Manage snapshot policies and schedules
Manage snapshot policies and schedules to automate and customize the creation of snapshots in your ONTAP environment. Use these APIs to add, retrieve, update, and delete schedules associated with snapshot policies, ensuring efficient data protection and retention management.
Overview
In ONTAP, scheduled snapshot creation works based on the schedules associated with snapshot policies. ONTAP provides six cluster-wide schedules: "5min", "8hour", "hourly", "daily", "weekly" and "monthly". A snapshot policy is created using at least one of these schedules and up to 5 schedules can be associated with a snapshot policy. A snapshot policy can be linked to a storage object and based on the schedule in the policy, snapshots are created on the object at that interval. Each schedule in a snapshot policy has a snapshot name prefix attached to it. Every snapshot created using this policy has this prefix in its name. There is also a retention count associated with every schedule. This count indicates the maximum number of snapshots that can exist for a given schedule. Once the snapshot count reaches the retention count, on the next create operation, the oldest snapshot is deleted. A retention period can be associated with every schedule. During snapshot creation, this period is set as SnapLock expiry time on snapshot locking enabled volumes.
A schedule can be added, modified or deleted from a snapshot policy.
Snapshot policy schedule APIs
The following APIs are used to perform operations related to snapshot policy schedules:
– POST /api/storage/snapshot-policies/{snapshot_policy.uuid}/schedules/
– GET /api/storage/snapshot-policies/{snapshot_policy.uuid}/schedules/
– GET /api/storage/snapshot-policies/{snapshot_policy.uuid}/schedules/{schedule.uuid}
– PATCH /api/storage/snapshot-policies/{snapshot_policy.uuid}/schedules/{schedule.uuid}
– DELETE /api/storage/snapshot-policies/{snapshot_policy.uuid}/schedules/{schedule.uuid}
Adding schedule to a snapshot policy
The POST operation is used to create a schedule for a snapshot policy with the specified attributes.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/snapshot-policies/32a0841a-818e-11e9-b4f4-005056bbab9c/schedules" -H "accept: application/hal+json" -d '{"schedule.uuid": "7c985d80-818a-11e9-b4f4-005056bbab9c", "count": "5", "prefix": "new_hourly" }'
# The response:
HTTP/1.1 201 Created
Date: Wed, 29 May 2019 22:41:33 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Location: /api/storage/snapshot-policies/32a0841a-818e-11e9-b4f4-005056bbab9c/schedules
Content-Length: 271
Content-Type: application/json
"num_records": 1,
"records": [
"snapshot_policy": {
"uuid": "32a0841a-818e-11e9-b4f4-005056bbab9c"
"schedule": {
"uuid": "7c985d80-818a-11e9-b4f4-005056bbab9c"
"count": 5,
"prefix": "new_monthly"
Retrieving snapshot policy schedules
The GET operation is used to retrieve snapshot policy schedules.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/snapshot-policies/32a0841a-818e-11e9-b4f4-005056bbab9c/schedules" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Date: Wed, 29 May 2019 22:49:58 GMT
Content-Length: 898
"records": [
"schedule": {
"uuid": "63d017dc-818a-11e9-b4f4-005056bbab9c",
"name": "5min"
"schedule": {
"uuid": "64a5c5da-818a-11e9-b4f4-005056bbab9c",
"name": "8hour"
"schedule": {
"uuid": "63e21a3e-818a-11e9-b4f4-005056bbab9c",
"name": "daily"
"schedule": {
"uuid": "7c985d80-818a-11e9-b4f4-005056bbab9c",
"name": "monthly"
"num_records": 4
Retrieving the attributes of a specific snapshot policy schedule
The GET operation is used to retrieve the attributes of a specific snapshot policy schedule.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/snapshot-policies/32a0841a-818e-11e9-b4f4-005056bbab9c/schedules/7c985d80-818a-11e9-b4f4-005056bbab9c" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Date: Wed, 29 May 2019 22:54:06 GMT
Content-Length: 238
"schedule": {
"name": "monthly"
"count": 5,
"prefix": "new_monthly",
"snapmirror_label": "-",
"retention_period": "PT20M"
Updating a snapshot policy schedule
The PATCH operation is used to update the specific attributes of a snapshot policy.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/snapshot-policies/32a0841a-818e-11e9-b4f4-005056bbab9c/schedules/7c985d80-818a-11e9-b4f4-005056bbab9c" -d '{"count": "10" }' -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Date: Wed, 29 May 2019 23:08:00 GMT
Content-Length: 3
Deleting a snapshot policy
The DELETE operation is used to delete a snapshot policy.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/storage/snapshot-policies/32a0841a-818e-11e9-b4f4-005056bbab9c/schedules/7c985d80-818a-11e9-b4f4-005056bbab9c" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Date: Wed, 29 May 2019 23:12:32 GMT
Content-Length: 3
