REST API reference
Create the Vscan scanner-pool configuration for an SVM
Configures a Vscan scanner-pool for a specified SVM, setting up the necessary servers and privileged users for virus scanning operations. Use this endpoint to establish a scanner-pool with either complete or mandatory properties depending on your environment's requirements.
HTTP method and endpoint
POST /protocols/vscan/{svm.uuid}/scanner-pools
Introduced in
ONTAP 9.6
Usage notes
Creates a Vscan scanner-pool configuration for a specified SVM. You can create a scanner-pool with all fields specified or only mandatory fields specified.
Important notes:
  • A scanner-pool must have servers and privileged users specified.
  • If the role or cluster is not specified, the scanner-pool is created on the local cluster with the role set as primary. *`Only one of the fields cluster-uuid or cluster-name is required.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the Vscan configuration.
  • name - Scanner-pool name.
  • privileged_users - List of privileged users.
  • servers - List of server IP addresses or FQDNs.
  • role - Setting a role for a scanner-pool is recommended.
  • cluster - Passing the cluster name or UUID (or both) in a multi-cluster environment is recommended.
Default property values
If not specified in POST, the following default property values are assigned:
  • role - primary
  • cluster.name - Local cluster name.
  • cluster.uuid - Local cluster UUID.
  • vserver vscan scanner-pool create
  • vserver vscan scanner-pool apply-policy
  • vserver vscan scanner-pool privileged-users add
  • vserver vscan scanner-pool servers add
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
cluster
cluster_reference
name
string
Specifies the name of the scanner pool. Scanner pool name can be up to 256 characters long and is a string that can only contain any combination of ASCII-range alphanumeric characters a-z, A-Z, 0-9), "_", "-" and ".".
privileged_users
array[string]
Specifies a list of privileged users. A valid form of privileged user-name is "domain-name\user-name". Privileged user-names are stored and treated as case-insensitive strings. Virus scanners must use one of the registered privileged users for connecting to clustered Data ONTAP for exchanging virus-scanning protocol messages and to access file for scanning, remedying and quarantining operations.
  • example: ["cifs\u1", "cifs\u2"]
  • Introduced in: 9.6
role
string
Specifies the role of the scanner pool. The possible values are:
  • primary - Always active.
  • secondary - Active only when none of the primary external virus-scanning servers are connected.
  • idle - Always inactive.
servers
array[string]
Specifies a list of IP addresses or FQDN for each Vscan server host names which are allowed to connect to clustered ONTAP.
  • example: ["1.1.1.1", "10.72.204.27", "vmwin204-27.fsct.nb"]
svm
svm
Example request
  "cluster": {
    "name": "cluster1",
  "name": "scanner-1",
  "privileged_users": [
    "cifs\\u1",
    "cifs\\u2"
  "role": "string",
  "servers": [
    "1.1.1.1",
    "10.72.204.27",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records
records
array[vscan_scanner_pool]
  "num_records": 1,
  "records": [
      "cluster": {
        "name": "cluster1",
        "cifs\\u1",
        "cifs\\u2"
      "role": "string",
      "servers": [
        "1.1.1.1",
        "10.72.204.27",
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
10027086
The specified list of servers contains one or more entries that cannot be resolved
10027258
The specified cluster_name does not exist
10027256
The specified cluster_uuid does not exist
10027257
The specified cluster_name and cluster_uuid are valid but belong to different clusters
10027248
Scanner-pool created successfully but failed to activate
10027107
The list of privileged users or list of servers specified is empty
10027108
The list of privileged users specified contains an invalid entry
10027063
Attempting to modify a scanner-pool on an SVM owned by the cluster with a data SVM
10027086
DNS resolution failed for one or more hostnames
10027119
The privileged user contains characters that are not allowed
string
cluster_reference
name
string
uuid
string
svm
name
string
uuid
string
vscan_scanner_pool
Scanner pool is a set of attributes which are used to validate and manage connections between clustered ONTAP and external virus-scanning server, or "Vscan server".
cluster
cluster_reference
name
string
privileged_users
array[string]
role
string
servers
array[string]
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
