REST API reference
Update a storage pool specified by the UUID
PATCH /storage/pools/{uuid}
Introduced In: 9.11
Updates the storage pool specified by the UUID with the properties in the body. This request starts a job and returns a link to that job.
  • storage pool rename
  • storage pool reassign
  • storage pool add
uuid
string
path
True
Storage pool UUID.
simulate
boolean
query
False
When set to "true" in conjunction with a PATCH on "capacity.disk_count", the end point returns a simulated layout of the storage pool with the additional disks, without changing system state.
  • Introduced in: 9.12
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
capacity
capacity
name
string
Storage pool name.
nodes
array[node_reference]
Nodes that can use this storage pool for their aggregates.
storage_type
string
Storage type for the disks used to create the storage pool.
uuid
string
Storage pool UUID.
Example request
  "capacity": {
    "disks": [
        "disk": {
          "name": "1.0.1"
        "total_size": 0,
        "usable_size": 0
    "remaining": 0,
    "spare_allocation_units": [
        "available_size": 0,
        "node": {
          "name": "node1",
        "size": 0,
        "syncmirror_pool": "string"
    "total": 0,
    "used_allocation_units": [
        "aggregate": {
          "name": "aggr1",
        "current_usage": 0,
        "node": {
          "name": "node1",
  "name": "string",
  "nodes": [
      "name": "node1",
  "storage_type": "string",
  "uuid": "string"
Status: 200, Ok
job
job_link
num_records
integer
Number of shared storage pools in the cluster.
records
array[storage_pool]
  "job": {
    "uuid": "string"
  "num_records": 1,
  "records": [
      "capacity": {
        "disks": [
            "disk": {
              "name": "1.0.1"
            "total_size": 0,
            "usable_size": 0
        "remaining": 0,
            "node": {
              "name": "node1",
            "size": 0,
        "total": 0,
            "aggregate": {
              "name": "aggr1",
            "current_usage": 0,
            "node": {
              "name": "node1",
      "name": "string",
      "nodes": [
          "name": "node1",
      "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
11211658
Node does not have enough spare capacity.
11211659
Valid allocation unit input is required.
11211662
Specified node is not part of the storage pool.
11211663
Failed to reassign available capacity in the storage pool.
11211664
Could not fix the broken allocation unit for the storage pool.
11212673
Could not grow one or more aggregates.
11212679
Adding specified number of disks will expand storage pool beyond maximum supported disk limit.
11212680
Incorrect node specified.
11212681
0 is an invalid value for disk_count.
11212682
Adding the specified number of disks will result in the storage pool reaching the maximum disk limit reserved for RAID-TEC use only. At this limit, the storage pool can only allocate capacity to aggregates containing RAID-TEC RAID groups. Existing aggregates containing RAID groups other than RAID-TEC will not automatically grow to the new capacity.
11212683
Renaming storage pool to new name failed.
11212763
Storage pool add job failed.
11215657
Storage pool PATCH request have missing parameters.
11215658
Storage pool PATCH request for reassign is invalid.
11215659
Storage pool PATCH request for reassign have invalid allocation unit count.
11215660
Storage pool PATCH request for reassign have invalid node name.
11215662
Storage pool PATCH request have invalid disk count.
string
disk
Reference to the constituent disk object.
name
string
storage_pool_disk
disk
disk
total_size
integer
Raw capacity of the disk, in bytes.
usable_size
integer
Usable capacity of this disk, in bytes.
node
Specifies what node can use this set of allocation units.
name
string
uuid
string
storage_pool_spare_allocation_unit
available_size
integer
The usable capacity of this set of allocation units.
count
integer
The number of spare allocation units on this node.
node
node
size
integer
Size of each allocation unit.
syncmirror_pool
string
The RAID SyncMirror Pool to which this allocation unit is assigned.
aggregate
The aggregate that is using this cache capacity.
name
string
uuid
string
node
The node hosting the aggregate using this set of allocation units.
name
string
uuid
string
storage_pool_used_allocation_unit
aggregate
aggregate
count
integer
The number of allocation units used by this aggregate.
current_usage
integer
The amount of cache space used by this aggregate.
node
node
capacity
disk_count
integer
The number of disks in the storage pool.
disks
array[storage_pool_disk]
Properties of each disk used in the shared storage pool.
remaining
integer
Remaining usable capacity in the flash pool, in bytes.
array[storage_pool_spare_allocation_unit]
Properties of spare allocation units.
total
integer
Total size of the flash pool, in bytes.
array[storage_pool_used_allocation_unit]
Information about the storage pool allocation units participating in the cache tier of an aggregate.
code
string
Argument code
message
string
Message argument
error
Indicates why the storage pool is unhealthy. This property is not returned for healthy storage pools.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
health
Properties that outline shared storage pool health.
is_healthy
boolean
Indicates whether the storage pool is able to participate in provisioning operations.
state
string
The state of the shared storage pool.
node_reference
name
string
uuid
string
storage_pool
capacity
capacity
name
string
Storage pool name.
nodes
storage_type
string
uuid
string
Storage pool UUID.
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
