REST API reference
Create a Snapshot copy policy
Creates a Snapshot copy policy to automate the creation and management of Snapshot copies according to a defined schedule and retention criteria. This helps in maintaining consistent data protection and recovery strategies for your storage volumes.
HTTP method and endpoint
POST /storage/snapshot-policies
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the Snapshot copy policy.
  • name - Name for the Snapshot copy policy.
  • copies.schedule - Schedule at which Snapshot copies are captured on the volume.
  • copies.count - Number of Snapshot copies to maintain for this schedule.
  • copies.prefix - Prefix to use when creating Snapshot copies at regular intervals.
Default property values
If not specified in POST, the following default property values are assigned:
  • enabled - true
  • copies.prefix - Value of schedule.name
  • snapshot policy create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
A comment associated with the Snapshot copy policy.
copies
array[copies]
enabled
boolean
Is the Snapshot copy policy enabled?
name
string
Name of the Snapshot copy policy.
scope
string
Set to "svm" when the request is on a data SVM, otherwise set to "cluster".
svm
svm
uuid
string
Example request
  "comment": "string",
  "copies": [
      "prefix": "string",
      "schedule": {
        "name": "hourly"
      "snapmirror_label": "string"
  "enabled": 1,
  "name": "default",
  "scope": "string",
  "svm": {
    "name": "svm1",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
1638407
When adding schedule to a Snapshot copy policy, the count for that schedule must be specified.
1638408
When adding schedule to a Snapshot copy policy, the schedule name must be specified.
1638413
Schedule not found.
1638417
Specified policy name is invalid.
1638451
This operation would result in total Snapshot copy count for the policy to exceed maximum supported count.
1638508
Another schedule has the same prefix within this policy.
1638526
This operation is not supported on a node Vserver.
1638527
Policy name already exists.
1638528
This operation is not supported in a mixed-version cluster.
1638531
This operation is not supported because specified policy is owned by the cluster admin.
string
schedule
name
string
Schedule at which Snapshot copies are captured on the volume. Some common schedules already defined in the system are hourly, daily, weekly, at 15 minute intervals, and at 5 minute intervals. Snapshot copy policies with custom schedules can be referenced.
copies
count
integer
The number of Snapshot copies to maintain for this schedule.
prefix
string
The prefix to use while creating Snapshot copies at regular intervals.
schedule
schedule
snapmirror_label
string
Label for SnapMirror operations
svm
name
string
The name of the SVM.
uuid
string
snapshot_policy
The Snapshot copy policy object is associated with a read-write volume used to create and delete Snapshot copies at regular intervals.
comment
string
copies
array[copies]
enabled
boolean
name
string
scope
string
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
