REST API reference
Create a collection of aggregates for an entire cluster
Automatically creates aggregates for an entire cluster based on an optimal layout recommended by the system. Alternatively, you can provide specific properties to customize the aggregate creation according to your requirements.
HTTP method and endpoint
POST /storage/aggregates
Introduced in
ONTAP 9.6
Usage notes
Automatically creates aggregates based on an optimal layout recommended by the system. Alternatively, properties can be provided to create an aggregate according to the requested specification. This request starts a job and returns a link to that job. POST operations will be blocked while one or more nodes in the cluster are simulating or implementing automatic aggregate creation.
Required properties
Properties are not required for this API. The following properties are only required if you want to specify properties for aggregate creation:
  • name - Name of the aggregate.
  • node.name or node.uuid - Node on which the aggregate will be created.
  • block_storage.primary.disk_count - Number of disks to be used to create the aggregate.
Default values
If not specified in POST, the following default values are assigned. The remaining unspecified properties will receive system dependent default values.
  • block_storage.mirror.enabled - false
  • snaplock_type - non_snaplock
  • storage aggregate auto-provision
  • storage aggregate create
Example:
POST /api/storage/aggregates {"node": {"name": "node1"}, "name": "test", "block_storage": {"primary": {"disk_count": "10"}}}
disk_size
integer
query
False
If set, POST only selects disks of the specified size.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
_links
_links
block_storage
block_storage
Configuration information for the locally attached portion of the aggregate. When a cloud store is also used by this aggregate, this is referred to as the performance tier.
cloud_storage
cloud_storage
Configuration information for the cloud storage portion of the aggregate. This is referred to as the capacity tier.
create_time
string
Timestamp of aggregate creation.
data_encryption
data_encryption
dr_home_node
dr_home_node
Node where the aggregate resides after disaster recovery. The value for this field might differ from the 'node' field during switchover.
home_node
home_node
Node where the aggregate resides after giveback. The value for this field might differ from the value of the 'node' field during takeover.
inactive_data_reporting
is_spare_low
boolean
Specifies whether the aggregate is in a spares low condition on any of the RAID groups. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
name
string
Aggregate name.
node
node
Node where the aggregate currently resides.
recommendation_spares
array[aggregate_spare]
Information on the aggregate's remaining hot spare disks.
sidl_enabled
boolean
Specifies whether or not SIDL is enabled on the aggregate.
snaplock_type
string
SnapLock type.
snapshot
snapshot
space
space
state
string
Operational state of the aggregate.
uuid
string
Aggregate UUID.
volume-count
integer
Number of volumes in the aggregate.
Example request
  "block_storage": {
    "hybrid_cache": {
      "disk_count": 6,
      "raid_type": "string",
      "size": 1612709888,
      "storage_pools": [
          "storage_pool": {
            "name": "storage_pool_1",
      "used": 26501122
    "mirror": {
      "enabled": "",
      "state": "string"
    "plexes": [
        "name": "plex0"
    "primary": {
      "checksum_style": "string",
      "disk_class": "performance",
      "disk_count": 8,
      "disk_type": "string",
      "raid_size": 16,
      "simulated_raid_groups": [
          "name": "string",
    "storage_type": "string"
  "cloud_storage": {
    "stores": [
        "cloud_store": {
          "name": "store1",
        "used": 0
  "create_time": "2018-01-01T12:00:00-04:00",
  "dr_home_node": {
    "name": "node1",
  "home_node": {
    "name": "node1",
  "inactive_data_reporting": {
    "enabled": null,
    "start_time": "2019-12-12T12:00:00-04:00"
  "is_spare_low": "",
  "name": "node1_aggr_1",
  "node": {
    "name": "node1",
  "recommendation_spares": [
      "disk_class": "solid_state",
      "is_partition": 1,
      "layout_requirements": [
          "aggregate_min_disks": 6,
          "raid_group": {
            "default": 16,
            "max": 28,
            "min": 5
      "node": {
        "name": "node1",
      "size": 10156769280,
      "syncmirror_pool": "string",
      "total": 10,
      "usable": 9
