Create or retrieve event filters
Manage event filters by defining rules to identify and handle specific system events. These filters determine which events require further action and where they are sent. Utilize filters to customize event handling based on criteria such as name patterns, severity levels, and SNMP trap types.
Overview
Manages the list of available filters. A filter is a named collection of rules that enable the system to identify events that require additional handling. A filter is linked with a destination to which the system sends specific events.
When EMS processes an event, each filter is evaluated for a match. More than one filter can handle a single event.
The system defines default filters that cannot be removed or modified. These filters are specified by setting the "system_defined" field to "true". |
Filter rule position
A filter's rules are evaluated sequentially, according to their position index. When a rule is added or modified, the position can be set to customize the filter's logic. If no position is specified, a new rule is appended to the end of the list.
Filter rule types
A filter rule can be one of two types: 'include' or 'exclude'. If an event matches the criteria of the rule, the type dictates whether it should be forwarded to the destination or ignored.
Filter rule matching criteria
A valid filter rule must contain at least one set of criteria.
Name pattern
A name pattern is matched against an event's name. Multiple characters can be matched using the wildcard character '*'.
Severity
The severity pattern is matched against an event's severity. Multiple severities can be specified in a comma separated list. A single wildcard '*' will match all severities. Valid values are:
emergency
alert
error
notice
informational
debug
SNMP trap type
The SNMP trap type pattern is matched against an event's trap type. Multiple trap types can be specified in a comma separated list. A single wildcard '*' matches all trap types. Valid values are:
standard
built_in
severity_based
Retrieving a list of filters whose names contain a hyphen
# The API:
GET /api/support/ems/filters
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/filters?name=*-*" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"records": [
"name": "default-trap-events",
"href": "/api/support/ems/filters/default-trap-events"
"name": "important-events",
"href": "/api/support/ems/filters/important-events"
"name": "no-info-debug-events",
"href": "/api/support/ems/filters/no-info-debug-events"
"num_records": 3,
"href": "/api/support/ems/filters?name=*-*"
Creating a new filter using various matching criteria
# The API:
POST /api/support/ems/filters
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/filters" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filters_post.txt"
test_ems_filters_post.txt(body):
"name": "test-filter",
"rules": [
"index": 1,
"type": "include",
"message_criteria": {
"name_pattern": "LUN.*",
"severities": "alert,error",
"snmp_trap_types": "severity_based"
# The response:
201 Created
