REST API reference
Create S3 server, users, and buckets configurations
Creates configurations for an S3 server, users, and buckets within a Storage Virtual Machine (SVM). You use this endpoint when setting up or managing S3 services, ensuring all necessary components are configured together.
HTTP method and endpoint
POST /protocols/s3/services
Introduced in
ONTAP 9.7
Usage notes
Creates an S3 server, users, and buckets configurations.
Important notes
  • Each SVM can have one S3 server configuration.
  • One or more buckets and users can also be created using this end-point.
  • If creating a user configuration fails, buckets are not created either and already created users are not saved.
  • If creating a bucket configuration fails, all buckets already created are saved with no new buckets created.
Required properties
  • svm.uuid - Existing SVM in which to create an S3 server configuration.
  • enabled - Specifies the state of the server created.
  • comment - Any information related to the server created.
Default property values
  • comment - ""
  • enabled - true
  • vserver object-store-server create
  • vserver object-store-server bucket create
  • vserver object-store-server bucket policy statement create
  • vserver object-store-server bucket policy-statement-condition create
  • vserver object-store-server bucket cors-rule create
  • vserver object-store-server user create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
buckets
array[s3_bucket]
This field cannot be specified in a PATCH method.
certificate
certificate
Specifies the certificate that will be used for creating HTTPS connections to the S3 server.
comment
string
Can contain any additional information about the server being created or modified.
default_unix_user
string
Specifies the default UNIX user for NAS Access.
default_win_user
string
Specifies the default Windows user for NAS Access.
enabled
boolean
Specifies whether the S3 server being created or modified should be up or down.
is_http_enabled
boolean
Specifies whether HTTP is enabled on the S3 server being created or modified. By default, HTTP is disabled on the S3 server.
is_https_enabled
boolean
Specifies whether HTTPS is enabled on the S3 server being created or modified. By default, HTTPS is enabled on the S3 server.
max_key_time_to_live
string
Indicates the maximum time period that an S3 user can specify for the 'key_time_to_live' property.
  • Valid format is: 'PnDTnHnMnS|PnW'. For example, P2DT6H3M10S specifies a time period of 2 days, 6 hours, 3 minutes, and 10 seconds.
  • If no value is specified for this property or the value specified is '0' seconds, then a user can specify any valid value.
max_lock_retention_period
string
Specifies the maximum value that can be set as the retention period for an object in a bucket with locking enabled. The value for this property can be in years or days, not both. The value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "PY" and "PD" respectively, for example "P10Y" represents a duration of 10 years.
min_lock_retention_period
string
Specifies the minimum value that can be set as the retention period for an object in a bucket with locking enabled. The value for this property can be in years or days, not both. The value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "PY" and "PD" respectively, for example "P10Y" represents a duration of 10 years.
name
string
Specifies the name of the S3 server. A server name can contain 3 to 253 characters using only the following combination of characters':' 0-9, A-Z, a-z, ".", and "-".
port
integer
Specifies the HTTP listener port for the S3 server. By default, HTTP is enabled on port 80. Valid values range from 1 to 65535.
secure_port
integer
Specifies the HTTPS listener port for the S3 server. By default, HTTPS is enabled on port 443. Valid values range from 1 to 65535.