  "snaplock_type": "string",
  "snapshot": {
    "files_total": 10,
    "files_used": 3,
    "max_files_available": 5,
    "max_files_used": 50
  "space": {
    "block_storage": {
      "aggregate_metadata": 2655,
      "aggregate_metadata_percent": 8,
      "available": 10156560384,
      "data_compacted_count": 1990000,
      "data_compaction_space_saved": 1996000,
      "data_compaction_space_saved_percent": 27,
      "full_threshold_percent": 0,
      "inactive_user_data": 304448,
      "inactive_user_data_percent": 0,
      "physical_used": 2461696,
      "physical_used_percent": 50,
      "used": 2088960,
      "used_including_snapshot_reserve": 674685,
      "used_including_snapshot_reserve_percent": 35,
      "volume_deduplication_shared_count": 1990000,
      "volume_deduplication_space_saved": 1996000,
      "volume_deduplication_space_saved_percent": 27,
      "volume_footprints_percent": 14
    "cloud_storage": {
      "used": 402743264
    "efficiency": {
      "logical_used": 0,
      "ratio": 0,
      "savings": 0
    "efficiency_without_snapshots": {
      "logical_used": 0,
      "ratio": 0,
      "savings": 0
    "efficiency_without_snapshots_flexclones": {
      "logical_used": 0,
      "ratio": 0,
      "savings": 0
    "footprint": 608896,
    "snapshot": {
      "available": 2000,
      "reserve_percent": 20,
      "total": 5000,
      "used": 3000,
      "used_percent": 45
  "state": "string",
  "uuid": "string",
  "volume-count": 0
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
460770
The aggregate create job failed to create the aggregate.
786438
Failed to create an aggregate on the node.
786439
An aggregate already uses the specified name.
786446
The node is not in cluster.
786468
VLDB is offline.
786819
The value is invalid for the specified option at the current privilege level.
786902
RAID-TEC aggregate is not fully supported.
786911
Not every node in the cluster has the Data ONTAP version required for the feature.
787069
Node is setup for MetroCluster over IP configuration; creating an unmirrored aggregate is not supported in this configuration.
787092
The target field cannot be specified for this operation.
918138
Internal error. Failed to get encryption operation status.
1114292
The required SnapLock license is not installed.
2425736
No matching node found for the target UUID.
19726341
Not enough eligible spare disks are available on the node.
19726344
No recommendation can be made for this cluster.
19726357
Automatic aggregate creation is not supported on MetroCluster with Fibre Channel (FC).
19726358
Automatic aggregate creation is not supported on ONTAP Cloud.
19726373
Recommendation specified for creating aggregates is not current.
19726378
Failed to create recommended aggregates on one or more nodes.
19726382
Another provisioning operation is in progress on this cluster. Wait a few minutes, and try the operation again.
19726386
Encountered an error when retrieving licensing information on this cluster.
19726387
No recommendation can be provided for this cluster within the license capacity.
19726401
Aggregate recommendations are not supported when the DR group is not in the "normal" state.
19726402
Internal error. Unable to determine the MetroCluster configuration state.
19726403
Aggregate recommendation is not supported when there are no healthy target connections to remote storage.
196608055
Aggregate recommendation is not supported on this node because it does not support NetApp Aggregate Encryption (NAE).
196608206
string
storage_pool_reference
Shared Storage Pool
name
string
uuid
string
storage_pools
allocation_units_count
integer
Allocation count of storage pool.
storage_pool
Shared Storage Pool
hybrid_cache
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs.
disk_count
integer
Number of disks used in the cache tier of the aggregate. Only provided when hybrid_cache.enabled is 'true'.
enabled
boolean
Specifies whether the aggregate uses HDDs with SSDs as a cache.
raid_type
string
RAID type for SSD cache of the aggregate. Only provided when hybrid_cache.enabled is 'true'.
size
integer
Total usable space in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'.
storage_pools
array[storage_pools]
List of storage pool properties and allocation_units_count for aggregate.
used
integer
Space used in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'.
mirror
enabled
boolean
Aggregate is SyncMirror protected
state
string
plex_reference
Plex
name
string
added_data_disk_count
integer
Number of added data disks in RAID group.
