Storage snapshot-policies snapshot_policy.uuid schedules endpoint overview
Overview
In ONTAP, scheduled Snapshot copy creation works based on the schedules associated with Snapshot copy policies. ONTAP provides six cluster-wide schedules: "5min", "8hour", "hourly", "daily", "weekly" and "monthly". A Snapshot copy policy is created using at least one of these schedules and up to 5 schedules can be associated with a Snapshot copy policy. A Snapshot copy policy can be linked to a storage object and based on the schedule in the policy, Snapshot copies are created on the object at that interval. Each schedule in a Snapshot copy policy has a Snapshot copy name prefix attached to it. Every Snapshot copy created using this policy has this prefix in its name. There is also a retention count associated with every schedule. This count indicates the maximum number of Snapshot copies that can exist for a given schedule. Once the Snapshot copy count reaches the retention count, on the next create operation, the oldest Snapshot copy is deleted. A schedule can be added, modified or deleted from a Snapshot copy policy.
Snapshot copy policy schedule APIs
The following APIs are used to perform operations related to Snapshot copy policy schedules:
– POST /api/storage/snapshot-policies/{snapshot_policy.uuid}/schedules/
– GET /api/storage/snapshot-policies/{snapshot_policy.uuid}/schedules/
– GET /api/storage/snapshot-policies/{snapshot_policy.uuid}/schedules/{schedule.uuid}
– PATCH /api/storage/snapshot-policies/{snapshot_policy.uuid}/schedules/{schedule.uuid}
– DELETE /api/storage/snapshot-policies/{snapshot_policy.uuid}/schedules/{schedule.uuid}
Adding schedule to a Snapshot copy policy
The POST operation is used to create a schedule for a Snapshot copy policy with the specified attributes.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/snapshot-policies/32a0841a-818e-11e9-b4f4-005056bbab9c/schedules" -H "accept: application/hal+json" -d '{"schedule.uuid": "7c985d80-818a-11e9-b4f4-005056bbab9c", "count": "5", "prefix": "new_hourly" }'
# The response:
HTTP/1.1 201 Created
Date: Wed, 29 May 2019 22:41:33 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Location: /api/storage/snapshot-policies/32a0841a-818e-11e9-b4f4-005056bbab9c/schedules
Content-Length: 271
Content-Type: application/json
"num_records": 1,
"records": [
"snapshot_policy": {
"uuid": "32a0841a-818e-11e9-b4f4-005056bbab9c"
"schedule": {
"uuid": "7c985d80-818a-11e9-b4f4-005056bbab9c"
"count": 5,
"prefix": "new_monthly"
Retrieving Snapshot copy policy schedules
The GET operation is used to retrieve Snapshot copy policy schedules.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/snapshot-policies/32a0841a-818e-11e9-b4f4-005056bbab9c/schedules" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Date: Wed, 29 May 2019 22:49:58 GMT
Content-Length: 898
"records": [
"schedule": {
"uuid": "63d017dc-818a-11e9-b4f4-005056bbab9c",
"name": "5min"
"schedule": {
"uuid": "64a5c5da-818a-11e9-b4f4-005056bbab9c",
"name": "8hour"
"schedule": {
"uuid": "63e21a3e-818a-11e9-b4f4-005056bbab9c",
"name": "daily"
"schedule": {
"uuid": "7c985d80-818a-11e9-b4f4-005056bbab9c",
"name": "monthly"
"num_records": 4
Retrieving the attributes of a specific Snapshot copy policy schedule
The GET operation is used to retrieve the attributes of a specific Snapshot copy policy schedule.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/snapshot-policies/32a0841a-818e-11e9-b4f4-005056bbab9c/schedules/7c985d80-818a-11e9-b4f4-005056bbab9c" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Date: Wed, 29 May 2019 22:54:06 GMT
Content-Length: 238
"schedule": {
"name": "monthly"
"count": 5,
"prefix": "new_monthly",
"snapmirror_label": "-"
Updating a Snapshot copy policy schedule
The PATCH operation is used to update the specific attributes of a Snapshot copy policy.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/snapshot-policies/32a0841a-818e-11e9-b4f4-005056bbab9c/schedules/7c985d80-818a-11e9-b4f4-005056bbab9c" -d '{"count": "10" }' -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Date: Wed, 29 May 2019 23:08:00 GMT
Content-Length: 3
Deleting a Snapshot copy policy
The DELETE operation is used to delete a Snapshot copy policy.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/storage/snapshot-policies/32a0841a-818e-11e9-b4f4-005056bbab9c/schedules/7c985d80-818a-11e9-b4f4-005056bbab9c" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Date: Wed, 29 May 2019 23:12:32 GMT
Content-Length: 3