svm
svm
users
array[s3_user]
Example request
  "buckets": [
      "aggregates": [
          "name": "aggr1",
      "audit_event_selector": {
        "access": "string",
        "permission": "string"
      "comment": "S3 bucket.",
      "constituents_per_aggregate": 4,
      "cors": {
        "rules": [
            "allowed_headers": [
              "x-amz-request-id"
            "allowed_methods": [
              "PUT",
              "DELETE"
            "allowed_origins": [
              "http://www.example.com"
            "expose_headers": [
              "x-amz-date"
            "id": "string",
            "max_age_seconds": 1024
      "lifecycle_management": {
        "rules": [
            "bucket_name": "bucket1",
            "expiration": {
              "object_age_days": 100,
              "object_expiry_date": "2039-09-22 20:00:00 -0400"
            "name": "string",
            "object_filter": {
              "prefix": "/logs",
              "size_greater_than": 10240,
              "size_less_than": 10485760,
              "tags": [
                "project1=projA",
                "project2=projB"
            "svm": {
              "name": "svm1",
            "uuid": "414b29a1-3b26-11e9-bd58-0050568ea055"
      "logical_used_size": 0,
      "name": "bucket1",
      "nas_path": "/",
      "policy": {
        "statements": [
            "actions": [
              "GetObject",
              "PutObject",
              "DeleteObject",
              "ListBucket"
            "conditions": [
                "delimiters": [
                "max_keys": [
                  1000
                "operator": "ip_address",
                "prefixes": [
                  "pref"
                "source_ips": [
                  "1.1.1.1",
                  "1.2.2.0/24"
                "usernames": [
                  "user1"
            "effect": "allow",
            "principals": [
              "user1",
              "group/grp1",
              "nasgroup/group1"
            "resources": [
              "bucket1",
              "bucket1/*"
            "sid": "FullAccessToUser1"
      "qos_policy": {
        "max_throughput": [
          "900KB/s",
          "500MB/s",
          "120GB/s",
          "5000IOPS",
          "5000IOPS,500KB/s",
          "2500IOPS,100MB/s",
          "1000IOPS,25MB/s"
        "max_throughput_iops": 10000,
        "max_throughput_mbps": 500,
        "min_throughput": [
          "900KB/s",
          "500MB/s",
          "120GB/s",
          "5000IOPS",
          "5000IOPS,500KB/s",
          "2500IOPS,100MB/s",
          "1000IOPS,25MB/s"
        "min_throughput_iops": 2000,
        "min_throughput_mbps": 500,
        "name": "performance",
      "retention": {
        "default_period": "P10Y",
        "mode": "governance"
      "role": "string",
      "size": 1677721600,
      "snapshot_policy": {
        "name": "default-1weekly",
        "uuid": "3675af31-431c-12fa-114a-20675afebc12"
      "storage_service_level": "value",
      "svm": {
        "name": "svm1",
      "type": "s3",
      "uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
      "versioning_state": "enabled",
      "volume": {
        "name": "volume1",
  "certificate": {
    "name": "string",
  "comment": "S3 server",
  "default_unix_user": "string",
  "default_win_user": "string",
  "max_key_time_to_live": "PT6H3M",
  "max_lock_retention_period": "P10Y",
  "min_lock_retention_period": "P10Y",
  "name": "Server-1",
  "port": 80,
  "secure_port": 443,
  "svm": {
    "name": "svm1",
  "users": [
      "access_key": "<AWS-ACCESS-KEY-ID>",
      "comment": "S3 user",
      "key_expiry_time": "2023-12-31 19:00:00 -0500",
      "key_time_to_live": "PT6H3M",
      "name": "user-1",
      "secret_key": "<AWS-SECRET-ACCESS-KEY>",
      "svm": {
        "name": "svm1",
Status: 201, Created
num_records
integer
Number of Records
records
array[records]
  "num_records": 1,
  "records": [
      "job": {
        "uuid": "string"
      "users": [
          "name": "user-1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1115127
The cluster lacks a valid S3 license.
2621706
The specified "{svm.uuid}" and "{svm.name}" refer to different SVMs.
92405789
The specified object server name contains invalid characters or not a fully qualified domain name. Valid characters for an object store server name are 0-9, A-Z, a-z, ".", and "-".
92405790
Object store server names must have between 3 and 253 characters.
92405839
Creating an object store server requires an effective cluster version of data ONTAP 9.7.0 or later. Upgrade all the nodes to 9.7.0 or later and try the operation again.
92405853
Failed to create the object store server because Cloud Volumes ONTAP does not support object store servers.
92405863
An error occurs when creating an S3 user or bucket. The reason for failure is detailed in the error message. Follow the error codes specified for the user or bucket endpoints to see details for the failure.
92405863
Failed to create bucket "{bucket name}". Reason: "Failed to create bucket "{bucket name}" for SVM "{svm.name}". Reason: Bucket name "{bucket name}" contains invalid characters or invalid character combinations. Valid characters for a bucket name are 0-9, a-z, ".", and "-". Invalid character combinations are ".-", "-.", and "..". ". Resolve all the issues and retry the operation.
