Create a new cluster-scoped or SVM-scoped interface
Creates a new cluster-scoped or SVM-scoped interface to configure network connectivity within your ONTAP system. Use this operation to set up the necessary networking properties and ensure proper communication for your storage or management needs.
HTTP method and endpoint
POST /network/ip/interfaces
Introduced in
ONTAP 9.6
Required properties
name- Name of the interface to create. -
iporsubnet-
ip.address- IP address for the interface. -
ip.netmask- IP subnet of the interface. -
subnet.uuidorsubnet.name
ipspace.nameoripspace.uuid-
Required for Cluster-scoped interfaces.
Optional for SVM-scoped interfaces.
svm.nameorsvm.uuid-
Required for an SVM-scoped interface.
Invalid for a Cluster-scoped interface.
If a LIF in the subnet of the specified IP address does not already exist, a location.home_port, a location.home_node, or a location.broadcast_domain needs to be provided.
Recommended property values
service_policy-
for SVM scoped interfaces-
default-data-files for interfaces carrying file-oriented NAS data traffic
default-data-blocks for interfaces carrying block-oriented SAN data traffic
default-data-iscsi for interfaces carrying iSCSI data traffic
default-management for interfaces carrying SVM management requests
for Cluster scoped interfaces-
default-intercluster for interfaces carrying cluster peering traffic
default-management for interfaces carrying system management requests
default-route-announce for interfaces carrying BGP peer connections
Default property values
If not specified in POST, the following default property values are assigned:
scope-
svm if svm parameter is specified.
cluster if svm parameter is not specified
enabled- true -
location.auto_revert- true -
service_policy-
default-data-files if scope is
svm -
default-management if scope is
clusterand IPspace is notCluster -
default-cluster if scope is
clusterand IPspace isCluster
failover- Selects the least restrictive failover policy supported by all the services in the service policy. -
ddns_enabled-
true if the interface supports data_nfs or data_cifs services
false otherwise
fail_if_subnet_conflicts- true
Related ONTAP commands
network interface create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
ddns_enabled |
boolean |
Indicates whether or not dynamic DNS updates are enabled. Defaults to true if the interface supports "data_nfs" or "data_cifs" services, otherwise false. |
dns_zone |
string |
Fully qualified DNS zone name |
enabled |
boolean |
The administrative state of the interface. |
fail_if_subnet_conflicts |
boolean |
This command fails if the specified IP address falls within the address range of a named subnet. Set this value to false to use the specified IP address and to assign the subnet owning that address to the interface. |
ip |
IP information |
ipspace |
Either the UUID or name must be supplied on POST for cluster-scoped objects. |
location |
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node. For PATCH, set is_home to true to revert a LIF back to its home port. |
name |
string |
Interface name |
probe_port |
integer |
Probe port for Cloud load balancer |
rdma_protocols |
array[string] |
Supported RDMA offload protocols |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
service_policy |
services |
array[string] |
The services associated with the interface. |
state |
string |
The operational state of the interface. |
subnet |
A named subnet. Either UUID or name can be supplied on input. |
svm |
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST. |
uuid |
string |
The UUID that uniquely identifies the interface. |
vip |
boolean |
True for a VIP interface, whose location is announced via BGP. |
Example request
"dns_zone": "storage.company.com",
"ip": {
"address": "10.10.10.7",
"netmask": "24"
"ipspace": {
"name": "Default",
"location": {
"broadcast_domain": {
"name": "bd1",
"failover": "string",
"home_node": {
"name": "node1",
"home_port": {
"name": "e1b",
"node": {
"name": "node1"
"is_home": true
"name": "dataLif1",
"probe_port": 64001,
"rdma_protocols": [
"roce"
"scope": "string",
"service_policy": {
"name": "default-intercluster",
"services": [
"data_nfs"
"state": "string",
"subnet": {
"name": "subnet1",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
recommend |
Response properties specific to the LIF recommendation functionality. |
records |
array[ip_interface] |
"num_records": 1,
"recommend": {
"messages": [
"records": [
"ip": {
"netmask": "24"
"ipspace": {
"name": "Default",
"location": {
"name": "bd1",
"home_node": {
"name": "node1",
"home_port": {
"name": "e1b",
"node": {
"name": "node1"
"is_home": true
"name": "dataLif1",
"rdma_protocols": [
"roce"
"scope": "string",
