Create an LDAP schema
POST /name-services/ldap-schemas
Introduced In: 9.11
Creates an LDAP schema.
Important notes
To create a new schema, first create a copy of the default schemas provided by ONTAP and then modify the copy accordingly.
If no value is specified for the owner.uuid or owner.name fields, the cserver UUID and name are used by default.
Related ONTAP commands
vserver services name-service ldap client schema copy
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
global_schema |
boolean |
A global schema that can be used by all the SVMs. |
name |
string |
The name of the schema being created, modified or deleted. |
owner |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
template |
The existing schema template you want to copy. |
Example request
"global_schema": 1,
"name": "AD-SFU-v1",
"owner": {
"name": "svm1",
"scope": "string",
"template": {
"name": "AD-SFU-v1"
Status: 201, Created
global_schema |
boolean |
name |
string |
owner |
scope |
string |
template |
"global_schema": 1,
"owner": {
"name": "svm1",
"scope": "string",
"template": {
"name": "AD-SFU-v1"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621706 |
The specified SVM UUID is incorrect for the specified SVM name. |
4915221 |
LDAP schema name in use in data SVM. |
4915222 |
LDAP schema name in use in admin SVM. |
href |
string |
_links
ldap_schema_account
unix |
string |
Attribute name used to retrieve UNIX account information. |
windows |
string |
Attribute name used to retrieve Windows account information for a UNIX user account. |
windows_to_unix
attribute |
string |
Attribute name used to retrieve the UNIX account information for a Windows user account. |
no_domain_prefix |
boolean |
Indicates whether or not the name for Windows to UNIX name mapping should have a domain prefix. |
object_class |
string |
Name used to represent the windowsToUnix object class. |
ldap_schema_name_mapping
account |
windows_to_unix |
owner
name |
string |
uuid |
string |
attribute
gecos |
string |
RFC 2307 gecos attribute. |
gid_number |
string |
RFC 2307 gidNumber attribute. |
home_directory |
string |
RFC 2307 homeDirectory attribute. |
login_shell |
string |
RFC 2307 loginShell attribute. |
uid |
string |
RFC 1274 userid attribute used by RFC 2307 as UID. |
uid_number |
string |
RFC 2307 uidNumber attribute. |
user_password |
string |
RFC 2256 userPassword attribute used by RFC 2307. |
cn
group |
string |
RFC 2256 cn attribute used by RFC 2307 when working with groups. |
netgroup |
string |
RFC 2256 cn attribute used by RFC 2307 when working with netgroups. |
member
nis_netgroup |
string |
RFC 2307 memberNisNetgroup attribute. |
uid |
string |
RFC 2307 memberUid attribute. |
nis
mapentry |
string |
RFC 2307 nisMapEntry attribute. |
mapname |
string |
RFC 2307 nisMapName attribute. |
netgroup |
string |
RFC 2307 nisNetgroup object class. |
netgroup_triple |
string |
RFC 2307 nisNetgroupTriple attribute. |
object |
string |
RFC 2307 nisObject object class. |
posix
account |
string |
RFC 2307 posixAccount object class. |
group |
string |
RFC 2307 posixGroup object class. |
rfc2307
attribute |
cn |
member |
nis |
posix |
rfc2307bis
enabled |
boolean |
Indicates whether RFC 2307bis is enabled for the client schema. |
group_of_unique_names |
string |
RFC 2307bis groupOfUniqueNames object class. |
maximum_groups |
integer |
Maximum number of groups supported when RFC 2307bis is enabled. |
unique_member |
string |
RFC 2307bis uniqueMember attribute. |
template
name |
string |
The name of the schema. |
ldap_schema
global_schema |
boolean |
name |
string |
owner |
scope |
string |
template |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
