Create a collection of aggregates for an entire cluster
Automatically creates aggregates based on a recommended layout or lets you specify properties to tailor aggregate creation to your needs. This operation initiates a job and provides a link to monitor its progress.
HTTP method and endpoint
POST /storage/aggregates
Introduced in
ONTAP 9.6
Usage notes
Automatically creates aggregates based on an optimal layout recommended by the system. Alternatively, properties can be provided to create an aggregate according to the requested specification. This request starts a job and returns a link to that job. POST operations will be blocked while one or more nodes in the cluster are simulating or implementing automatic aggregate creation.
Required properties
Properties are not required for this API. The following properties are only required if you want to specify properties for aggregate creation:
name- Name of the aggregate. -
node.nameornode.uuid- Node on which the aggregate will be created. -
block_storage.primary.disk_count- Number of disks to be used to create the aggregate.
Default values
If not specified in POST, the following default values are assigned. The remaining unspecified properties will receive system dependent default values.
block_storage.mirror.enabled- false -
snaplock_type- non_snaplock
Related ONTAP commands
storage aggregate auto-provision -
storage aggregate create
Example:
POST /api/storage/aggregates {"node": {"name": "node1"}, "name": "test", "block_storage": {"primary": {"disk_count": "10"}}}
disk_size |
integer |
query |
False |
If set, POST only selects disks of the specified size. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
_tags |
array[string] |
Tags are an optional way to track the uses of a resource. Tag values must be formatted as key:value strings. |
block_storage |
Configuration information for the locally attached portion of the aggregate. When a cloud store is also used by this aggregate, this is referred to as the performance tier. |
create_time |
string |
Timestamp of aggregate creation. |
data_encryption |
home_node |
Node where the aggregate resides after giveback. The value for this field might differ from the value of the 'node' field during takeover. |
inactive_data_reporting |
inode_attributes |
is_spare_low |
boolean |
Specifies whether the aggregate is in a spares low condition on any of the RAID groups. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
name |
string |
Aggregate name. |
node |
Node where the aggregate currently resides. |
sidl_enabled |
boolean |
Specifies whether or not SIDL is enabled on the aggregate. |
snaplock_type |
string |
SnapLock type. |
snapshot |
space |
state |
string |
Operational state of the aggregate. |
uuid |
string |
Aggregate UUID. |
volume-count |
integer |
Number of volumes in the aggregate. |
Example request
"_tags": [
"team:csi",
"environment:test"
"block_storage": {
"hybrid_cache": {
"disk_count": 6,
"disk_type": "string",
"raid_size": 24,
"raid_type": "string",
"simulated_raid_groups": [
"name": "string"
"size": 1612709888,
"storage_pools": [
"storage_pool": {
"name": "storage_pool_1",
"used": 26501122
"mirror": {
"enabled": "",
"state": "string"
"plexes": [
"name": "plex0"
"primary": {
"checksum_style": "string",
"disk_class": "performance",
"disk_count": 8,
"raid_size": 16,
"name": "string",
"storage_type": "string"
"create_time": "2018-01-01 11:00:00 -0500",
"home_node": {
"name": "node1",
"inactive_data_reporting": {
"enabled": true,
"start_time": "2019-12-12 11:00:00 -0500"
"inode_attributes": {
"file_private_capacity": 31136,
"file_public_capacity": 31136,
"files_private_used": 502,
"files_total": 31136,
"files_used": 97,
"max_files_available": 31136,
"max_files_possible": 2844525,
"max_files_used": 97,
"used_percent": 5,
"version": 4
"is_spare_low": "",
"name": "node1_aggr_1",
"node": {
"name": "node1",
"snaplock_type": "string",
"snapshot": {
"files_total": 10,
"files_used": 3,
"max_files_available": 5,
"max_files_used": 50
"space": {
"block_storage": {
"aggregate_metadata": 2655,
"aggregate_metadata_percent": 8,