added_parity_disk_count
integer
Number of added parity disks in RAID group.
data_disk_count
integer
Number of data disks in RAID group.
existing_data_disk_count
integer
Number of existing data disks in the RAID group.
existing_parity_disk_count
integer
Number of existing parity disks in the RAID group.
is_partition
boolean
Indicates whether the disk is partitioned (true) or whole (false).
name
string
Name of the raid group.
parity_disk_count
integer
Number of parity disks in RAID group.
raid_type
string
RAID type of the aggregate.
usable_size
integer
Usable size of each disk, in bytes.
primary
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details.
checksum_style
string
The checksum style used by the aggregate.
disk_class
string
The class of disks being used by the aggregate.
disk_count
integer
Number of disks used in the aggregate. This includes parity disks, but excludes disks in the hybrid cache.
disk_type
string
The type of disk being used by the aggregate.
raid_size
integer
Option to specify the maximum number of disks that can be included in a RAID group.
raid_type
string
array[simulated_raid_groups]
block_storage
hybrid_cache
hybrid_cache
mirror
mirror
plexes
array[plex_reference]
Plex reference for each plex in the aggregate.
primary
primary
storage_type
string
Type of aggregate.
uses_partitions
boolean
If true, aggregate is using shared disks.
cloud_store
Cloud store
_links
_links
name
string
uuid
string
cloud_storage_tier
cloud_store
cloud_store
Cloud store
used
integer
Capacity used in bytes in the cloud store by this aggregate. This is a cached value calculated every 5 minutes.
cloud_storage
attach_eligible
boolean
Specifies whether the aggregate is eligible for a cloud store to be attached.
stores
array[cloud_storage_tier]
Configuration information for each cloud storage portion of the aggregate.
tiering_fullness_threshold
integer
The percentage of space in the performance tier that must be used before data is tiered out to the cloud store. Only valid for PATCH operations.
data_encryption
drive_protection_enabled
boolean
Specifies whether the aggregate uses self-encrypting drives with data protection enabled.
software_encryption_enabled
boolean
Specifies whether NetApp aggregate encryption is enabled. All data in the aggregate is encrypted.
dr_home_node
name
string
uuid
string
home_node
_links
_links
name
string
uuid
string
start_time
string
Timestamp at which inactive data reporting was enabled on the aggregate.
inode_attributes
file_private_capacity
integer
Number of files that can currently be stored on disk for system metadata files. This number will dynamically increase as more system files are created. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
file_public_capacity
integer
Number of files that can currently be stored on disk for user-visible files. This number will dynamically increase as more user-visible files are created. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
files_private_used
integer
Number of system metadata files used. If the referenced file system is restricted or offline, a value of 0 is returned. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
files_total
integer
Maximum number of user-visible files that this referenced file system can currently hold. If the referenced file system is restricted or offline, a value of 0 is returned.
files_used
integer
Number of user-visible files used in the referenced file system. If the referenced file system is restricted or offline, a value of 0 is returned.
max_files_available
integer
The count of the maximum number of user-visible files currently allowable on the referenced file system.
max_files_possible
integer
The largest value to which the maxfiles-available parameter can be increased by reconfiguration, on the referenced file system.
max_files_used
integer
The number of user-visible files currently in use on the referenced file system.
used_percent
integer
The percentage of disk space currently in use based on user-visible file count on the referenced file system.
version
integer
The inofile-version of the aggregate. If the referenced file system is restricted or offline, a value of 0 is returned. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
other
integer
read
integer
total
integer
write
integer
metric
The most recent sample of I/O metrics for the aggregate.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
node
_links
_links
name
string
uuid
string
raid_group
default
integer
Default number of disks in a RAID group.
max
integer
Maximum number of disks allowed in a RAID group.
min
integer
Minimum number of disks allowed in a RAID group.
layout_requirement
aggregate_min_disks
integer
Minimum number of disks to create an aggregate.
default
boolean
Indicates if this RAID type is the default.
raid_group
raid_group
raid_type
string
RAID type.
node
Node where the spares are assigned.