92405863
Failed to create bucket "{bucket name}". Reason: "Failed to create bucket "{bucket name}" for SVM "{svm.name}". Reason: Invalid QoS policy group specified "{qos policy}". The specified QoS policy group has a min-throughput value set, and the workload being assigned resides on a platform that does not support min-throughput or the cluster is in a mixed version state and the effective cluster version of ONTAP does not support min-throughput on this platform. Resolve all the issues and retry the operation.
92405863
Failed to create bucket "{bucket name}". Reason: "User(s) "{user name(s)}" specified in the principal list do not exist for SVM "{svm.name}". Use the "object-store-server user create" command to create a user.". Resolve all the issues and retry the operation.
92405863
Failed to create user "{user name}". Reason: "SVM "Cluster" is not a data SVM. Specify a data SVM.". Resolve all the issues and retry the operation.
92405884
An object store server can only be created on a data SVM. An object store server can also be created on a system SVM on a mixed platform cluster.
92405903
Failed to configure HTTPS on an object store server for SVM "{svm.name}". Reason: {Reason of failure}.
92405900
Certificate not found for SVM "{svm.name}".
92405917
The specified certificate name and UUID do not refer to the same certificate.
92406020
Only certificates of type "server" are supported.
92406044
Failed to set default UNIX user for SVM "{svm.name}". Reason: UNIX user can only be created on a Data SVM.
92406071
S3 protocol is not present in the allowed protocol list for SVM "{svm.name}".
92406196
The specified value for the "key_time_to_live" field cannot be greater than the maximum limit specified for the "max_key_time_to_live" field in the object store server.
92406197
Object store user "user-2" must have a non-zero value for the "key_time_to_live" field because the maximum limit specified for the "max_key_time_to_live" field in the object store server is not zero.
92406230
The value for "retention.default_period" parameter for object store bucket "" cannot be greater than the maximum lock retention period set in the object store server for SVM "". Check the maximum allowed lock retention period present in the object store server for SVM "" and try the operation again. //end row //start row
92406231 //end row //start row
One or more object store buckets exist with a default retention period greater than the "max_lock_retention_period" specified. Check the default retention period set for each bucket in the specified SVM and try the operation again. //end row //start row
92406236 //end row //start row
The value for "retention.default_period" parameter for object store bucket "" cannot be less than the minimum lock retention period set in the object store server for SVM "". Check the minimum allowed lock retention period present in the object store server for SVM "" and try the operation again. //end row //start row
92406237 //end row //start row
One or more object store buckets exist with a default retention period less than the "min_lock_retention_period" specified. Check the default retention period set for each bucket in the specified SVM and try the operation again. //end row //start row
92406238 //end row //start row
The value for the "min_lock_retention_period" parameter cannot be greater than the "max_lock_retention_period" parameter for the object store server for SVM "vs1". //end row //start row
92406217 //end row //start row
The specified "-allowed-headers" in not valid because it contains more than one wild card ("*") character.; //end row //start row
92406224 //end row //start row
A Cross-Origin Resource Sharing (CORS) rule must have an origin and HTTP method specified.; //end row //start row
92406211 //end row //start row
The specified method "DONE" is not valid. Valid methods are GET, PUT, DELETE, HEAD, and POST.; //end row //start row
92405863 //end row //start row
Failed to create CORS rules for bucket "bb1". Reason: "Field "index" cannot be specified for this operation.". Resolve all the issues and retry the operation.; //end row //start row
92406228 //end row //start row
Cannot exceed the maximum limit of 100 Cross-Origin Resource Sharing (CORS) rules per S3 bucket "" in SVM "".; //end row
=== //end table
== Definitions
[.api-def-first-level] .See Definitions [%collapsible%closed] ==== [#href] [.api-collapsible-fifth-title] href
[cols=3*,options=header]
|Name |Type |Description
|href |string a|
[#self_link] [.api-collapsible-fifth-title] self_link [#_links] [.api-collapsible-fifth-title] _links [#aggregates] [.api-collapsible-fifth-title] aggregates
Aggregate
|name |string a|
|uuid |string a|
[#audit_event_selector] [.api-collapsible-fifth-title] audit_event_selector
Audit event selector allows you to specify access and permission types to audit.
|access |string a|Specifies read and write access types.
|permission |string a|Specifies allow and deny permission types.