"available": 10156560384,
"data_compacted_count": 1990000,
"data_compaction_space_saved": 1996000,
"data_compaction_space_saved_percent": 27,
"full_threshold_percent": 0,
"inactive_user_data": 304448,
"inactive_user_data_percent": 0,
"physical_used": 2461696,
"physical_used_percent": 50,
"size": 10156769280,
"used": 2088960,
"used_including_snapshot_reserve": 674685,
"used_including_snapshot_reserve_percent": 35,
"used_percent": 50,
"volume_deduplication_shared_count": 1990000,
"volume_deduplication_space_saved": 1996000,
"volume_deduplication_space_saved_percent": 27,
"volume_footprints_percent": 14
"cloud_storage": {
"used": 402743264
"efficiency": {
"logical_used": 0,
"ratio": 0,
"savings": 0,
"wise_tsse_min_used_capacity_pct": 0
"efficiency_without_snapshots": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"efficiency_without_snapshots_flexclones": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"footprint": 608896,
"snapshot": {
"available": 2000,
"reserve_percent": 20,
"total": 5000,
"used": 3000,
"used_percent": 45
"state": "string",
"uuid": "string",
"volume-count": 0
Status: 202, Accepted
job |
num_records |
integer |
Number of records |
records |
array[aggregate] |
warnings |
array[aggregate_warning] |
List of validation warnings and remediation advice for the aggregate simulate behavior. |
"job": {
"uuid": "string"
"num_records": 1,
"records": [
"_tags": [
"team:csi",
"environment:test"
"block_storage": {
"hybrid_cache": {
"disk_count": 6,
"raid_size": 24,
"name": "string"
"size": 1612709888,
"storage_pools": [
"storage_pool": {
"used": 26501122
"mirror": {
"enabled": "",
"state": "string"
"plexes": [
"name": "plex0"
"primary": {
"disk_count": 8,
"raid_size": 16,
"name": "string",
"home_node": {
"name": "node1",
"enabled": true,
"files_used": 97,
"used_percent": 5,
"version": 4
"is_spare_low": "",
"node": {
"name": "node1",
"snapshot": {
"files_total": 10,
"files_used": 3,
"space": {
"block_storage": {
"used": 2088960,
"used_percent": 50,
"cloud_storage": {
"used": 402743264
"efficiency": {
"logical_used": 0,
"ratio": 0,
"savings": 0,
"logical_used": 0,
"ratio": 0,
"savings": 0
"logical_used": 0,
"ratio": 0,
"savings": 0
"snapshot": {
"available": 2000,
"total": 5000,
"used": 3000,
"used_percent": 45
"state": "string",
"uuid": "string",
"volume-count": 0
"warnings": [
"action": {
"arguments": [
"string"
"message": "string"
"name": "string",
"warning": {
"arguments": [
"string"
"message": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
460770 |
The aggregate create job failed to create the aggregate. |
786438 |
Failed to create an aggregate on the node. |
786439 |
An aggregate already uses the specified name. |
786446 |
The node is not in cluster. |
786468 |
VLDB is offline. |
786819 |
The value is invalid for the specified option at the current privilege level. |
786902 |
RAID-TEC aggregate is not fully supported. |
786911 |
Not every node in the cluster has the Data ONTAP version required for the feature. |
786973 |
The number of disks specified does not meet the minimum number of disks required for this operation. |
787069 |
Node is setup for MetroCluster over IP configuration; creating an unmirrored aggregate is not supported in this configuration. |
787092 |
The target field cannot be specified for this operation. |
787267 |
The number of disks specified does not meet the minimum number of disks required for the creation of a new RAID group. |
918138 |
Internal error. Failed to get encryption operation status. |
1114292 |
The required SnapLock license is not installed. |
2425736 |
No matching node found for the target UUID. |
19726341 |
Not enough eligible spare disks are available on the node. |
19726344 |
No recommendation can be made for this cluster. |
19726357 |
Automatic aggregate creation is not supported on MetroCluster with Fibre Channel (FC). |
19726358 |
Automatic aggregate creation is not supported on ONTAP Cloud. |
19726373 |
Recommendation specified for creating aggregates is not current. |
19726378 |
Failed to create recommended aggregates on one or more nodes. |
