REST API reference
Updates the public key for a user account
learn more
  • [doc /security/authentication/publickeys/{owneruuid}/{accountname}/{index}](#docs-security-security_authentication_publickeys_{owneruuid}_{accountname}_{index})
  • [doc /security/accounts](#docs-security-security_accounts)
PATCH /security/authentication/publickeys/{owner.uuid}/{account.name}/{index}
Introduced In: 9.7
Updates the public key for a user account.
  • security login publickey modify
owner.uuid
string
path
True
Account owner UUID
account.name
string
path
True
User account name
index
integer
path
True
Index number for the public key (where there are multiple keys for the same account).
  • Max value: 99
  • Min value: 0
Request Body
Name Type Description
comment
string
Optional comment for the public key.
obfuscated_fingerprint
string
The obfuscated fingerprint for the public key (READONLY).
public_key
string
The public key
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
sha_fingerprint
string
The SHA fingerprint for the public key (READONLY).
Example request
  "comment": "string",
  "obfuscated_fingerprint": "string",
  "public_key": "string",
  "scope": "string",
  "sha_fingerprint": "string"
Status: 200, Ok
Status: Default, Error
string
account_reference
_links
_links
name
string
User account
owner
Owner name and UUID that uniquely identifies the public key.
name
string
The name of the SVM.
uuid
string
publickey
The public key for the user account (to access SSH).
comment
string
string
public_key
string
The public key
scope
string
sha_fingerprint
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
