm |
target_nqn |
string |
The NVMe qualified name (NQN) used to identify the NVMe storage target. |
uuid |
string |
Example request
"comment": "string",
"io_queue": {
"default": {
"count": 4,
"depth": 16
"serial_number": "wCVsgFMiuMhVAAAAAAAB",
"subsystem_maps": [
"anagrpid": "00103050h",
"namespace": {
"name": "/vol/vol1/namespace1",
"nsid": "00000001h"
"svm": {
"name": "svm1",
"target_nqn": "nqn.1992-01.example.com:string",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
72090001 |
The NVMe subsystem does not exist. |
href |
string |
_links
hosts
default
The default I/O queue parameters inherited by NVMe hosts in the NVMe subsystem.
count |
integer |
The number of host I/O queue pairs. |
depth |
integer |
The host I/O queue depth. |
io_queue
default |
The default I/O queue parameters inherited by NVMe hosts in the NVMe subsystem. |
namespace
An NVMe namespace mapped to the NVMe subsystem.
name |
string |
The name of the NVMe namespace. |
uuid |
string |
The unique identifier of the NVMe namespace. |
subsystem_maps
anagrpid |
string |
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace. The format for an ANAGRPIP is 8 hexadecimal digits (zero-filled) followed by a lower case "h". |
namespace |
An NVMe namespace mapped to the NVMe subsystem. |
nsid |
string |
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace. The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h". |
svm
name |
string |
The name of the SVM. |
uuid |
string |
nvme_subsystem
An NVMe subsystem maintains configuration state and namespace access control for a set of NVMe-connected hosts.
comment |
string |
delete_on_unmap |
boolean |
io_queue |
serial_number |
string |
subsystem_maps |
svm |
target_nqn |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