19726382 |
Another provisioning operation is in progress on this cluster. Wait a few minutes, and try the operation again. |
19726386 |
Encountered an error when retrieving licensing information on this cluster. |
19726387 |
No recommendation can be provided for this cluster within the license capacity. |
19726401 |
Aggregate recommendations are not supported when the DR group is not in the "normal" state. |
19726402 |
Internal error. Unable to determine the MetroCluster configuration state. |
19726403 |
Aggregate recommendation is not supported when there are no healthy target connections to remote storage. |
196608055 |
Aggregate recommendation is not supported on this node because it does not support NetApp Aggregate Encryption (NAE). |
196608206 |
href |
string |
_links
added_data_disk_count |
integer |
Number of added data disks in RAID group. |
added_parity_disk_count |
integer |
Number of added parity disks in RAID group. |
existing_data_disk_count |
integer |
Number of existing data disks in the RAID group. |
existing_parity_disk_count |
integer |
Number of existing parity disks in the RAID group. |
is_partition |
boolean |
Indicates whether the disk is partitioned (true) or whole (false). |
name |
string |
Name of the raid group. |
usable_size |
integer |
Usable size of each disk, in bytes. |
storage_pool_reference
Shared Storage Pool
name |
string |
uuid |
string |
storage_pools
allocation_units_count |
integer |
Allocation count of storage pool. |
storage_pool |
Shared Storage Pool |
hybrid_cache
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs.
disk_count |
integer |
Number of disks used in the cache tier of the aggregate. Only provided when hybrid_cache.enabled is 'true'. |
disk_type |
string |
Type of disk being used by the aggregate's cache tier. |
enabled |
boolean |
Specifies whether the aggregate uses HDDs with SSDs as a cache. |
raid_size |
integer |
Option to specify the maximum number of disks that can be included in a RAID group. |
raid_type |
string |
RAID type for SSD cache of the aggregate. Only provided when hybrid_cache.enabled is 'true'. |
simulated_raid_groups |
array[simulated_raid_groups] |
size |
integer |
Total usable space in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'. |
storage_pools |
array[storage_pools] |
List of storage pool properties and allocation_units_count for aggregate. |
used |
integer |
Space used in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'. |
mirror
enabled |
boolean |
Aggregate is SyncMirror protected |
state |
string |
plex_reference
Plex
name |
string |
integer |
integer |
data_disk_count |
integer |
Number of data disks in RAID group. |
integer |
integer |
is_partition |
boolean |
name |
string |
parity_disk_count |
integer |
Number of parity disks in RAID group. |
raid_type |
string |
RAID type of the aggregate. |
usable_size |
integer |
primary
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details.
checksum_style |
string |
The checksum style used by the aggregate. |
disk_class |
string |
The class of disks being used by the aggregate. |
disk_count |
integer |
Number of disks used in the aggregate. This includes parity disks, but excludes disks in the hybrid cache. |
disk_type |
string |
The type of disk being used by the aggregate. |
raid_size |
integer |
raid_type |
string |
block_storage
hybrid_cache |
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs. |
mirror |
plexes |
array[plex_reference] |
Plex reference for each plex in the aggregate. |
primary |
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details. |
storage_type |
string |
Type of aggregate. |
uses_partitions |
boolean |
If true, aggregate is using shared disks. |
cloud_store
Cloud store
name |
string |
uuid |
string |
cloud_storage_tier
cloud_store |
Cloud store |
used |
integer |
Capacity used in bytes in the cloud store by this aggregate. This is a cached value calculated every 5 minutes. |
cloud_storage
Configuration information for the cloud storage portion of the aggregate. This is referred to as the capacity tier.