[#rules] [.api-collapsible-fifth-title] rules
Information about the CORS rule of an S3 bucket.
|allowed_headers |array[string] a|An array of HTTP headers allowed in the cross-origin requests.
|allowed_methods |array[string] a|An array of HTTP methods allowed in the cross-origin requests.
|allowed_origins |array[string] a|List of origins from where a cross-origin request is allowed to originate from for the S3 bucket.
|expose_headers |array[string] a|List of extra headers sent in the response that customers can access from their applications.
|id |string a|Bucket CORS rule identifier. The length of the name can range from 0 to 256 characters.
|max_age_seconds |integer a|The time in seconds for your browser to cache the preflight response for the specified resource.
[#cors] [.api-collapsible-fifth-title] cors
Cross-origin resource sharing (CORS) specifies an object associated with a bucket. The CORS configuration enables the bucket to service the cross-origin requests. A request might typically come from an origin with a domain that is different to that of the bucket. By configuring a CORS rule, you can define a combination of allowed origins, HTTP headers and methods that a bucket can use to filter out the cross-origin requests that it can service successfully.
|rules |array[rules] a|Specifies an object store bucket CORS rule.
[#encryption] [.api-collapsible-fifth-title] encryption
|enabled |boolean a|Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket. This field cannot be specified in a POST method.
[#abort_incomplete_multipart_upload] [.api-collapsible-fifth-title] abort_incomplete_multipart_upload
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags.
|after_initiation_days |integer a|Number of days of initiation after which uploads can be aborted.
[#expiration] [.api-collapsible-fifth-title] expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
|expired_object_delete_marker |boolean a|Cleanup object delete markers.
|object_age_days |integer a|Number of days since creation after which objects can be deleted. This cannot be used along with object_expiry_date.
|object_expiry_date |string a|Specific date from when objects can expire. This cannot be used with object_age_days.
[#non_current_version_expiration] [.api-collapsible-fifth-title] non_current_version_expiration
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
|new_non_current_versions |integer a|Number of latest non-current versions to be retained.
|non_current_days |integer a|Number of days after which non-current versions can be deleted.
[#object_filter] [.api-collapsible-fifth-title] object_filter
Specifies a way to filter objects within a bucket.
|prefix |string a|A prefix that is matched against object-names within a bucket.
|size_greater_than |integer a|Size of the object greater than specified for which the corresponding lifecycle rule is to be applied.
|size_less_than |integer a|Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied.
|tags |array[string] a|An array of key-value paired tags of the form or <tag=value>.
[#svm] [.api-collapsible-fifth-title] svm
Specifies the name of the SVM where this bucket exists.
|name |string a|The name of the SVM. This field cannot be specified in a PATCH method.
|uuid |string a|The unique identifier of the SVM. This field cannot be specified in a PATCH method.
Information about the lifecycle management rule of a bucket.
|abort_incomplete_multipart_upload |abort_incomplete_multipart_upload a|Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags.
|bucket_name |string a|Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-".
|enabled |boolean a|Specifies whether or not the associated rule is enabled.
|expiration |expiration a|Specifies a way to perform expiration action on filtered objects within a bucket.
|name |string a|Bucket lifecycle management rule identifier. The length of the name can range from 0 to 256 characters.
|non_current_version_expiration |non_current_version_expiration a|Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
|object_filter |object_filter a|Specifies a way to filter objects within a bucket.
|svm |svm a|Specifies the name of the SVM where this bucket exists.
|uuid |string a|Specifies the unique identifier of the bucket.
[#lifecycle_management] [.api-collapsible-fifth-title] lifecycle_management
Lifecycle management is implemented as an object associated with a bucket. It defines rules to be applied against objects within a bucket. These rules are applied in the background and can delete objects.
|rules |array[rules] a|Specifies an object store lifecycle management policy.
[#s3_bucket_policy_condition] [.api-collapsible-fifth-title] s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
|delimiters |array[string] a|An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified.
|max_keys |array[integer] a|An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified.
|operator |string a|Condition operator that is applied to the specified condition key.
|prefixes |array[string] a|An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified.
|source_ips |array[string] a|An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified.
|usernames |array[string] a|An array of usernames that a current user in the context is evaluated against using the condition operators.
