Update a LUN attribute value
Updates a LUN attribute value to modify its configuration or behavior as needed.
HTTP method and endpoint
PATCH /storage/luns/{lun.uuid}/attributes/{name}
Introduced in
ONTAP 9.10
Learn more
lun.uuid |
string |
path |
True |
The unique identifier of the LUN. |
name |
string |
path |
True |
The name of the attribute. |
Request Body
| Name | Type | Description |
lun |
The LUN for which the attribute is set. |
value |
string |
The attribute value. Required in POST; valid in PATCH. |
Example request
"lun": {
"value": "value1"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374875 |
The specified LUN was not found. |
5374929 |
The combined sizes of an attribute name and value are too large. |
5374931 |
The specified attribute was not found. |
5375060 |
The move start operation failed. |
href |
string |
_links
lun
uuid |
string |
lun_attribute
A name/value pair optionally stored with the LUN. Attributes are available to callers to persist small amounts of application-specific metadata. They are in no way interpreted by ONTAP.
Attribute names and values must be at least one byte and no more than 4091 bytes in length. The sum of the name and value lengths must be no more than 4092 bytes.
lun |
value |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
