REST API reference
Create or retrieve event filters
Manage event filters to determine how specific events are handled within the system. By creating or retrieving filters, you can customize event handling rules to ensure that important events are directed to the appropriate destinations for further action. Default filters are system-defined and cannot be altered.
Overview
Manages the list of available filters. A filter is a named collection of rules that enable the system to identify events that require additional handling. A filter is linked with a destination to which the system sends specific events.
When EMS processes an event, each filter is evaluated for a match. More than one filter can handle a single event.
Note The system defines default filters that cannot be removed or modified. These filters are specified by setting the "system_defined" field to "true".
Filter rule position
A filter's rules are evaluated sequentially, according to their position index. When a rule is added or modified, the position can be set to customize the filter's logic. If no position is specified, a new rule is appended to the end of the list.
Filter rule types
A filter rule can be one of two types: 'include' or 'exclude'. If an event matches the criteria of the rule, the type dictates whether it should be forwarded to the destination or ignored.
Filter rule matching criteria
A valid filter rule must contain at least one set of criteria.
Name pattern
A name pattern is matched against an event's name. Multiple characters can be matched using the wildcard character '*'.
Severity
The severity pattern is matched against an event's severity. Multiple severities can be specified in a comma separated list. A single wildcard * will match all severities. When multiple severities are provided in a rule, all must match for the rule to be considered matched. A pattern can include one or more wildcard * characters. Valid values are:
  • emergency
  • alert
  • error
  • notice
  • informational
  • debug
SNMP trap type
The SNMP trap type pattern is matched against an event's trap type. Multiple trap types can be specified in a comma separated list. A single wildcard * matches all trap types. When multiple trap types are provided in a rule, all must match for the rule to be considered matched. A pattern can include one or more wildcard * characters. Valid values are:
  • standard
  • built_in
  • severity_based
Parameter criteria
A parameter criterion is matched against events' parameters. Each parameter consists of a name and a value. When multiple parameter criteria are provided in a rule, all must match for the rule to be considered matched. A pattern can include one or more wildcard '*' characters.
Retrieving a list of filters whose names contain a hyphen
# The API:
GET /api/support/ems/filters
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/filters?name=*-*" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"records": [
    "name": "default-trap-events",
        "href": "/api/support/ems/filters/default-trap-events"
    "name": "important-events",
        "href": "/api/support/ems/filters/important-events"
    "name": "no-info-debug-events",
        "href": "/api/support/ems/filters/no-info-debug-events"
"num_records": 3,
    "href": "/api/support/ems/filters?name=*-*"
Creating a new filter using various matching criteria
# The API:
POST /api/support/ems/filters
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/filters" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filters_post.txt"
test_ems_filters_post.txt(body):
"name": "test-filter",
"rules": [
    "index": 1,
    "type": "include",
    "message_criteria": {
      "name_pattern": "LUN.*",
      "severities": "alert,error",
      "snmp_trap_types": "severity_based"
    "parameter_criteria": [
        "name_pattern": "type",
        "value_pattern": "volume"
        "name_pattern": "vol",
        "value_pattern": "cloud*"
# The response:
201 Created
