Updates the storage pool specified by the uuid with the properties in the body this request starts a job and returns a link to that job
storage pool reassign -
storage pool add
PATCH /storage/pools/{uuid}
Introduced In: 9.11
Updates the storage pool specified by the UUID with the properties in the body. This request starts a job and returns a link to that job.
Related ONTAP commands
storage pool rename -
storage pool add
uuid |
string |
path |
True |
Storage pool UUID. |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
capacity |
name |
string |
Storage pool name. |
nodes |
array[node_reference] |
Nodes that can use this storage pool for their aggregates. |
storage_type |
string |
Storage type for the disks used to create the storage pool. |
uuid |
string |
Example request
"capacity": {
"disks": [
"disk": {
"name": "1.0.1"
"total_size": 0,
"usable_size": 0
"remaining": 0,
"spare_allocation_units": [
"available_size": 0,
"node": {
"name": "node1",
"size": 0,
"syncmirror_pool": "string"
"total": 0,
"used_allocation_units": [
"aggregate": {
"name": "aggr1",
"current_usage": 0,
"node": {
"name": "node1",
"name": "string",
"nodes": [
"name": "node1",
"storage_type": "string",
"uuid": "string"
Status: 200, Ok
job |
num_records |
integer |
Number of shared storage pools in the cluster. |
records |
array[storage_pool] |
"job": {
"uuid": "string"
"records": [
"capacity": {
"disks": [
"disk": {
"name": "1.0.1"
"total_size": 0,
"usable_size": 0
"remaining": 0,
"node": {
"name": "node1",
"size": 0,
"total": 0,
"aggregate": {
"name": "aggr1",
"current_usage": 0,
"node": {
"name": "node1",
"name": "string",
"nodes": [
"name": "node1",
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
11211658 |
Node does not have enough spare capacity. |
11211659 |
Valid allocation unit input is required. |
11211662 |
Specified node is not part of the storage pool. |
11211663 |
Failed to reassign available capacity in the storage pool. |
11211664 |
Could not fix the broken allocation unit for the storage pool. |
11212673 |
Could not grow one or more aggregates. |
11212679 |
Adding specified number of disks will expand storage pool beyond maximum supported disk limit. |
11212680 |
Incorrect node specified. |
11212681 |
0 is an invalid value for disk_count. |
11212682 |
Adding the specified number of disks will result in the storage pool reaching the maximum disk limit reserved for RAID-TEC use only. At this limit, the storage pool can only allocate capacity to aggregates containing RAID-TEC RAID groups. Existing aggregates containing RAID groups other than RAID-TEC will not automatically grow to the new capacity. |
11212683 |
Renaming storage pool to new name failed. |
11212763 |
Storage pool add job failed. |
11215657 |
Storage pool PATCH request have missing parameters. |
11215658 |
Storage pool PATCH request for reassign is invalid. |
11215659 |
Storage pool PATCH request for reassign have invalid allocation unit count. |
11215660 |
Storage pool PATCH request for reassign have invalid node name. |
11215662 |
Storage pool PATCH request have invalid disk count. |
href |
string |
_links
disk
Reference to the constituent disk object.
name |
string |
storage_pool_disk
disk |
Reference to the constituent disk object. |
total_size |
integer |
Raw capacity of the disk, in bytes. |
usable_size |
integer |
Usable capacity of this disk, in bytes. |
node
Specifies what node can use this set of allocation units.
name |
string |
uuid |
string |
storage_pool_spare_allocation_unit
available_size |
integer |
The usable capacity of this set of allocation units. |
count |
integer |
The number of spare allocation units on this node. |
node |
Specifies what node can use this set of allocation units. |
size |
integer |
Size of each allocation unit. |
syncmirror_pool |
string |
The RAID SyncMirror Pool to which this allocation unit is assigned. |
aggregate
The aggregate that is using this cache capacity.
name |
string |
uuid |
string |
node
The node hosting the aggregate using this set of allocation units.
name |
string |
uuid |
string |
storage_pool_used_allocation_unit
aggregate |
The aggregate that is using this cache capacity. |
count |
integer |
The number of allocation units used by this aggregate. |
current_usage |
integer |
The amount of cache space used by this aggregate. |
node |
The node hosting the aggregate using this set of allocation units. |
capacity
disk_count |
integer |
The number of disks in the storage pool. |
disks |
array[storage_pool_disk] |
Properties of each disk used in the shared storage pool. |
remaining |
integer |
Remaining usable capacity in the flash pool, in bytes. |
spare_allocation_units |
Properties of spare allocation units. |
total |
integer |
Total size of the flash pool, in bytes. |
used_allocation_units |
Information about the storage pool allocation units participating in the cache tier of an aggregate. |
code |
string |
Argument code |
message |
string |
Message argument |
error
Indicates why the storage pool is unhealthy. This property is not returned for healthy storage pools.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
health
Properties that outline shared storage pool health.
is_healthy |
boolean |
Indicates whether the storage pool is able to participate in provisioning operations. |
state |
string |
The state of the shared storage pool. |
node_reference
name |
string |
uuid |
string |
storage_pool
capacity |
name |
string |
nodes |
storage_type |
string |
uuid |
string |
job_link
uuid |
string |
error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
