REST API reference
Re-key the external key in the key hierarchy
Rekeys the external key in the key hierarchy for an SVM with an AKV configuration, ensuring the security of your key management operations.
HTTP method and endpoint
POST /security/azure-key-vaults/{azure_key_vault.uuid}/rekey-external
Introduced in
ONTAP 9.11
Required properties
  • key_id - Key identifier of the new AKV key encryption key.
  • security key-manager external azure rekey-external
string
path
True
UUID of the existing AKV configuration.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
key_id
string
Key identifier of the AKV key encryption key.
Example request
  "key_id": "https://keyvault1.vault.azure.net/keys/key1/12345678901234567890123456789012"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
65537120
Azure Key Vault is not configured for the given SVM.
65537547
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation.
azure_key_vault_key
key_id
string
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
