REST API reference
Create a home directory search path
Creates a home directory search path to define the locations within the SVM namespace where home directories are searched for. This helps ensure that the correct directories are found when accessing CIFS shares.
HTTP method and endpoint
POST /protocols/cifs/home-directory/search-paths
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the home directory search path.
  • path - Path in the owning SVM namespace that is used to search for home directories.
  • cifs server home-directory search-path add
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
index
integer
The position in the list of paths that is searched to find the home directory of the CIFS client. Not available in POST.
path
string
The file system path that is searched to find the home directory of the CIFS client.
svm
svm
Example request
  "index": 0,
  "path": "/HomeDirectory/EngDomain",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records
records
array[cifs_search_path]
  "records": [
      "index": 0,
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
655551
Invalid home-directory search-path path
655462
The specified path is an invalid file-type
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
cifs_search_path
This is a list of CIFS home directory search paths. When a CIFS client connects to a home directory share, these paths are searched in the order indicated by the position field to find the home directory of the connected CIFS client.
index
integer
path
string
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
