Create a Vscan scanner-pool configuration for an SVM
Creates a Vscan scanner-pool configuration for a specified SVM. This configuration allows you to define servers and privileged users required for scanning operations within the SVM environment.
HTTP method and endpoint
POST /protocols/vscan/{svm.uuid}/scanner-pools
Introduced in
ONTAP 9.6
Usage notes
You can create a scanner-pool with all fields specified or only mandatory fields specified.
Important notes:
A scanner-pool must have servers and privileged users specified.
If the role or cluster is not specified, the scanner-pool is created on the local cluster with the role set as primary. *`Only one of the fields cluster-uuid or cluster-name is required.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the Vscan configuration. -
name- Scanner-pool name. -
privileged_users- List of privileged users. -
servers- List of server IP addresses or FQDNs.
Recommended optional properties
role- Setting a role for a scanner-pool is recommended. -
cluster- Passing the cluster name or UUID (or both) in a multi-cluster environment is recommended.
Default property values
If not specified in POST, the following default property values are assigned:
role- primary -
cluster.name- Local cluster name. -
cluster.uuid- Local cluster UUID.
Related ONTAP commands
vserver vscan scanner-pool create -
vserver vscan scanner-pool apply-policy -
vserver vscan scanner-pool privileged-users add -
vserver vscan scanner-pool servers add
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
cluster |
name |
string |
Specifies the name of the scanner pool. Scanner pool name can be up to 256 characters long and is a string that can only contain any combination of ASCII-range alphanumeric characters a-z, A-Z, 0-9), "_", "-" and ".". |
privileged_users |
array[string] |
Specifies a list of privileged users. A valid form of privileged user-name is "domain-name\user-name". Privileged user-names are stored and treated as case-insensitive strings. Virus scanners must use one of the registered privileged users for connecting to clustered Data ONTAP for exchanging virus-scanning protocol messages and to access file for scanning, remedying and quarantining operations.
role |
string |
Specifies the role of the scanner pool. The possible values are:
servers |
array[string] |
Specifies a list of IP addresses or FQDN for each Vscan server host names which are allowed to connect to clustered ONTAP.
svm |
Example request
"cluster": {
"name": "cluster1",
"name": "scanner-1",
"privileged_users": [
"cifs\\u1",
"cifs\\u2"
"role": "string",
"servers": [
"1.1.1.1",
"10.72.204.27",
"vmwin204-27.fsct.nb"
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[vscan_scanner_pool] |
"records": [
"cluster": {
"name": "cluster1",
"cifs\\u1",
"cifs\\u2"
"role": "string",
"servers": [
"1.1.1.1",
"10.72.204.27",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10027086 |
The specified list of servers contain one or more entries that cannot be resolved |
10027258 |
The specified cluster_name does not exist |
10027256 |
The specified cluster_uuid does not exist |
10027257 |
The specified cluster_name and cluster_uuid are valid but belong to different clusters |
10027248 |
Scanner-pool created successfully but failed to activate |
10027107 |
The list of privileged users or list of servers specified is empty |
10027108 |
The list of privileged users specified contains an invalid entry |
10027063 |
Attempting to modify a scanner-pool on an administrative SVM with a data SVM |
href |
string |
_links
cluster_reference
_links |
name |
string |
uuid |
string |
svm
name |
string |
The name of the SVM. |
uuid |
string |
vscan_scanner_pool
Scanner pool is a set of attributes which are used to validate and manage connections between clustered ONTAP and external virus-scanning server, or "Vscan server".
cluster |
name |
string |
privileged_users |
array[string] |
role |
string |
servers |
array[string] |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
