REST API reference
Update a storage port
Updates a storage port to modify its configuration or operational state. Use this endpoint when you need to make changes to the settings of an existing storage port in your ONTAP system.
HTTP method and endpoint
PATCH /storage/ports/{node.uuid}/{name}
Introduced in
ONTAP 9.11
  • storage port modify
  • storage port enable
  • storage port disable
Learn more
node.uuid
string
path
True
Node UUID
name
string
path
True
Port name
Request Body
Name Type Description
board_name
string
cable
cable
description
string
enabled
boolean
error
error
firmware_version
string
force
boolean
in_use
boolean
Specifies whether any devices are connected through this port
mac_address
string
mode
string
Operational mode of a non-dedicated Ethernet port
name
string
node
node
part_number
string
redundant
boolean
Specifies whether all devices connected through this port have a redundant path from another port
serial_number
string
speed
number
Operational port speed in Gbps
state
string
type
string
wwn
string
World Wide Name
wwpn
string
World Wide Port Name
Example request
  "board_name": "string",
  "cable": {
    "identifier": "500a0980000b6c3f-50000d1703544b80",
    "length": "2m",
    "part_number": "112-00431+A0",
    "serial_number": 616930439,
    "transceiver": "mini_sas_hd",
    "vendor": "Molex Inc."
  "description": "SAS Host Adapter 2a (PMC-Sierra PM8072 rev. C)",
  "error": {
    "corrective_action": "string",
    "message": "string"
  "firmware_version": "03.08.09.00",
  "mac_address": "string",
  "mode": "storage",
  "name": "2a",
  "node": {
    "name": "node1",
  "part_number": "111-03801",
  "serial_number": "7A2463CC45B",
  "speed": 6,
  "state": "online",
  "type": "sas",
  "wwn": "50000d1703544b80",
  "wwpn": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
17891328
Port operation "\" failed on port \"\". This might indicate a hardware error, an illegal request, or an aborted command.
17891329
Port "\" is invalid.
17891330
Port operation "\" failed on port \"\" because it is not supported on this port type.
17891331
Cannot complete operation on port "\". The status of the port is not available.
17891332
Port operation "\" failed on port \"\". The port is not offline.
17891333
Port operation "\" failed on port \"\". The port is already offline.
17891334
Port operation "\" failed on port \"\". One or more devices on the port is currently being sanitized.
17891338
Device operation "\" failed on port \"\". Some devices can only be accessed through this port. Disabling this port might cause multiple device failures.
17891339
Device operation "\" failed on port \"\". Some devices can only be accessed through this port. Disabling this port might cause multiple device failures. Use the \"-force\" parameter to ignore checks and the port.
17891344
Device operation "\" failed on port \"\" because the port is in use.
17891345
Device operation "\" failed on port \"\" because the port is in use. Use the \"-force\" parameter to ignore checks and the port.
17891346
Port "\" is already enabled.
17891347
Port "\" is already disabled.
17891350
Port "\" is not a valid storage Ethernet port.
17891350
17891352
Port operation "\" failed on port \"\". Reboot node \"\" to recover.
17891353
Unable to enable port "\" because it is in network mode.
17891354
Unable to disable port "\" because it is in network mode.
17891355
Port operation "\" failed on port \"\" because it is not supported on dedicated ports.
17891356
Unable to port \"\" when setting mode to \"\".
cable
identifier
string
length
string
part_number
string
serial_number
string
transceiver
string
vendor
string
error
corrective_action
string
Error corrective action
message
string
Error message
string
node
name
string
uuid
string
storage_port
board_name
string
cable
cable
description
string
enabled
boolean
error
error
firmware_version
string
force
boolean
in_use
boolean
mac_address
string
mode
string
name
string
node
node
part_number
string
redundant
boolean
serial_number
string
speed
number
state
string
type
string
wwn
string
World Wide Name
wwpn
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