"service_policy": {
"services": [
"data_nfs"
"state": "string",
"subnet": {
"name": "subnet1",
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1376656 |
Cluster interfaces must be in the same subnet. Verify the address and netmask are set to the correct values. |
1376663 |
All LIFs from a single DNS zone must be in the same SVM. |
1376663 |
Cannot add interface to DNS zone because all interfaces from a single DNS zone must be in the same SVM. |
1376963 |
Duplicate IP address. |
1376976 |
The specified port is not capable of hosting this LIF. |
1377583 |
Failed to create the interface because the broadcast domain of the specified subnet is different from the specified broadcast domain. |
1377666 |
Subnet does not have any addresses available. |
1966138 |
The same IP address may not be used for both a mgmt interface and a gateway address. |
1966140 |
An interface with the same name already exists. |
1966141 |
Invalid DNS zone name. |
1966142 |
Only data LIFs can be assigned a DNS zone. |
1966191 |
The interface could not be created because interface identifier creation failed. |
1966217 |
Invalid port on the node. |
1966267 |
IPv6 addresses must have a prefix length between 1 and 127. |
1966269 |
IPv4 addresses must have a prefix length between 1 and 32. |
1966270 |
Operation not support on SAN LIFs. |
1966300 |
The LIF name is too long. The maximum number of characters allowed for iSCSI and FC LIF names is 254. |
1966373 |
Failed to create interface because the home-port is not in the IPspace associated with the SVM. |
1966454 |
A port on the node is not a member of a broadcast domain. |
1966476 |
DNS Update is supported only on data LIFs. |
1966477 |
DNS Update is supported only on LIFs configured with the NFS or CIFS protocol. |
1966987 |
The Vserver Broadcast-Domain Home-Node and Home-Port combination is not valid. |
1967081 |
The specified SVM must exist in the specified IPspace. |
1967082 |
The specified ipspace.name does not match the IPspace name of ipspace.uuid. |
1967102 |
POST operation might have left configuration in an inconsistent state. Check the configuration. |
1967106 |
The specified location.home_port.name does not match the specified port name of location.home_port.uuid. |
1967107 |
The location.home_port.uuid specified is not valid. |
1967108 |
The specified location.home_node.name does not match the node name of location.home_node.uuid. |
1967109 |
The specified location.home_port.node.name does not match the node name of location.home_node.uuid. |
1967110 |
The specified location.home_port.node.name does not match location.home_node.name. |
1967111 |
Home node must be specified by at least one location.home_node, location.home_port, or location.broadcast_domain field. |
1967112 |
The specified location.home_node.name does not match the node name of location.home_port.uuid. |
1967120 |
The specified service_policy.name does not match the specified service policy name of service_policy.uuid. |
1967121 |
Invalid service_policy.uuid specified. |
1967122 |
The specified location.broadcast_domain.name does not match the specified broadcast domain name of location.broadcast_domain.uuid. |
1967123 |
The specified IPspace does not match the IPspace name of location.broadcast_domain.uuid. |
1967124 |
The location.broadcast_domain.uuid specified is not valid. |
1967127 |
svm.uuid or svm.name must be provided if scope is "svm". |
1967128 |
ipspace.uuid or ipspace.name must be provided if scope is "cluster". |
1967129 |
The specified location.home_port.uuid is not valid. |
1967130 |
The specified location.home_port.name is not valid. |
1967131 |
The specified location.home_port.uuid and location.home_port.name are not valid. |
1967135 |
The specified location.broadcast_domain.uuid is not valid. |
1967136 |
The specified location.broadcast_domain.name (and ipspace name) is not valid. |
1967137 |
The specified location.broadcast_domain.uuid and location.broadcast_domain.name (and IPspace name) are not valid. |
1967145 |
The specified location.failover is not valid. |
1967146 |
The specified svm.name is not valid. |
1967147 |
The specified svm.uuid is not valid. |
1967153 |
No suitable port exists on location.home_node to host the interface. |
1967154 |
Interfaces cannot be created on ports that are down. If a broadcast domain is specified, ensure that it contains at least one port that is operationally up. |
1967381 |
Post VIP interfaces requires an effective cluster version of 9.7 or later. |
1967382 |
VIP interfaces only reside in SVM scope. |
1967383 |
Neither location.home_port.uuid or location.home_port.name should be set with vip=true. |
1967384 |
Failed to create VIP interface because the home node does not have active BGP sessions to support Virtual IP (VIP) traffic. |
