Update a public key for a user account
PATCH /security/authentication/publickeys/{owner.uuid}/{account.name}/{index}
Introduced In: 9.7
Updates the public key and/or certificate for a user account.
Related ONTAP commands
security login publickey modify
Learn more
owner.uuid |
string |
path |
True |
Account owner UUID |
account.name |
string |
path |
True |
User account name |
index |
integer |
path |
True |
Index number for the public key (where there are multiple keys for the same account).
Request Body
| Name | Type | Description |
certificate |
string |
Optional certificate for the public key. |
certificate_details |
string |
The details present in the certificate (READONLY). |
certificate_expired |
string |
The expiration details of the certificate (READONLY). |
certificate_revoked |
string |
The revocation details of the certificate (READONLY). |
comment |
string |
Optional comment for the public key. |
obfuscated_fingerprint |
string |
The obfuscated fingerprint for the public key (READONLY). |
public_key |
string |
The public key |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
sha_fingerprint |
string |
The SHA fingerprint for the public key (READONLY). |
Example request
"certificate": "string",
"certificate_details": "string",
"certificate_expired": "string",
"certificate_revoked": "string",
"comment": "string",
"obfuscated_fingerprint": "string",
"public_key": "string",
"scope": "string",
"sha_fingerprint": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5832707 |
Failed to generate fingerprint for the public key. |
href |
string |
_links
account_reference
name |
string |
User account |
owner
Owner name and UUID that uniquely identifies the public key.
name |
string |
uuid |
string |
publickey
The public key for the user account (to access SSH).
certificate |
string |
string |
string |
string |
comment |
string |
string |
public_key |
string |
The public key |
scope |
string |
sha_fingerprint |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
