REST API reference
Create a new cluster-scoped or SVM-scoped interface
Creates a new interface that is either cluster-scoped or SVM-scoped. This is useful for configuring network access and management within your ONTAP environment.
HTTP method and endpoint
POST /network/ip/interfaces
Introduced in
ONTAP 9.6
Usage notes
Creates a new Cluster-scoped or SVM-scoped interface.
Required properties
  • name - Name of the interface to create.
  • ip or subnet
    • ip.address - IP address for the interface.
    • ip.netmask - IP subnet of the interface.
    • subnet.uuid or subnet.name
  • ipspace.name or ipspace.uuid
    • Required for Cluster-scoped interfaces.
    • Optional for SVM-scoped interfaces.
  • svm.name or svm.uuid
    • Required for an SVM-scoped interface.
    • Invalid for a Cluster-scoped interface.
  • location.home_port or location.home_node or location.broadcast_domain - One of these properties must be set to a value to define where the interface will be located.
  • service_policy
    • for SVM scoped interfaces
      • default-data-files for interfaces carrying file-oriented NAS data traffic
      • (DEPRECATED) default-data-blocks for interfaces carrying block-oriented SAN data traffic
      • default-data-iscsi for interfaces carrying iSCSI data traffic
      • default-management for interfaces carrying SVM management requests
    • for Cluster scoped interfaces
      • default-intercluster for interfaces carrying cluster peering traffic
      • default-management for interfaces carrying system management requests
      • default-route-announce for interfaces carrying BGP peer connections
Default property values
If not specified in POST, the following default property values are assigned:
  • scope
    • svm if svm parameter is specified.
    • cluster if svm parameter is not specified
  • enabled - true
  • location.auto_revert - true
  • service_policy
    • default-data-files if scope is svm
    • default-management if scope is cluster and IPspace is not Cluster
    • default-cluster if scope is cluster and IPspace is Cluster
  • failover - Selects the least restrictive failover policy supported by all the services in the service policy.
  • ddns_enabled
    • true if the interface supports data_nfs or data_cifs services
    • false otherwise
  • fail_if_subnet_conflicts - true
  • network interface create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
ddns_enabled
boolean
Indicates whether or not dynamic DNS updates are enabled. Defaults to true if the interface supports "data_nfs" or "data_cifs" services, otherwise false.
dns_zone
string
Fully qualified DNS zone name
enabled
boolean
The administrative state of the interface.
boolean
This command fails if the specified IP address falls within the address range of a named subnet. Set this value to false to use the specified IP address and to assign the subnet owning that address to the interface.
ip
ip_info
IP information
ipspace
ipspace
Either the UUID or name must be supplied on POST for cluster-scoped objects.
location
location
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node. For PATCH, set is_home to true to revert a LIF back to its home port.
name
string
Interface name
probe_port
integer
Probe port for Cloud load balancer
rdma_protocols
array[string]
Supported RDMA offload protocols
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
service_policy
service_policy
services
array[string]
The services associated with the interface.
state
string
The operational state of the interface.
subnet
ip_subnet_reference
A named subnet. Either UUID or name can be supplied on input.
svm
svm
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST.
uuid
string
The UUID that uniquely identifies the interface.
vip
boolean
True for a VIP interface, whose location is announced via BGP.
Example request
  "dns_zone": "storage.company.com",
  "ip": {
    "address": "10.10.10.7",
    "netmask": "24"
  "ipspace": {
    "name": "exchange",
  "location": {
    "broadcast_domain": {
      "name": "bd1",
    "failover": "string",
    "home_node": {
      "name": "node1",
    "home_port": {
      "name": "e1b",
      "node": {
        "name": "node1"
    "is_home": null
  "name": "dataLif1",
  "probe_port": 64001,
  "rdma_protocols": [
    "roce"
  "scope": "string",
  "service_policy": {
    "name": "default-intercluster",
  "services": [
    "data_nfs"
  "state": "string",
  "subnet": {
    "name": "subnet1",
  "svm": {
    "name": "svm1",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
1376656
Cluster interfaces must be in the same subnet. Verify the address and netmask are set to the correct values.
1376663
All LIFs from a single DNS zone must be in the same SVM.
1376663
Cannot add interface to DNS zone because all interfaces from a single DNS zone must be in the same SVM.
1376963
Duplicate IP address.
1376976
The specified port is not capable of hosting this LIF.
1966138
The same IP address may not be used for both a mgmt interface and a gateway address.
1966140
An interface with the same name already exists.
1966141
Invalid DNS zone name.
1966142
Only data LIFs can be assigned a DNS zone.
1966267
IPv6 addresses must have a prefix length between 1 and 127.
1966269
IPv4 addresses must have a prefix length between 1 and 32.
1966270
Operation not support on SAN LIFs.
1966476
DNS Update is supported only on data LIFs.
1966477
DNS Update is supported only on LIFs configured with the NFS or CIFS protocol.
1966987
The Vserver Broadcast-Domain Home-Node and Home-Port combination is not valid.
1967081
The specified SVM must exist in the specified IPspace.
