Create S3 server, users, and buckets configurations
Creates configurations for an S3 server, users, and buckets. Use this endpoint when you need to set up or modify S3 storage environments on an existing SVM.
HTTP method and endpoint
POST /protocols/s3/services
Introduced in
ONTAP 9.7
Usage notes
Creates an S3 server, users, and buckets configurations.
Important notes
Each SVM can have one S3 server configuration.
One or more buckets and users can also be created using this end-point.
If creating a user configuration fails, buckets are not created either and already created users are not saved.
If creating a bucket configuration fails, all buckets already created are saved with no new buckets created.
Required properties
svm.uuid- Existing SVM in which to create an S3 server configuration.
Recommended optional properties
enabled- Specifies the state of the server created. -
comment- Any information related to the server created.
Default property values
comment- "" -
enabled- true
Related ONTAP commands
vserver object-store-server create -
vserver object-store-server bucket create -
vserver object-store-server bucket policy statement create -
vserver object-store-server bucket policy-statement-condition create -
vserver object-store-server user create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
buckets |
array[s3_bucket] |
certificate |
Specifies the certificate that will be used for creating HTTPS connections to the S3 server. |
comment |
string |
Can contain any additional information about the server being created or modified. |
enabled |
boolean |
Specifies whether the S3 server being created or modified should be up or down. |
is_http_enabled |
boolean |
Specifies whether HTTP is enabled on the S3 server being created or modified. By default, HTTP is disabled on the S3 server. |
is_https_enabled |
boolean |
Specifies whether HTTPS is enabled on the S3 server being created or modified. By default, HTTPS is enabled on the S3 server. |
name |
string |
Specifies the name of the S3 server. A server name can contain 1 to 253 characters using only the following combination of characters':' 0-9, A-Z, a-z, ".", and "-". |
port |
integer |
Specifies the HTTP listener port for the S3 server. By default, HTTP is enabled on port 80. |
secure_port |
integer |
Specifies the HTTPS listener port for the S3 server. By default, HTTPS is enabled on port 443. |
svm |
users |
array[s3_user] |
Example request
"buckets": [
"aggregates": [
"name": "aggr1",
"audit_event_selector": {
"access": "string",
"permission": "string"
"comment": "S3 bucket.",
"constituents_per_aggregate": 4,
"logical_used_size": 0,
"name": "bucket1",
"policy": {
"statements": [
"actions": [
"GetObject",
"PutObject",
"DeleteObject",
"ListBucket"
"conditions": [
"delimiters": [
"max_keys": [
1000
"operator": "ip_address",
"prefixes": [
"pref"
"source_ips": [
"1.1.1.1",
"1.2.2.0/24"
"usernames": [
"user1"
"effect": "allow",
"principals": [
"user1",
"group/grp1"
"resources": [
"bucket1",
"bucket1/*"
"sid": "FullAccessToUser1"
"qos_policy": {
"max_throughput_iops": 10000,
"max_throughput_mbps": 500,
"min_throughput_iops": 2000,
"min_throughput_mbps": 500,
"name": "performance",
"role": "string",
"size": 1677721600,
"storage_service_level": "value",
"svm": {
"name": "svm1",
"uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
"versioning_state": "enabled",
"volume": {
"name": "volume1",
"certificate": {
"name": "cert1",
"comment": "S3 server",
"name": "Server-1",
"svm": {
"name": "svm1",
"users": [
"access_key": "Pz3SB54G2B_6dsXQPrA5HrTPcf478qoAW6_Xx6qyqZ948AgZ_7YfCf_9nO87YoZmskxx3cq41U2JAH2M3_fs321B4rkzS3a_oC5_8u7D8j_45N8OsBCBPWGD_1d_ccfq",
"comment": "S3 user",
"name": "user-1",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of Records |
records |
array[records] |
"records": [
"job": {
"uuid": "string"
"users": [
"name": "user-1",
"secret_key": "A20_tDhC_cux2C2BmtL45bXB_a_Q65c_96FsAcOdo14Az8V31jBKDTc0uCL62Bh559gPB8s9rrn0868QrF38_1dsV2u1_9H2tSf3qQ5xp9NT259C6z_GiZQ883Qn63X1"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621706 |
The specified SVM UUID is incorrect for the specified SVM name. |
92405789 |
The specified object server name contains invalid characters or not a fully qualified domain name. Valid characters for an object store server name are 0-9, A-Z, a-z, ".", and "-". |
92405790 |
Object store server names must have between 1 and 15 characters. |
92405839 |
Creating an object store server requires an effective cluster version of data ONTAP 9.7.0 or later. Upgrade all the nodes to 9.7.0 or later and try the operation again. |
92405853 |
Failed to create the object store server because Cloud Volumes ONTAP does not support object store servers. |
92405863 |
An error occurs when creating an S3 user or bucket. The reason for failure is detailed in the error message. Follow the error codes specified for the user or bucket endpoints to see details for the failure. |
92405884 |
An object store server can only be created on a data SVM. An object store server can also be created on a system SVM on a mixed platform cluster. |
href |
string |
self_link
_links
aggregates
name |
string |
uuid |
string |
Audit event selector allows you to specify access and permission types to audit.
