REST API reference
Update the comment parameter of an SNMP user
Updates the comment for an SNMP user, specifying details relevant to the user's configuration. Use this endpoint to modify SNMP user information as needed for maintenance or documentation purposes.
HTTP method and endpoint
PATCH /support/snmp/users/{engine_id}/{name}
Introduced in
ONTAP 9.7
Usage notes
Updates the comment parameter of an SNMP user.
Optional properties
  • comment - Comment text.
  • security login modify
engine_id
string
path
True
Engine ID of owning SVM or remote switch.
name
string
path
True
SNMP user name.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
comment
string
Optional comment text.
Example request
  "comment": "This is a comment."
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
2621475
This operation is not allowed on a node SVM.
2621699
This operation is not allowed on a system SVM.
5636123
Cannot create an SNMP user with a role other than readonly, none, or admin.
5636124
Cannot create an SNMP user with a role other than vsadmin-readonly, none, or vsadmin.
5832712
Cannot modify attributes for user "diag."
7077906
Cannot use given role with this SVM because a role with that name has not been defined for the SVM.
9043999
ONTAP failed to create an SNMPv3 user because SNMPv3 is disabled in the cluster.
string
owner
Optional name and UUID of owning Storage Virtual Machine (SVM).
name
string
uuid
string
snmpv3
Optional parameter that can be specified only for an SNMPv3 user i.e. when 'authentication_method' is either 'usm' or 'both'. This parameter defines the SNMPv3 credentials for an SNMPv3 user.
authentication_protocol
string
Authentication protocol.
privacy_protocol
string
Privacy protocol.
snmp_user
An SNMP user can be an SNMPv1/SNMPv2c user or an SNMPv3 user. SNMPv1/SNMPv2c user is also called a "community" user. An SNMPv3 user, also called a User-based Security Model (USM) user, can be a local SNMPv3 user or a remote SNMPv3 user. A local SNMPv3 user can be used for querying ONTAP SNMP server over SNMPv3 and/or for sending SNMPv3 traps. The local SNMPv3 user used for sending SNMPv3 traps must be configured with the same authentication and privacy credentials on the traphost receiver as well. A remote SNMPv3 user is also configured on a remote switch and used by ONTAP SNMP client functionality to query the remote switch over SNMPv3. An SNMP user is scoped to its owning Storage Virtual Machine (SVM). Owning SVM could be a data SVM or the administrative SVM.
comment
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