1967082
The specified ipspace.name does not match the IPspace name of ipspace.uuid.
1967102
POST operation might have left configuration in an inconsistent state. Check the configuration.
1967106
The specified location.home_port.name does not match the specified port name of location.home_port.uuid.
1967107
The location.home_port.uuid specified is not valid.
1967108
The specified location.home_node.name does not match the node name of location.home_node.uuid.
1967109
The specified location.home_port.node.name does not match the node name of location.home_node.uuid.
1967110
The specified location.home_port.node.name does not match location.home_node.name.
1967111
Home node must be specified by at least one location.home_node, location.home_port, or location.broadcast_domain field.
1967112
The specified location.home_node.name does not match the node name of location.home_port.uuid.
1967120
The specified service_policy.name does not match the specified service policy name of service_policy.uuid.
1967121
Invalid service_policy.uuid specified.
1967122
The specified location.broadcast_domain.name does not match the specified broadcast domain name of location.broadcast_domain.uuid.
1967123
The specified IPspace does not match the IPspace name of location.broadcast_domain.uuid.
1967124
The location.broadcast_domain.uuid specified is not valid.
1967127
svm.uuid or svm.name must be provided if scope is "svm".
1967128
ipspace.uuid or ipspace.name must be provided if scope is "cluster".
1967129
The specified location.home_port.uuid is not valid.
1967130
The specified location.home_port.name is not valid.
1967131
The specified location.home_port.uuid and location.home_port.name are not valid.
1967135
The specified location.broadcast_domain.uuid is not valid.
1967136
The specified location.broadcast_domain.name (and ipspace name) is not valid.
1967137
The specified location.broadcast_domain.uuid and location.broadcast_domain.name (and IPspace name) are not valid.
1967145
The specified location.failover is not valid.
1967146
The specified svm.name is not valid.
1967147
The specified svm.uuid is not valid.
1967153
No suitable port exists on location.home_node to host the interface.
1967154
Interfaces cannot be created on ports that are down. If a broadcast domain is specified, ensure that it contains at least one port that is operationally up.
1967381
Post VIP interfaces requires an effective cluster version of 9.7 or later.
1967382
VIP interfaces only reside in SVM scope.
1967383
Neither location.home_port.uuid or location.home_port.name should be set with vip=true.
1967384
Failed to create VIP interface because the home node does not have active BGP sessions to support Virtual IP (VIP) traffic.
1967385
VIP interfaces with an IPv4 address must use ip.netmask=32. VIP interfaces with an IPv6 address must use ip.netmask=128.
1967387
The specified IP address is in use by a subnet in this IPspace.
1967391
Setting the DNS zone requires an effective cluster version of 9.9.1 or later.
1967392
Setting the DDNS enable parameter requires an effective cluster version of 9.9.1 or later.
1967394
Setting the probe port parameter requires an effective cluster version of 9.10.1 or later.
1967396
The specified subnet.name does not match the subnet name of subnet.uuid.
1967397
The specified subnet.uuid does not match any configured subnet.";
1967398
Address must be specified by either ip.address and ip.netmask, or at least one subnet field, not both.";
5373966
An iSCSI interface cannot be created in an SVM configured for NVMe.
53281018
Failover policy is not compatible with one or more services in service policy
53281036
Setting the probe port parameter is not allowed on this platform.
53281065
The service_policy does not exist in the SVM.
53281086
LIF would exceed the maximum number of supported intercluster LIFs in IPspace.
53281087
Cannot configure SAN LIF on SVM.
string
ip_info
IP information
address
string
IPv4 or IPv6 address
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
ipspace
name
string
IPspace name
uuid
string
IPspace UUID
broadcast_domain
name
string
Name of the broadcast domain, scoped to its IPspace
uuid
string
Broadcast domain UUID
home_node
name
string
uuid
string
node
name
string
Name of node on which the port is located.
home_port
name
string
node
node
uuid
string
node
name
string
uuid
string
port
name
string
node
node
uuid
string
location
auto_revert
boolean
broadcast_domain
broadcast_domain
failover
string
Policy that defines where an interface is permitted to move on failover. The policy named “default” implements the recommended best practice for NAS LIFs on the current platform and cluster, and was known as “system_defined” in the CLI.
home_node
home_node
home_port
home_port
throughput
The rate of throughput bytes per second observed at the interface.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
metric
The most recent sample of I/O metrics for the interface.
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
service_policy
name
string
uuid
string
throughput_raw
Throughput bytes observed at the interface. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
The real time I/O statistics for the interface.
status
string
throughput_raw
throughput_raw
timestamp
string
ip_subnet_reference
name
string
The name of the subnet. If only the name is provided, the IPspace scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the subnet.
svm
name
string
The name of the SVM.
uuid
string
ip_interface
ddns_enabled
boolean
dns_zone
string
enabled
boolean
boolean
ip
ip_info
IP information
ipspace
ipspace
location
location
name
string
Interface name
probe_port
integer
rdma_protocols
array[string]
scope
string
service_policy
service_policy
services
array[string]
state
string
subnet
ip_subnet_reference
svm
svm
uuid
string
vip
boolean
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
