Update a storage port
Updates a storage port to modify its configuration or change its operational status. Use this operation to manage the network connectivity of your storage system effectively.
HTTP method and endpoint
PATCH /storage/ports/{node.uuid}/{name}
Introduced in
ONTAP 9.11
Related ONTAP commands
storage port modify -
storage port enable -
storage port disable
Learn more
node.uuid |
string |
path |
True |
Node UUID |
name |
string |
path |
True |
Port name |
Request Body
| Name | Type | Description |
board_name |
string |
description |
string |
enabled |
boolean |
firmware_version |
string |
force |
boolean |
in_use |
boolean |
Specifies whether any devices are connected through this port |
mac_address |
string |
mode |
string |
Operational mode of a non-dedicated Ethernet port |
name |
string |
node |
part_number |
string |
redundant |
boolean |
Specifies whether all devices connected through this port have a redundant path from another port |
serial_number |
string |
speed |
number |
Operational port speed in Gbps |
state |
string |
type |
string |
wwn |
string |
World Wide Name |
wwpn |
string |
World Wide Port Name |
Example request
"board_name": "string",
"description": "SAS Host Adapter 2a (PMC-Sierra PM8072 rev. C)",
"firmware_version": "03.08.09.00",
"mac_address": "string",
"mode": "storage",
"name": "2a",
"node": {
"name": "node1",
"part_number": "111-03801",
"serial_number": "7A2463CC45B",
"speed": "6",
"state": "online",
"type": "sas",
"wwn": "50000d1703544b80",
"wwpn": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
17891328 |
Port operation " |
17891329 |
Port " |
17891330 |
Port operation " |
17891331 |
Cannot complete operation on port " |
17891332 |
Port operation " |
17891333 |
Port operation " |
17891334 |
Port operation " |
17891338 |
Device operation " |
17891339 |
17891344 |
17891345 |
17891346 |
Port " |
17891347 |
Port " |
17891350 |
Port " |
17891350 |
Port " |
17891352 |
Port operation " |
17891353 |
Unable to enable port " |
17891354 |
Unable to disable port " |
17891355 |
Port operation " |
17891356 |
Unable to |
cable
identifier |
string |
length |
string |
part_number |
string |
serial_number |
string |
error
corrective_action |
string |
Error corrective action |
message |
string |
Error message |
href |
string |
_links
node
name |
string |
uuid |
string |
storage_port
board_name |
string |
description |
string |
enabled |
boolean |
firmware_version |
string |
force |
boolean |
in_use |
boolean |
mac_address |
string |
mode |
string |
name |
string |
node |
part_number |
string |
redundant |
boolean |
serial_number |
string |
speed |
number |
state |
string |
type |
string |
wwn |
string |
World Wide Name |
wwpn |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
