REST API reference
Update a LUN attribute value
Updates a LUN attribute value to modify its configuration or characteristics according to your storage requirements.
HTTP method and endpoint
PATCH /storage/luns/{lun.uuid}/attributes/{name}
Introduced in
ONTAP 9.10
lun.uuid
string
path
True
The unique identifier of the LUN.
name
string
path
True
The name of the attribute.
Request Body
Name Type Description
lun
lun
The LUN for which the attribute is set.
value
string
The attribute value. Required in POST; valid in PATCH.
Example request
  "lun": {
  "value": "value1"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5374875
The specified LUN was not found.
5374929
The combined sizes of an attribute name and value are too large.
5374931
The specified attribute was not found.
string
lun
uuid
string
lun_attribute
A name/value pair optionally stored with the LUN. Attributes are available to callers to persist small amounts of application-specific metadata. They are in no way interpreted by ONTAP.
Attribute names and values must be at least one byte and no more than 4091 bytes in length. The sum of the name and value lengths must be no more than 4092 bytes.
lun
lun
value
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
