Update the S3 group configuration for an SVM
Updates the S3 group configuration for an SVM to modify group attributes such as name, users, and attached policies. This operation is useful for managing access and permissions within your S3 environment.
HTTP method and endpoint
PATCH /protocols/s3/services/{svm.uuid}/groups/{id}
Introduced in
ONTAP 9.8
Usage notes
Updates the S3 group configuration of an SVM.
Important notes
The following fields can be modified for a group:
name- Group name that needs to be modified. -
users- List of users present in the group. -
policies- List of policies to be attached to this group.
Recommended optional properties
comment- Short description about the S3 Group.
Related ONTAP commands
vserver object-store-server group modify
Learn more
id |
integer |
path |
True |
Group identifier that identifies the unique group. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
comment |
string |
Can contain any additional information about the group being created or modified. |
id |
integer |
Specifies a unique group ID used to identify a particular group. This parameter should not be specified in the POST method. A group ID is automatically generated and it is retrieved using the GET method. Group id is SVM scoped. |
name |
string |
Specifies the name of the group. A group name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
policies |
array[policies] |
Specifies a list of policies that are attached to the group. The wildcard character "*" is a valid value for specifying all policies. |
svm |
users |
array[users] |
Specifies the list of users who belong to the group. |
Example request
"comment": "Admin group",
"id": 5,
"name": "Admin-Group",
"policies": [
"name": "Policy1"
"svm": {
"name": "svm1",
"users": [
"name": "user-1"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405896 |
Users list cannot be empty. |
92405930 |
Group name is not valid. Group names must have between 1 and 128 characters. |
92405931 |
Group name contains invalid characters. Valid characters for a group name are 0-9, A-Z, a-z, "_", "+", "=", ",", ".", "@", and "-". |
92405934 |
User name specified in the user list do not exist for SVM. Use the "object-store-server user create" command to create a user. |
92405936 |
Query characters such as * are not supported in the user list. |
92405937 |
Policy name specified in the policy list do not exist for SVM. |
92405966 |
User name is present more than once in the users field. |
href |
string |
_links
policies
name |
string |
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
svm
name |
string |
The name of the SVM. |
uuid |
string |
users
name |
string |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
s3_group
This is a container for S3 user groups.
comment |
string |
id |
integer |
name |
string |
policies |
array[policies] |
svm |
users |
array[users] |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
