REST API reference
Create a new named subnet
POST /network/ip/subnets
Introduced In: 9.11
Creates a new named subnet.
Required properties
  • name - Name of the subnet to create.
  • broadcast_domain - Broadcast domain containing the subnet.
  • ipspace - IPspace containing the subnet. Required only if broadcast_domain.uuid is not provided.
  • subnet.address - IP address for the subnet.
  • subnet.netmask - IP netmask of the subnet.
Default property values
If not specified in POST, the following default property values are assigned:
  • gateway - no gateway
  • ip_ranges - empty
  • fail_if_lifs_conflict - true
  • network subnet create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
available_count
integer
available_ip_ranges
array[ip_address_range]
broadcast_domain
broadcast_domain
The broadcast domain that the subnet is associated with. Either the UUID or name must be supplied on POST.
boolean
This action will fail if any existing interface is using an IP address in the ranges provided. Set this to false to associate any manually addressed interfaces with the subnet and allow the action to succeed.
gateway
string
The IP address of the gateway for this subnet.
ip_ranges
ipspace
ipspace
The IPspace that the subnet is associated with. Either the UUID or name must be supplied on POST.
name
string
Subnet name
subnet
ip_info
IP information
total_count
integer
used_count
integer
uuid
string
The UUID that uniquely identifies the subnet.
Example request
  "available_count": 0,
  "available_ip_ranges": [
      "end": "10.10.10.7",
      "start": "10.10.10.7"
  "broadcast_domain": {
    "name": "bd1",
  "gateway": "10.1.1.1",
  "ip_ranges": [
  "ipspace": {
    "name": "Default",
  "name": "subnet1",
  "subnet": {
    "address": "10.10.10.7",
    "netmask": "24"
  "total_count": 0,
  "used_count": 0,
Status: 201, Created
num_records
integer
Number of records
records
array[ip_subnet]
  "num_records": 1,
  "records": [
        "name": "bd1",
      "ip_ranges": [
      "ipspace": {
        "name": "Default",
      "name": "subnet1",
      "subnet": {
        "netmask": "24"
      "total_count": 0,
      "used_count": 0,
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1377658
Invalid gateway for subnet in IPspace.
1377659
Subnet would overlap with existing subnet named in IPspace.
1377660
A subnet with the name already exists in the IPspace.
1377661
Subnet in IPspace cannot use subnet address because that address is already used by another subnet in the same IPspace.
1377662
The IP range address is not within the subnet in IPspace.
1377663
The specified IP address range of subnet in IPspace contains an address already in use by a LIF.
1377664
The specified IP address range of subnet in IPspace contains an address already in use by the Service Processor.
1377673
The addresses provided must have the same address family.
1377675
The netmask of the interface did not match the netmask of the subnet.
1377681
Cannot update LIF associations for LIF. The broadcast domain of the LIF does not match the broadcast domain of the subnet.
1377682
IPv6 is not enabled in the cluster.
1966269
IPv4 Addresses must have a prefix length between 1 and 32.
1967082
The specified ipspace.name does not match the IPspace name of specified ipspace.uuid
53282568
The subnet.address must be specified together with subnet.netmask.
53282569
The specified subnet.netmask is not valid.
53282570
Each pair of ranges must have ip_ranges.start less than or equal to ip_ranges.end.
53282571
The ip_ranges.start and ip_ranges.end fields must have the same number of items.
53282573
Broadcast domain is a required parameter. The broadcast_domain.name and/or the broadcast_domain.uuid must be specified.
53282574
The specified broadcast_domain and ipspace parameters do not match.
53282575
Operation might have left configuration in an inconsistent state. Unable to set UUID for created entry.
53282576
The specified ipspace.uuid is invalid.
53282577
The specified broadcast_domain.uuid is invalid.
53282578
The specified broadcast_domain.name does not match the IPspace name of specified broadcast_domain.uuid
53282579
Missing the ipspace.name or ipspace.uuid parameter.
string
ip_address_range
IP address range
end
string
IPv4 or IPv6 address
start
string
broadcast_domain
name
string
Name of the broadcast domain, scoped to its IPspace
uuid
string
Broadcast domain UUID
ipspace
name
string
IPspace name
uuid
string
IPspace UUID
ip_info
IP information
address
string
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
ip_subnet
available_count
integer
available_ip_ranges
broadcast_domain
broadcast_domain
boolean
gateway
string
ip_ranges
ipspace
ipspace
name
string
Subnet name
subnet
ip_info
IP information
total_count
integer
used_count
integer
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
