Restore keys for an SVM
POST /security/azure-key-vaults/{azure_key_vault.uuid}/restore
Introduced In: 9.8
Restore the keys for an SVM from a configured AKV.
Related ONTAP commands
security key-manager external azure restore
azure_key_vault.uuid |
string |
path |
True |
UUID of the existing AKV configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537511 |
AKV is not configured for the given SVM. |
65537515 |
Failed to restore keys on some nodes in the cluster. |
| Name | Type | Description |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
