View NetBIOS information
View detailed information about NetBIOS connections within your cluster using these endpoints. Examine interface IP addresses, WINS server details, and registered NetBIOS names to effectively troubleshoot name resolution issues.
Displays information about NBT connections for the cluster. Displays the IP address associated with the interfaces, the IP addresses of the WINS servers in use, and information about the registered NetBIOS names for the cluster. You can use this command to troubleshoot NetBIOS name resolution problems.
Retrieving full CIFS NetBIOS information for all SVMs in the clsuter
# The API:
GET /api/protocols/cifs/netbios
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/netbios?return_timeout=15&fields=*&return_records=true" -H "accept: application/json" -H "authorization: Basic YWRtaW46bmV0YXBwMSE="
# The response:
"records": [
"node": {
"uuid": "c2179c2c-777f-11ec-95a1-1315568ef5fd",
"name": "vsim2"
"svm": {
"name": "vs1",
"uuid": "99a3bd71-777f-11ec-95a1-1315568ef5fd"
"name": "CIFSERVER2",
"interfaces": [
"172.10.144.44"
"wins_servers": [
"ip": "10.10.10.10",
"state": "inactive"
"scope": "group",
"mode": "h",
"state": "broadcast",
"time_left": 0,
"name_registration_type": "",
"suffix": "00"
"node": {
"name": "vsim2"
"svm": {
"name": "vs1",
"interfaces": [
"172.10.144.44"
"wins_servers": [
"state": "inactive"
"scope": "",
"mode": "h",
"time_left": 0,
"name_registration_type": "group",
"suffix": "20"
"num_records": 2
Retrieving CIFS NetBIOS Information for a particular SVM
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/netbios?svm.uuid=45a3bd71-777f-11ec-95a1-1315568ef5fd&return_timeout=15&fields=*&return_records=true" -H "accept: application/json" -H "authorization: Basic YWRtaW46bmV0YXBwMSE="
# The response:
"records": [
"node": {
"name": "vsim2"
"svm": {
"name": "vs1",
"uuid": "45a3bd71-777f-11ec-95a1-1315568ef5fd"
"interfaces": [
"172.10.144.44"
"wins_servers": [
"state": "inactive"
"scope": "group",
"mode": "h",
"time_left": 0,
"suffix": "00"
"num_records": 1
