Update an NVMe subsystem
PATCH /protocols/nvme/subsystems/{uuid}
Introduced In: 9.6
Updates an NVMe subsystem.
Related ONTAP commands
vserver nvme subsystem modify
Learn more
uuid |
string |
path |
True |
The unique identifier of the NVMe subsystem. |
Request Body
| Name | Type | Description |
comment |
string |
A configurable comment for the NVMe subsystem. Optional in POST and PATCH. |
delete_on_unmap |
boolean |
An option that causes the subsystem to be deleted when the last subsystem map associated with it is deleted. Optional in POST and PATCH. This property defaults to false when the subsystem is created. |
io_queue |
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller. |
serial_number |
string |
The serial number of the NVMe subsystem. |
subsystem_maps |
array[subsystem_maps] |
The NVMe namespaces mapped to the NVMe subsystem. There is an added computational cost to retrieving property values for |
target_nqn |
string |
The NVMe qualified name (NQN) used to identify the NVMe storage target. |
uuid |
string |
Example request
"comment": "string",
"io_queue": {
"default": {
"count": 4,
"depth": 16
"serial_number": "wCVsgFMiuMhVAAAAAAAB",
"subsystem_maps": [
"anagrpid": "00103050h",
"namespace": {
"name": "/vol/vol1/namespace1",
"nsid": "00000001h"
"target_nqn": "nqn.1992-01.example.com:string",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
72090001 |
The NVMe subsystem does not exist. |
href |
string |
_links
dh_hmac_chap
A container for properties of NVMe in-band authentication with the DH-HMAC-CHAP protocol.
mode |
string |
The expected NVMe in-band authentication mode for the host. This property is an indication of which secrets are configured for the host. When set to:
hosts
dh_hmac_chap |
A container for properties of NVMe in-band authentication with the DH-HMAC-CHAP protocol. |
default
The default I/O queue parameters inherited by NVMe hosts in the NVMe subsystem.
count |
integer |
The number of host I/O queue pairs. |
depth |
integer |
The host I/O queue depth. |
io_queue
default |
The default I/O queue parameters inherited by NVMe hosts in the NVMe subsystem. |
namespace
An NVMe namespace mapped to the NVMe subsystem.
name |
string |
The name of the NVMe namespace. |
uuid |
string |
The unique identifier of the NVMe namespace. |
subsystem_maps
anagrpid |
string |
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace. The format for an ANAGRPIP is 8 hexadecimal digits (zero-filled) followed by a lower case "h". |
namespace |
An NVMe namespace mapped to the NVMe subsystem. |
nsid |
string |
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace. The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h". |
svm
name |
string |
uuid |
string |
nvme_subsystem
An NVMe subsystem maintains configuration state and namespace access control for a set of NVMe-connected hosts.
comment |
string |
delete_on_unmap |
boolean |
io_queue |
serial_number |
string |
subsystem_maps |
target_nqn |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