attach_eligible |
boolean |
Specifies whether the aggregate is eligible for a cloud store to be attached. |
migrate_threshold |
integer |
Specifies the minimum percentage of performance tier free space that must exist in order for migration of data from the capacity tier to performance tier to be allowed. Only valid for PATCH operations. |
stores |
array[cloud_storage_tier] |
Configuration information for each cloud storage portion of the aggregate. |
tiering_fullness_threshold |
integer |
The percentage of space in the performance tier that must be used before data is tiered out to the cloud store. Only valid for PATCH operations. |
data_encryption
drive_protection_enabled |
boolean |
Specifies whether the aggregate uses self-encrypting drives with data protection enabled. |
software_encryption_enabled |
boolean |
Specifies whether NetApp aggregate encryption is enabled. All data in the aggregate is encrypted. |
dr_home_node
Node where the aggregate resides after disaster recovery. The value for this field might differ from the 'node' field during switchover.
name |
string |
uuid |
string |
home_node
name |
string |
uuid |
string |
start_time |
string |
Timestamp at which inactive data reporting was enabled on the aggregate. |
inode_attributes
file_private_capacity |
integer |
Number of files that can currently be stored on disk for system metadata files. This number will dynamically increase as more system files are created. This is an advanced property; there is an added computationl cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
file_public_capacity |
integer |
Number of files that can currently be stored on disk for user-visible files. This number will dynamically increase as more user-visible files are created. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
files_private_used |
integer |
Number of system metadata files used. If the referenced file system is restricted or offline, a value of 0 is returned. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
files_total |
integer |
Maximum number of user-visible files that this referenced file system can currently hold. If the referenced file system is restricted or offline, a value of 0 is returned. |
files_used |
integer |
Number of user-visible files used in the referenced file system. If the referenced file system is restricted or offline, a value of 0 is returned. |
max_files_available |
integer |
The count of the maximum number of user-visible files currently allowable on the referenced file system. |
max_files_possible |
integer |
The largest value to which the maxfiles-available parameter can be increased by reconfiguration, on the referenced file system. |
max_files_used |
integer |
The number of user-visible files currently in use on the referenced file system. |
used_percent |
integer |
The percentage of disk space currently in use based on user-visible file count on the referenced file system. |
version |
integer |
The inofile-version of the aggregate. If the referenced file system is restricted or offline, a value of 0 is returned. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
other |
integer |
read |
integer |
total |
integer |
write |
integer |
metric
The most recent sample of I/O metrics for the aggregate.
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
node
name |
string |
uuid |
string |
snapshot
files_total |
integer |
Total files allowed in Snapshot copies |
files_used |
integer |
Total files created in Snapshot copies |
integer |
Maximum files available for Snapshot copies |
max_files_used |
integer |
Files in use by Snapshot copies |
block_storage
aggregate_metadata |
integer |
Space used by different metafiles and internal operations inside the aggregate, in bytes. |
aggregate_metadata_percent |
integer |
Aggregate metadata as a percentage. |
available |
integer |
Space available in bytes. |
data_compacted_count |
integer |
Amount of compacted data in bytes. |
data_compaction_space_saved |
integer |
Space saved in bytes by compacting the data. |
data_compaction_space_saved_percent |
integer |
Percentage saved by compacting the data. |
full_threshold_percent |
integer |
The aggregate used percentage at which 'monitor.volume.full' EMS is generated. |
inactive_user_data |
integer |
The size that is physically used in the block storage and has a cold temperature, in bytes. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data or **. |
inactive_user_data_percent |
integer |
The percentage of inactive user data in the block storage. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data_percent or **. |
physical_used |
integer |
Total physical used size of an aggregate in bytes. |
physical_used_percent |
integer |
Physical used percentage. |
size |
integer |
Total usable space in bytes, not including WAFL reserve and aggregate Snapshot copy reserve. |
used |
integer |
Space used or reserved in bytes. Includes volume guarantees and aggregate metadata. |
used_including_snapshot_reserve |
integer |
Total used including the Snapshot copy reserve, in bytes. |
used_including_snapshot_reserve_percent |
integer |
Total used including the Snapshot reserve as a percentage. |
used_percent |
integer |
Aggregate used percentage. |
volume_deduplication_shared_count |
integer |
Amount of shared bytes counted by storage efficiency. |
volume_deduplication_space_saved |
integer |
Amount of space saved in bytes by storage efficiency. |
volume_deduplication_space_saved_percent |
integer |
Percentage of space saved by storage efficiency. |
volume_footprints_percent |
integer |
A summation of volume footprints inside the aggregate, as a percentage. A volume's footprint is the amount of space being used for the volume in the aggregate. |
cloud_storage
used |
integer |
Used space in bytes in the cloud store. Only applicable for aggregates with a cloud store tier. |
efficiency
Storage efficiency.