_links
_links
name
string
uuid
string
aggregate_spare
checksum_style
string
The checksum type that has been assigned to the spares.
disk_class
string
Disk class of spares.
disk_type
string
Type of disk.
is_partition
boolean
Indicates whether a disk is partitioned (true) or whole (false)
layout_requirements
array[layout_requirement]
Available RAID protections and their restrictions.
node
node
size
integer
Usable size of each spare, in bytes.
syncmirror_pool
string
SyncMirror spare pool.
total
integer
Total number of spares in the bucket. The total spare count for each class of spares also includes reserved spare capacity recommended by ONTAP best practices.
  • example: 10
  • readOnly: 1
  • Introduced in: 9.11
usable
integer
Total number of usable spares in the bucket. The usable count for each class of spares does not include reserved spare capacity recommended by ONTAP best practices.
  • example: 9
  • readOnly: 1
  • Introduced in: 9.6
snapshot
files_total
integer
Total files allowed in Snapshot copies
files_used
integer
Total files created in Snapshot copies
max_files_available
integer
Maximum files available for Snapshot copies
max_files_used
integer
Files in use by Snapshot copies
block_storage
aggregate_metadata
integer
Space used by different metafiles and internal operations inside the aggregate, in bytes.
integer
Aggregate metadata as a percentage.
available
integer
Space available in bytes.
integer
Amount of compacted data in bytes.
integer
Space saved in bytes by compacting the data.
integer
Percentage saved by compacting the data.
integer
The aggregate used percentage at which 'monitor.volume.full' EMS is generated.
inactive_user_data
integer
The size that is physically used in the block storage and has a cold temperature, in bytes. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data or **.
integer
The percentage of inactive user data in the block storage. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data_percent or **.
physical_used
integer
Total physical used size of an aggregate in bytes.
integer
Physical used percentage.
size
integer
Total usable space in bytes, not including WAFL reserve and aggregate Snapshot copy reserve.
used
integer
Space used or reserved in bytes. Includes volume guarantees and aggregate metadata.
integer
Total used including the Snapshot copy reserve, in bytes.
integer
Total used including the Snapshot reserve as a percentage.
integer
Amount of shared bytes counted by storage efficiency.
integer
Amount of space saved in bytes by storage efficiency.
integer
Percentage of space saved by storage efficiency.
integer
A summation of volume footprints inside the aggregate, as a percentage. A volume's footprint is the amount of space being used for the volume in the aggregate.
cloud_storage
used
integer
Used space in bytes in the cloud store. Only applicable for aggregates with a cloud store tier.
efficiency
Storage efficiency.
logical_used
integer
Logical used
ratio
number
Data reduction ratio (logical_used / used)
savings
integer
Space saved by storage efficiencies (logical_used - used)
Storage efficiency that does not include the savings provided by Snapshot copies.
logical_used
integer
Logical used
ratio
number
savings
integer
Storage efficiency that does not include the savings provided by Snapshot copies and Flexclone volumes.
logical_used
integer
Logical used
ratio
number
savings
integer
snapshot
available
integer
Available space for Snapshot copies in bytes
reserve_percent
integer
Percentage of space reserved for Snapshot copies
total
integer
Total space for Snapshot copies in bytes
used
integer
Space used by Snapshot copies in bytes
used_percent
integer
Percentage of disk space used by Snapshot copies
space
block_storage
block_storage
cloud_storage
cloud_storage
efficiency
efficiency
Storage efficiency.
footprint
integer
A summation of volume footprints (including volume guarantees), in bytes. This includes all of the volume footprints in the block_storage tier and the cloud_storage tier. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
snapshot
snapshot
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
statistics
The real time I/O statistics for the aggregate.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
aggregate
_links
_links
block_storage
block_storage
cloud_storage
cloud_storage
create_time
string
data_encryption
data_encryption
dr_home_node
dr_home_node
home_node
home_node
is_spare_low
boolean
name
string
Aggregate name.
node
node
sidl_enabled
boolean
snaplock_type
string
SnapLock type.
snapshot
snapshot
space
space
state
string
uuid
string
Aggregate UUID.
volume-count
integer
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