[#s3_bucket_policy_statement] [.api-collapsible-fifth-title] s3_bucket_policy_statement
Specifies information about a single access permission.
|actions |array[string] a|
|conditions |array[s3_bucket_policy_condition] a|Specifies bucket policy conditions.
|effect |string a|Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access.
|principals |array[string] a|
|resources |array[string] a|
|sid |string a|Specifies the statement identifier used to differentiate between statements. The sid length can range from 1 to 256 characters and can only contain the following combination of characters 0-9, A-Z, and a-z. Special characters are not valid.
[#policy] [.api-collapsible-fifth-title] policy
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied.
|statements |array[s3_bucket_policy_statement] a|Specifies bucket access policy statement.
[#destination] [.api-collapsible-fifth-title] destination
|is_cloud |boolean a|Specifies whether a bucket is protected within the Cloud. This field cannot be specified using a POST method.
|is_external_cloud |boolean a|Specifies whether a bucket is protected on external Cloud providers. This field cannot be specified using a POST method.
|is_ontap |boolean a|Specifies whether a bucket is protected within ONTAP. This field cannot be specified using a POST method.
  • Default value: 1
  • readOnly: 1
  • Introduced in: 9.10
  • x-nullable: true
[#protection_status] [.api-collapsible-fifth-title] protection_status
Specifies attributes of bucket protection.
|destination |destination a|
|is_protected |boolean a|Specifies whether a bucket is a source and if it is protected within ONTAP and/or an external cloud. This field cannot be specified using a POST method.
  • Default value: 1
  • readOnly: 1
  • x-nullable: true
[#qos_policy] [.api-collapsible-fifth-title] qos_policy
Specifies "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached.
|max_throughput |string a|Specifies the maximum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either max_throughput_mbps or max_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1.
|max_throughput_iops |integer a|Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH.
|max_throughput_mbps |integer a|Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH.
|min_throughput |string a|Specifies the minimum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none.Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either min_throughput_mbps or min_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1.
|min_throughput_iops |integer a|Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when min_throughput is set during POST or PATCH.
|min_throughput_mbps |integer a|Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.This cannot be set when min_throughput is set during POST or PATCH.
|name |string a|The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
|uuid |string a|The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
[#retention] [.api-collapsible-fifth-title] retention
Specifies the retention mode and default retention period configured on the bucket.
|default_period |string a|Specifies the default retention period that is applied to objects while committing them to the WORM state without an associated retention period. The retention period can be in years, or days. The retention period value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "PY" and "PD" respectively, for example "P10Y" represents a duration of 10 years. The period string must contain only a single time element that is, either years, or days. A duration which combines different periods is not supported, for example "P1Y10D" is not supported.
|mode |string a|The lock mode of the bucket. compliance ‐ A SnapLock Compliance (SLC) bucket provides the highest level of WORM protection and an administrator cannot destroy a compliance bucket if it contains unexpired WORM objects. governance ‐ An administrator can delete a Governance bucket. no_lock ‐ Indicates the bucket does not support object locking.
[#snapshot_policy] [.api-collapsible-fifth-title] snapshot_policy
Specifies the bucket snapshot policy.
|name |string a|Specifies the name of the snapshot policy.
|uuid |string a|Specifies the unique identifier of the snapshot policy.
[#volume] [.api-collapsible-fifth-title] volume
Specifies the FlexGroup volume name and UUID where the bucket is hosted.
|name |string a|The name of the volume. This field cannot be specified in a PATCH method.
|uuid |string a|Unique identifier for the volume. This corresponds to the instance-uuid that is exposed in the CLI and ONTAPI. It does not change due to a volume move.
