Re-key the external key in the key hierarchy
Res-key the external key in the key hierarchy for an SVM with an AKV configuration. This can be useful when you need to update or change the encryption settings for security purposes.
HTTP method and endpoint
POST /security/azure-key-vaults/{azure_key_vault.uuid}/rekey-external
Introduced in
ONTAP 9.11
Usage notes
Rekeys the external key in the key hierarchy for an SVM with an AKV configuration.
Required properties
key_id- Key identifier of the new AKV key encryption key.
Related ONTAP commands
security key-manager external azure rekey-external
azure_key_vault.uuid |
string |
path |
True |
UUID of the existing AKV configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
key_id |
string |
Key identifier of the AKV key encryption key. |
svm |
Example request
"key_id": "https://keyvault1.vault.azure.net/keys/key1",
"svm": {
"name": "svm1",
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537120 |
Azure Key Vault is not configured for the given SVM. |
65537547 |
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation. |
href |
string |
_links
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
azure_key_vault_key
key_id |
string |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
