Create a new named subnet
Creates a new named subnet to organize IP addresses within a broadcast domain. This helps you manage network configurations efficiently in your ONTAP environment.
HTTP method and endpoint
POST /network/ip/subnets
Introduced in
ONTAP 9.11
Required properties
name- Name of the subnet to create. -
broadcast_domain- Broadcast domain containing the subnet. -
ipspace- IPspace containing the subnet. Required only ifbroadcast_domain.uuidis not provided. -
subnet.address- IP address for the subnet. -
subnet.netmask- IP netmask of the subnet.
Recommended property values
Default property values
If not specified in POST, the following default property values are assigned:
gateway- no gateway -
ip_ranges- empty -
fail_if_lifs_conflict- true
Related ONTAP commands
network subnet create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
available_count |
integer |
available_ip_ranges |
array[ip_address_range] |
broadcast_domain |
The broadcast domain that the subnet is associated with. Either the UUID or name must be supplied on POST. |
fail_if_lifs_conflict |
boolean |
This action will fail if any existing interface is using an IP address in the ranges provided. Set this to false to associate any manually addressed interfaces with the subnet and allow the action to succeed. |
gateway |
string |
The IP address of the gateway for this subnet. |
ip_ranges |
ipspace |
The IPspace that the subnet is associated with. Either the UUID or name must be supplied on POST. |
name |
string |
Subnet name |
subnet |
IP information |
total_count |
integer |
used_count |
integer |
uuid |
string |
The UUID that uniquely identifies the subnet. |
Example request
"available_count": 0,
"available_ip_ranges": [
"end": "10.10.10.7",
"start": "10.10.10.7"
"broadcast_domain": {
"name": "bd1",
"gateway": "10.1.1.1",
"ip_ranges": [
"ipspace": {
"name": "exchange",
"name": "subnet1",
"subnet": {
"address": "10.10.10.7",
"netmask": "24"
"total_count": 0,
"used_count": 0,
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1377660 |
A subnet with the name already exists in the IPspace. |
1377661 |
Subnet in IPspace cannot use subnet address because that address is already used by another subnet in the same IPspace. |
1377662 |
The IP range address is not within the subnet in IPspace. |
1377663 |
The specified IP address range of subnet in IPspace contains an address already in use by a LIF. |
1377664 |
The specified IP address range of subnet in IPspace contains an address already in use by the Service Processor. |
1377673 |
The addresses provided must have the same address family. |
1967082 |
The specified ipspace.name does not match the IPspace name of specified ipspace.uuid |
53282568 |
The subnet.address must be specified together with subnet.netmask. |
53282569 |
The specified subnet.netmask is not valid. |
53282570 |
Each pair of ranges must have ip_ranges.start less than or equal to ip_ranges.end. |
53282571 |
The ip_ranges.start and ip_ranges.end fields must have the same number of items. |
53282573 |
Broadcast domain is a required parameter. The broadcast_domain.name and/or the broadcast_domain.uuid must be specified. |
53282574 |
The specified broadcast_domain and ipspace parameters do not match. |
53282575 |
Operation might have left configuration in an inconsistent state. Unable to set UUID for created entry. |
53282576 |
The specified ipspace.uuid is invalid. |
53282577 |
The specified broadcast_domain.uuid is invalid. |
53282578 |
The specified broadcast_domain.name does not match the IPspace name of specified broadcast_domain.uuid |
53282579 |
Missing the ipspace.name or ipspace.uuid parameter. |
href |
string |
_links
ip_address_range
IP address range
end |
string |
IPv4 or IPv6 address |
start |
string |
broadcast_domain
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
ip_info
IP information
address |
string |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
ip_subnet
available_count |
integer |
broadcast_domain |
boolean |
gateway |
string |
ip_ranges |
ipspace |
name |
string |
Subnet name |
subnet |
IP information |
total_count |
integer |
used_count |
integer |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
