Create a home directory search path
Creates a home directory search path to define where the system looks for user home directories within a specific SVM.
HTTP method and endpoint
POST /protocols/cifs/home-directory/search-paths
Introduced in
ONTAP 9.6
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the home directory search path. -
path- Path in the owning SVM namespace that is used to search for home directories.
Related ONTAP commands
cifs server home-directory search-path add
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
index |
integer |
The position in the list of paths that is searched to find the home directory of the CIFS client. Not available in POST. |
path |
string |
The file system path that is searched to find the home directory of the CIFS client. |
svm |
Example request
"index": 0,
"path": "/HomeDirectory/EngDomain",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[cifs_search_path] |
"num_records": 1,
"records": [
"index": 0,
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655551 |
Invalid home-directory search-path path |
655462 |
The specified path is an invalid file-type |
href |
string |
_links
svm
name |
string |
uuid |
string |
cifs_search_path
This is a list of CIFS home directory search paths. When a CIFS client connects to a home directory share, these paths are searched in the order indicated by the position field to find the home directory of the connected CIFS client.
index |
integer |
path |
string |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