auto_adaptive_compression_savings |
boolean |
Indicates whether or not aggregate has auto adaptive compression savings. |
cross_volume_background_dedupe |
boolean |
Indicates whether or not cross volume background deduplication is enabled. |
cross_volume_dedupe_savings |
boolean |
Indicates whether or not aggregate has cross volume deduplication savings. |
cross_volume_inline_dedupe |
boolean |
Indicates whether or not cross volume inline deduplication is enabled. |
enable_workload_informed_tsse |
boolean |
Indicates whether Workload Informed TSSE is enabled on the system. |
logical_used |
integer |
Logical used |
ratio |
number |
Data reduction ratio (logical_used / used) |
savings |
integer |
Space saved by storage efficiencies (logical_used - used) |
wise_tsse_min_used_capacity_pct |
integer |
Minimum amount of used data in aggregate required to trigger cold compression on TSSE volumes. |
Storage efficiency that does not include the savings provided by Snapshot copies.
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
Storage efficiency that does not include the savings provided by Snapshot copies and Flexclone volumes.
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
snapshot
available |
integer |
Available space for Snapshot copies in bytes |
reserve_percent |
integer |
Percentage of space reserved for Snapshot copies |
total |
integer |
Total space for Snapshot copies in bytes |
used |
integer |
Space used by Snapshot copies in bytes |
used_percent |
integer |
Percentage of disk space used by Snapshot copies |
space
block_storage |
cloud_storage |
efficiency |
Storage efficiency. |
efficiency_without_snapshots |
Storage efficiency that does not include the savings provided by Snapshot copies. |
efficiency_without_snapshots_flexclones |
Storage efficiency that does not include the savings provided by Snapshot copies and Flexclone volumes. |
footprint |
integer |
A summation of volume footprints (including volume guarantees), in bytes. This includes all of the volume footprints in the block_storage tier and the cloud_storage tier. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
snapshot |
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
statistics
The real time I/O statistics for the aggregate.
iops_raw |
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
throughput_raw |
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
aggregate
_tags |
array[string] |
block_storage |
create_time |
string |
data_encryption |
home_node |
inode_attributes |
is_spare_low |
boolean |
name |
string |
Aggregate name. |
node |
sidl_enabled |
boolean |
snaplock_type |
string |
SnapLock type. |
snapshot |
space |
state |
string |
uuid |
string |
Aggregate UUID. |
volume-count |
integer |
job_link
uuid |
string |
action
arguments |
array[string] |
Arguments present in the specified action message. |
code |
integer |
Corrective action code of the specified action. |
message |
string |
Specifies the corrective action to be taken to resolve the issue. |
warning
arguments |
array[string] |
Arguments present in the warning message encountered. |
code |
integer |
Warning code of the warning encountered. |
message |
string |
Details of the warning encountered by the aggregate simulate query. |
aggregate_warning
action |
name |
string |
Name of the entity that returns the warning. |
warning |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
