Update the comment parameter of an SNMP user
Updates the comment parameter of an SNMP user to modify its description or purpose as needed.
HTTP method and endpoint
PATCH /support/snmp/users/{engine_id}/{name}
Introduced in
ONTAP 9.7
Optional properties
comment- Comment text.
Related ONTAP commands
security login modify
Learn more
engine_id |
string |
path |
True |
Engine ID of owning SVM or remote switch. |
name |
string |
path |
True |
SNMP user name. |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
Optional comment text. |
owner |
Optional name and UUID of owning Storage Virtual Machine (SVM). |
Example request
"comment": "This is a comment.",
"owner": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621475 |
This operation is not allowed on a node SVM. |
2621699 |
This operation is not allowed on a system SVM. |
5636123 |
Cannot create an SNMP user with a role other than readonly, none, or admin. |
5636124 |
Cannot create an SNMP user with a role other than vsadmin-readonly, none, or vsadmin. |
5832712 |
Cannot modify attributes for user "diag." |
7077906 |
Cannot use given role with this SVM because a role with that name has not been defined for the SVM. |
9043999 |
ONTAP failed to create an SNMPv3 user because SNMPv3 is disabled in the cluster. |
href |
string |
_links
owner
name |
string |
The name of the SVM. |
uuid |
string |
snmpv3
Optional parameter that can be specified only for an SNMPv3 user i.e. when 'authentication_method' is either 'usm' or 'both'. This parameter defines the SNMPv3 credentials for an SNMPv3 user.
authentication_protocol |
string |
Authentication protocol. |
privacy_protocol |
string |
Privacy protocol. |
snmp_user
An SNMP user can be an SNMPv1/SNMPv2c user or an SNMPv3 user. SNMPv1/SNMPv2c user is also called a "community" user. An SNMPv3 user, also called a User-based Security Model (USM) user, can be a local SNMPv3 user or a remote SNMPv3 user. A local SNMPv3 user can be used for querying ONTAP SNMP server over SNMPv3 and/or for sending SNMPv3 traps. The local SNMPv3 user used for sending SNMPv3 traps must be configured with the same authentication and privacy credentials on the traphost receiver as well. A remote SNMPv3 user is also configured on a remote switch and used by ONTAP SNMP client functionality to query the remote switch over SNMPv3. An SNMP user is scoped to its owning Storage Virtual Machine (SVM). Owning SVM could be a data SVM or the administrative SVM.
comment |
string |
owner |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