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
[#s3_bucket] [.api-collapsible-fifth-title] s3_bucket
A bucket is a container of objects. Each bucket defines an object namespace. S3 requests specify objects using a bucket-name and object-name pair. An object resides within a bucket.
|aggregates |array[aggregates] a|A list of aggregates for FlexGroup volume constituents where the bucket is hosted. If this option is not specified, the bucket is auto-provisioned as a FlexGroup volume.
|allowed |boolean a|If this is set to true, an SVM administrator can manage the S3 service. If it is false, only the cluster administrator can manage the service. This field cannot be specified in a POST method.
|audit_event_selector |audit_event_selector a|Audit event selector allows you to specify access and permission types to audit.
|comment |string a|Can contain any additional information about the bucket being created or modified.
|constituents_per_aggregate |integer a|Specifies the number of constituents or FlexVol volumes per aggregate. A FlexGroup volume consisting of all such constituents across all specified aggregates is created. This option is used along with the aggregates option and cannot be used independently.
|cors |cors a|Cross-origin resource sharing (CORS) specifies an object associated with a bucket. The CORS configuration enables the bucket to service the cross-origin requests. A request might typically come from an origin with a domain that is different to that of the bucket. By configuring a CORS rule, you can define a combination of allowed origins, HTTP headers and methods that a bucket can use to filter out the cross-origin requests that it can service successfully.
|encryption |encryption a|
|is_consistent_etag |boolean a|Specifies whether the NAS bucket returns a consistent ETag across different S3 requests.
|is_nas_path_mutable |boolean a|Specifies whether the NAS bucket mapping or association with a NAS volume can change according to the changes in the NAS volume junction-path due to volume operations like mount and unmount and therefore the NAS bucket will have access to any path in a NAS volume that matches the specified nas-path. Or is immutable and therefore the NAS bucket will always have access to the same nas-path that was specified during bucket creation even if the volume junction-path has undergone changes after the bucket creation.
|lifecycle_management |lifecycle_management a|Lifecycle management is implemented as an object associated with a bucket. It defines rules to be applied against objects within a bucket. These rules are applied in the background and can delete objects.
|logical_used_size |integer a|Specifies the bucket logical used size up to this point. This field cannot be specified using a POST or PATCH method.
|nas_path |string a|Specifies the NAS path to which the nas bucket corresponds to.
|policy |policy a|A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied.
|protection_status |protection_status a|Specifies attributes of bucket protection.
|qos_policy |qos_policy a|Specifies "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached.
|retention |retention a|Specifies the retention mode and default retention period configured on the bucket.
|role |string a|Specifies the role of the bucket. This field cannot be specified using a POST method.
|size |integer a|Specifies the bucket size in bytes; ranges from 190MB to 62PB.
|snapshot_policy |snapshot_policy a|Specifies the bucket snapshot policy.
|storage_service_level |string a|Specifies the storage service level of the FlexGroup volume on which the bucket should be created. Valid values are "value", "performance" or "extreme".
|svm |svm a|SVM, applies only to SVM-scoped objects.
|type |string a|Specifies the bucket type. Valid values are "s3"and "nas".
|use_mirrored_aggregates |boolean a|Specifies whether mirrored aggregates are selected when provisioning a FlexGroup. Only mirrored aggregates are used if this parameter is set to "true" and only unmirrored aggregates are used if this parameter is set to "false". The default value is "true" for a MetroCluster configuration and is "false" for a non-MetroCluster configuration.
|versioning_state |string a|Specifies the versioning state of the bucket. Valid values are "disabled", "enabled" or "suspended". Note that the versioning state cannot be modified to 'disabled' from any other state.
|volume |volume a|Specifies the FlexGroup volume name and UUID where the bucket is hosted.
[#certificate] [.api-collapsible-fifth-title] certificate
|name |string a|Certificate name
|uuid |string a|Certificate UUID
[#iops] [.api-collapsible-fifth-title] iops
|other |integer a|Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
|read |integer a|Performance metric for read I/O operations.
|total |integer a|Performance metric aggregated over all types of I/O operations.
|write |integer a|Performance metric for write I/O operations.
[#latency] [.api-collapsible-fifth-title] latency
[#throughput] [.api-collapsible-fifth-title] throughput
[#metric] [.api-collapsible-fifth-title] metric
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
|duration |string a|The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
|iops |iops a|The rate of I/O operations observed at the storage object.
|latency |latency a|The round trip latency in microseconds observed at the storage object.
|status |string a|Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
|throughput |throughput a|The rate of throughput bytes per second observed at the storage object.
|timestamp |string a|The timestamp of the performance data.