access |
string |
Specifies read and write access types. |
permission |
string |
Specifies allow and deny permission types. |
encryption
enabled |
boolean |
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket. |
s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
delimiters |
array[string] |
An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified. |
max_keys |
array[integer] |
An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified. |
operator |
string |
Condition operator that is applied to the specified condition key. |
prefixes |
array[string] |
An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified. |
source_ips |
array[string] |
An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified. |
usernames |
array[string] |
An array of usernames that a current user in the context is evaluated against using the condition operators. |
s3_bucket_policy_statement
Specifies information about a single access permission.
actions |
array[string] |
conditions |
array[s3_bucket_policy_condition] |
Specifies bucket policy conditions. |
effect |
string |
Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access. |
principals |
array[string] |
resources |
array[string] |
sid |
string |
Specifies the statement identifier used to differentiate between statements. |
policy
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied.
statements |
array[s3_bucket_policy_statement] |
Specifies bucket access policy statement. |
destination
is_cloud |
boolean |
Specifies whether a bucket is protected within the Cloud. |
is_ontap |
boolean |
Specifies whether a bucket is protected within ONTAP.
protection_status
Specifies attributes of bucket protection.
destination |
is_protected |
boolean |
Specifies whether a bucket is a source and if it is protected within ONTAP and/or an external cloud.
qos_policy
Specifes "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached.
max_throughput_iops |
integer |
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
max_throughput_mbps |
integer |
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_iops |
integer |
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_mbps |
integer |
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
volume
Specifies the FlexGroup volume name and UUID where the bucket is hosted.
name |
string |
The name of the volume. |
uuid |
string |
s3_bucket
A bucket is a container of objects. Each bucket defines an object namespace. S3 requests specify objects using a bucket-name and object-name pair. An object resides within a bucket.
aggregates |
array[aggregates] |
A list of aggregates for FlexGroup volume constituents where the bucket is hosted. If this option is not specified, the bucket is auto-provisioned as a FlexGroup volume. |
audit_event_selector |
Audit event selector allows you to specify access and permission types to audit. |
comment |
string |
Can contain any additional information about the bucket being created or modified. |
constituents_per_aggregate |
integer |
Specifies the number of constituents or FlexVol volumes per aggregate. A FlexGroup volume consisting of all such constituents across all specified aggregates is created. This option is used along with the aggregates option and cannot be used independently. |
encryption |
logical_used_size |
integer |
Specifies the bucket logical used size up to this point. |
name |
string |
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-". |
policy |
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied. |
protection_status |
Specifies attributes of bucket protection. |
qos_policy |
Specifes "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached. |
role |
string |
Specifies the role of the bucket. |
size |
integer |
Specifies the bucket size in bytes; ranges from 80MB to 64TB. |
storage_service_level |
string |
Specifies the storage service level of the FlexGroup volume on which the bucket should be created. Valid values are "value", "performance" or "extreme". |
svm |
uuid |
string |
Specifies the unique identifier of the bucket. |
versioning_state |
string |
Specifies the versioning state of the bucket. Valid values are "disabled", "enabled" or "suspended". Note that the versioning state cannot be modified to 'disabled' from any other state. |
volume |
Specifies the FlexGroup volume name and UUID where the bucket is hosted. |
certificate
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
metric
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
statistics
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
s3_user
This is a container of S3 users.
access_key |
string |
Specifies the access key for the user. |
comment |
string |
Can contain any additional information about the user being created or modified. |
name |
string |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
svm |
s3_service
Specifies the S3 server configuration.
buckets |
array[s3_bucket] |
certificate |
comment |
string |
enabled |
boolean |
is_http_enabled |
boolean |
is_https_enabled |
boolean |
name |
string |
port |
integer |
secure_port |
integer |
svm |
users |
array[s3_user] |
collection_links
job_link
uuid |
string |
s3_service_user_post_response
access_key |
string |
name |
string |
The name of the user. |
secret_key |
string |
Specifies the secret key for the user. |
records
job |
users |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
