REST API reference
Create an LDAP schema
Creates an LDAP schema to define and manage directory attributes and their relationships. Use this when you need to customize or extend the default LDAP schemas provided.
HTTP method and endpoint
POST /name-services/ldap-schemas
Introduced in
ONTAP 9.11
Important notes
  • To create a new schema, first create a copy of the default schemas provided by ONTAP and then modify the copy accordingly.
  • If no value is specified for the owner.uuid or owner.name fields, the cserver UUID and name are used by default.
  • vserver services name-service ldap client schema copy
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
global_schema
boolean
A global schema that can be used by all the SVMs.
name
string
The name of the schema being created, modified or deleted.
owner
owner
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
template
template
The existing schema template you want to copy.
Example request
  "global_schema": 1,
  "name": "AD-SFU-v1",
  "owner": {
    "name": "svm1",
  "scope": "string",
  "template": {
    "name": "AD-SFU-v1"
Status: 201, Created
global_schema
boolean
name
string
owner
owner
scope
string
template
template
  "global_schema": 1,
  "owner": {
    "name": "svm1",
  "scope": "string",
  "template": {
    "name": "AD-SFU-v1"
Status: Default
ONTAP Error Response Codes
Error Code Description
2621706
The specified SVM UUID is incorrect for the specified SVM name.
4915221
LDAP schema name in use in data SVM.
4915222
LDAP schema name in use in admin SVM.
string
ldap_schema_account
unix
string
Attribute name used to retrieve UNIX account information.
windows
string
Attribute name used to retrieve Windows account information for a UNIX user account.
windows_to_unix
attribute
string
Attribute name used to retrieve the UNIX account information for a Windows user account.
no_domain_prefix
boolean
Indicates whether or not the name for Windows to UNIX name mapping should have a domain prefix.
object_class
string
Name used to represent the windowsToUnix object class.
ldap_schema_name_mapping
account
ldap_schema_account
windows_to_unix
windows_to_unix
owner
name
string
The name of the SVM.
uuid
string
attribute
gecos
string
RFC 2307 gecos attribute.
gid_number
string
RFC 2307 gidNumber attribute.
home_directory
string
RFC 2307 homeDirectory attribute.
login_shell
string
RFC 2307 loginShell attribute.
uid
string
RFC 1274 userid attribute used by RFC 2307 as UID.
uid_number
string
RFC 2307 uidNumber attribute.
user_password
string
RFC 2256 userPassword attribute used by RFC 2307.
cn
group
string
RFC 2256 cn attribute used by RFC 2307 when working with groups.
netgroup
string
RFC 2256 cn attribute used by RFC 2307 when working with netgroups.
member
nis_netgroup
string
RFC 2307 memberNisNetgroup attribute.
uid
string
RFC 2307 memberUid attribute.
nis
mapentry
string
RFC 2307 nisMapEntry attribute.
mapname
string
RFC 2307 nisMapName attribute.
netgroup
string
RFC 2307 nisNetgroup object class.
netgroup_triple
string
RFC 2307 nisNetgroupTriple attribute.
object
string
RFC 2307 nisObject object class.
posix
account
string
RFC 2307 posixAccount object class.
group
string
RFC 2307 posixGroup object class.
rfc2307
attribute
attribute
cn
cn
member
member
nis
nis
posix
posix
rfc2307bis
enabled
boolean
Indicates whether RFC 2307bis is enabled for the client schema.
group_of_unique_names
string
RFC 2307bis groupOfUniqueNames object class.
maximum_groups
integer
Maximum number of groups supported when RFC 2307bis is enabled.
unique_member
string
RFC 2307bis uniqueMember attribute.
template
name
string
The name of the schema.
ldap_schema
global_schema
boolean
name
string
owner
owner
scope
string
template
template
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