[#iops_raw] [.api-collapsible-fifth-title] iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
[#latency_raw] [.api-collapsible-fifth-title] latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
[#throughput_raw] [.api-collapsible-fifth-title] throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
[#statistics] [.api-collapsible-fifth-title] statistics
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
|iops_raw |iops_raw a|The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
|latency_raw |latency_raw a|The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
|status |string a|Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
|throughput_raw |throughput_raw a|Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
[#s3_user] [.api-collapsible-fifth-title] s3_user
This is a container of S3 users.
|access_key |string a|Specifies the access key for the user.
|comment |string a|Can contain any additional information about the user being created or modified.
|key_expiry_time |string a|Specifies the date and time after which keys expire and are no longer valid.
|key_time_to_live |string a|Indicates the time period from when this parameter is specified:
  • when creating or modifying a user or
  • when the user keys were last regenerated, after which the user keys expire and are no longer valid.
  • Valid format is: 'PnDTnHnMnS\|PnW'. For example, P2DT6H3M10S specifies a time period of 2 days, 6 hours, 3 minutes, and 10 seconds.
  • If the value specified is '0' seconds, then the keys won't expire.
|name |string a|Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
|secret_key |string a|Specifies the secret key for the user.
[#s3_service] [.api-collapsible-fifth-title] s3_service
Specifies the S3 server configuration.
|buckets |array[s3_bucket] a|This field cannot be specified in a PATCH method.
|certificate |certificate a|Specifies the certificate that will be used for creating HTTPS connections to the S3 server.
|comment |string a|Can contain any additional information about the server being created or modified.
|default_unix_user |string a|Specifies the default UNIX user for NAS Access.
|default_win_user |string a|Specifies the default Windows user for NAS Access.
|enabled |boolean a|Specifies whether the S3 server being created or modified should be up or down.
|is_http_enabled |boolean a|Specifies whether HTTP is enabled on the S3 server being created or modified. By default, HTTP is disabled on the S3 server.
|is_https_enabled |boolean a|Specifies whether HTTPS is enabled on the S3 server being created or modified. By default, HTTPS is enabled on the S3 server.
|max_key_time_to_live |string a|Indicates the maximum time period that an S3 user can specify for the 'key_time_to_live' property.
|max_lock_retention_period |string a|Specifies the maximum value that can be set as the retention period for an object in a bucket with locking enabled. The value for this property can be in years or days, not both. The value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "PY" and "PD" respectively, for example "P10Y" represents a duration of 10 years.
|min_lock_retention_period |string a|Specifies the minimum value that can be set as the retention period for an object in a bucket with locking enabled. The value for this property can be in years or days, not both. The value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "PY" and "PD" respectively, for example "P10Y" represents a duration of 10 years.
|name |string a|Specifies the name of the S3 server. A server name can contain 3 to 253 characters using only the following combination of characters':' 0-9, A-Z, a-z, ".", and "-".
|port |integer a|Specifies the HTTP listener port for the S3 server. By default, HTTP is enabled on port 80. Valid values range from 1 to 65535.
|secure_port |integer a|Specifies the HTTPS listener port for the S3 server. By default, HTTPS is enabled on port 443. Valid values range from 1 to 65535.
|users |array[s3_user] a|This field cannot be specified in a PATCH method.
[#collection_links] [.api-collapsible-fifth-title] collection_links [#job_link] [.api-collapsible-fifth-title] job_link
|uuid |string a|The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
[#s3_service_user_post_response] [.api-collapsible-fifth-title] s3_service_user_post_response
|key_expiry_time |string a|Specifies the date and time after which the keys expire and are no longer valid.
|name |string a|The name of the user.
[#warning] [.api-collapsible-fifth-title] warning
Specifies a warning message sent from the S3 server during a POST or PATCH operation.
|code |integer a|Warning code of the warning encountered.
|message |string a|Details of the warning sent from the S3 server.
[#records] [.api-collapsible-fifth-title] records
|job |job_link a|
|users |array[s3_service_user_post_response] a|
[#error_arguments] [.api-collapsible-fifth-title] error_arguments
|code |string a|Argument code
|message |string a|Message argument
[#returned_error] [.api-collapsible-fifth-title] returned_error
|arguments |array[error_arguments] a|Message arguments
|code |string a|Error code
|message |string a|Error message
|target |string a|The target parameter that caused the error.