1967385 |
VIP interfaces with an IPv4 address must use ip.netmask=32. VIP interfaces with an IPv6 address must use ip.netmask=128. |
1967387 |
The specified IP address is in use by a subnet in this IPspace. |
1967391 |
Setting the DNS zone requires an effective cluster version of 9.9.1 or later. |
1967392 |
Setting the DDNS enable parameter requires an effective cluster version of 9.9.1 or later. |
1967394 |
Setting the probe port parameter requires an effective cluster version of 9.10.1 or later. |
1967396 |
The specified subnet.name does not match the subnet name of subnet.uuid. |
1967397 |
The specified subnet.uuid does not match any configured subnet."; |
1967398 |
Address must be specified by either ip.address and ip.netmask, or at least one subnet field, not both."; |
1967401 |
The specified subnet.name does not match any configured subnet. |
1967402 |
Data SVM cannot be specified with cluster scope. |
2621519 |
Invalid SVM name. The SVM name must begin with a letter or an underscore. The maximum supported length is 41 if the SVM type is "sync-source", otherwise it is 47. |
5373966 |
An iSCSI interface cannot be created in an SVM configured for NVMe. |
8847378 |
Cannot specify DNS zone when DNS updates are enabled for SVM |
53216540 |
LIFs on the specified SVM do not have a default service policy. |
53281018 |
Failover policy is not compatible with one or more services in service policy |
53281036 |
Setting the probe port parameter is not allowed on this platform. |
53281065 |
The service_policy does not exist in the SVM. |
53281073 |
IP address and netmask cannot be used because this represents a subnet address rather than a specific host address. |
53281086 |
LIF would exceed the maximum number of supported intercluster LIFs in IPspace. |
53281087 |
Cannot configure SAN LIF on SVM. |
53281092 |
Failed to create interface because the home-port does not support the specified protocol. |
53281104 |
The specified address is in use by the Service Processor |
53281106 |
Failed checking the cluster capabilities. |
53281114 |
The specified parameter is only supported on data SVMs. |
53281468 |
Failed to update external route tables for IP. |
53281680 |
Invalid value for the specified field. |
href |
string |
_links
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
broadcast_domain
Broadcast domain UUID along with a readable name.
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
home_node
name |
string |
uuid |
string |
node
name |
string |
Name of node on which the port is located. |
home_port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
name |
string |
node |
uuid |
string |
node
name |
string |
uuid |
string |
port
name |
string |
node |
uuid |
string |
location
auto_revert |
boolean |
broadcast_domain |
Broadcast domain UUID along with a readable name. |
failover |
string |
Policy that defines where an interface is permitted to move on failover. The policy named “default” implements the recommended best practice for NAS LIFs on the current platform and cluster, and was known as “system_defined” in the CLI. |
home_node |
home_port |
Port UUID along with readable names. Either the UUID or both names may be supplied on input. |
throughput
The rate of throughput bytes per second observed at the interface.
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Performance metric for write I/O operations. |
metric
The most recent sample of I/O metrics for the interface.
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the interface. |
timestamp |
string |
The timestamp of the performance data. |
service_policy
name |
string |
uuid |
string |
throughput_raw
Throughput bytes observed at the interface. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
statistics
The real time I/O statistics for the interface.
status |
string |
throughput_raw |
Throughput bytes observed at the interface. This can be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
ip_subnet_reference
name |
string |
The name of the subnet. If only the name is provided, the IPspace scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the subnet. |
svm
name |
string |
uuid |
string |
ip_interface
ddns_enabled |
boolean |
dns_zone |
string |
enabled |
boolean |
boolean |
ip |
IP information |
ipspace |
location |
name |
string |
Interface name |
probe_port |
integer |
rdma_protocols |
array[string] |
scope |
string |
service_policy |
services |
array[string] |
state |
string |
subnet |
svm |
uuid |
string |
vip |
boolean |
ip_interface_recommend_message
recommend
messages |
Messages describing the results of a LIF recommendation request. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
