REST API reference
Update the S3 group configuration for an SVM
Updates the S3 group configuration of an SVM to modify group details such as name, users, and policies.
HTTP method and endpoint
PATCH /protocols/s3/services/{svm.uuid}/groups/{id}
Introduced in
ONTAP 9.8
Important notes
  • The following fields can be modified for a group:
  • name - Group name that needs to be modified.
  • users - List of users present in the group.
  • policies - List of policies to be attached to this group.
  • comment - Short description about the S3 Group.
  • vserver object-store-server group modify
id
integer
path
True
Group identifier that identifies the unique group.
svm.uuid
string
path
True
Request Body
Name Type Description
comment
string
Can contain any additional information about the group being created or modified.
id
integer
Specifies a unique group ID used to identify a particular group. This parameter should not be specified in the POST method. A group ID is automatically generated and it is retrieved using the GET method. Group id is SVM scoped.
name
string
Specifies the name of the group. A group name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
policies
array[policies]
Specifies a list of policies that are attached to the group. The wildcard character "*" is a valid value for specifying all policies.
svm
svm
users
array[users]
Specifies the list of users who belong to the group.
Example request
  "comment": "Admin group",
  "id": 5,
  "name": "Admin-Group",
  "policies": [
      "name": "Policy1"
  "svm": {
    "name": "svm1",
  "users": [
      "name": "user-1"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
92405896
Users list cannot be empty.
92405930
Group name is not valid. Group names must have between 1 and 128 characters.
92405931
Group name contains invalid characters. Valid characters for a group name are 0-9, A-Z, a-z, "_", "+", "=", ",", ".", "@", and "-".
92405934
User name specified in the user list do not exist for SVM. Use the "object-store-server user create" command to create a user.
92405936
Query characters such as * are not supported in the user list.
92405937
Policy name specified in the policy list do not exist for SVM.
262222
User name is present more than once in the users field.
string
policies
name
string
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
svm
name
string
The name of the SVM.
uuid
string
users
name
string
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
s3_group
This is a container for S3 user groups.
comment
string
id
integer
name
string
policies
array[policies]
svm
svm
users
array[users]
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
