REST API reference
View NetBIOS information
Access NetBIOS information endpoints to view details about NBT connections within your cluster. These endpoints help troubleshoot NetBIOS name resolution issues by displaying associated IP addresses, WINS server details, and registered NetBIOS names.
Displays information about NBT connections for the cluster. Displays the IP address associated with the interfaces, the IP addresses of the WINS servers in use, and information about the registered NetBIOS names for the cluster. You can use this command to troubleshoot NetBIOS name resolution problems.
Retrieving full CIFS NetBIOS information for all SVMs in the clsuter
# The API:
GET /api/protocols/cifs/netbios
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/netbios?return_timeout=15&fields=*&return_records=true" -H  "accept: application/json" -H  "authorization: Basic YWRtaW46bmV0YXBwMSE="
# The response:
"records": [
    "node": {
      "uuid": "c2179c2c-777f-11ec-95a1-1315568ef5fd",
      "name": "vsim2"
    "svm": {
      "name": "vs1",
      "uuid": "99a3bd71-777f-11ec-95a1-1315568ef5fd"
    "name": "CIFSERVER2",
    "interfaces": [
      "172.10.144.44"
    "wins_servers": [
        "ip": "10.10.10.10",
        "state": "inactive"
    "scope": "group",
    "mode": "h",
    "state": "broadcast",
    "time_left": 0,
    "name_registration_type": "",
    "suffix": "00"
    "node": {
      "name": "vsim2"
    "svm": {
      "name": "vs1",
    "interfaces": [
      "172.10.144.44"
    "wins_servers": [
        "state": "inactive"
    "scope": "",
    "mode": "h",
    "time_left": 0,
    "name_registration_type": "group",
    "suffix": "20"
"num_records": 2
Retrieving CIFS NetBIOS Information for a particular SVM
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/netbios?svm.uuid=45a3bd71-777f-11ec-95a1-1315568ef5fd&return_timeout=15&fields=*&return_records=true" -H  "accept: application/json" -H  "authorization: Basic YWRtaW46bmV0YXBwMSE="
# The response:
"records": [
    "node": {
      "name": "vsim2"
    "svm": {
      "name": "vs1",
      "uuid": "45a3bd71-777f-11ec-95a1-1315568ef5fd"
    "interfaces": [
      "172.10.144.44"
    "wins_servers": [
        "state": "inactive"
    "scope": "group",
    "mode": "h",
    "time_left": 0,
    "suffix": "00"
"num_records": 1
