REST API reference
Create a Snapshot copy policy
Creates a Snapshot copy policy to define how and when Snapshot copies are taken on your storage volumes. Use this endpoint to specify the schedule, retention, and naming conventions for your Snapshot copies, tailoring them to your data protection needs.
HTTP method and endpoint
POST /storage/snapshot-policies
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - Specifies an SVM for policy creation. If not specified, the Snapshot policy will be created on the cluster admin SVM.
  • name - Name for the Snapshot copy policy.
  • copies.schedule - Schedule at which Snapshot copies are captured on the volume.
  • copies.count - Number of Snapshot copies to maintain for this schedule.
  • copies.prefix - Prefix to use when creating Snapshot copies at regular intervals.
  • copies.snapmirror_label - Label for SnapMirror operations.
  • copies.retention_period - Retention period for Snapshot copy locking enabled volumes.The duration must be specified in ISO format or "infinite".
Default property values
If not specified in POST, the following default property values are assigned:
  • svm.uuid or svm.name - If not specified, the Snapshot policy will be created on the cluster admin SVM.
  • enabled - true
  • copies.prefix - Value of schedule.name
  • snapshot policy create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
A comment associated with the Snapshot copy policy.
copies
array[copies]
enabled
boolean
Is the Snapshot copy policy enabled?
name
string
Name of the Snapshot copy policy.
scope
string
Set to "svm" when the request is on a data SVM, otherwise set to "cluster".
svm
svm
uuid
string
Example request
  "comment": "string",
  "copies": [
      "prefix": "string",
      "retention_period": "string",
      "schedule": {
        "name": "weekly",
      "snapmirror_label": "string"
  "enabled": 1,
  "name": "default",
  "scope": "string",
  "svm": {
    "name": "svm1",
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1638407
When adding schedule to a Snapshot copy policy, the count for that schedule must be specified.
1638408
When adding schedule to a Snapshot copy policy, the schedule name must be specified.
1638413
Schedule not found.
1638417
Specified policy name is invalid.
1638451
This operation would result in total Snapshot copy count for the policy to exceed maximum supported count.
1638506
Schedule already has a prefix. Cannot associate another prefix to the same schedule.
1638508
Another schedule has the same prefix within this policy.
1638526
This operation is not supported on a node Vserver.
1638527
Policy name already exists.
1638528
This operation is not supported in a mixed-version cluster.
1638531
This operation is not supported because specified policy is owned by the cluster admin.
2621706
The specified SVM UUID and SVM name refer to different SVMs.
918253
Incorrect format for the retention period, duration must be in the ISO-8601 format.
string
schedule
name
string
Job schedule name
uuid
string
Job schedule UUID
copies
count
integer
The number of Snapshot copies to maintain for this schedule.
prefix
string
The prefix to use while creating Snapshot copies at regular intervals.
retention_period
string
The retention period of Snapshot copies for this schedule. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The period string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported.
schedule
schedule
snapmirror_label
string
svm
name
string
uuid
string
snapshot_policy
The Snapshot copy policy object is associated with a read-write volume used to create and delete Snapshot copies at regular intervals.
comment
string
copies
array[copies]
enabled
boolean
name
string
scope
string
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
