REST API reference
Both nis domain and servers can be updated domains and servers cannot be empty both fqdns and ip addresses are supported for the servers field if the domain is updated, nis servers must also be specified ipv6 must be enabled if ipv6 family addresses are specified for the servers property<br/>
PATCH /security/authentication/cluster/nis
Introduced In: 9.6
Both NIS domain and servers can be updated. Domains and servers cannot be empty. Both FQDNs and IP addresses are supported for the 'servers' field. If the domain is updated, NIS servers must also be specified. IPv6 must be enabled if IPv6 family addresses are specified for the servers property.
Request Body
Name Type Description
_links
_links
bound_servers
array[string]
domain
string
The NIS domain to which this configuration belongs.
servers
array[string]
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
Example request
  "bound_servers": [
    "string"
  "domain": "string",
  "servers": [
    "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1966253
IPv6 is not enabled in the cluster .
3276964
The NIS domain name or NIS server domain is too long. The maximum supported for domain name is 64 characters and the maximum supported for NIS server domain is 255 characters.
3276933
A maximum of 10 NIS servers can be configured per SVM.
23724109
DNS resolution failed for one or more specified servers.
23724112
DNS resolution failed due to an internal error. Contact technical support if this issue persists.
23724132
DNS resolution failed for all the specified servers.
23724130
Cannot use an IPv6 name server address because there are no IPv6 interfaces
string
binding_status
code
string
Code corresponding to the server's binding status.
message
string
Detailed description of the server's binding status.
binding_details
server
string
Hostname/IP address of the NIS server in the domain.
status
binding_status
cluster_nis_service
_links
_links
bound_servers
array[string]
domain
string
servers
array[string]
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
