REST API reference
Create or retrieve SNMP traphosts
Retrieve and configure SNMP traphosts to manage the reception of SNMP traps from your ONTAP system. Utilize these endpoints to ensure proper communication and monitoring between your cluster and designated host machines.
Overview
This SNMP endpoint is used to retrieve, configure and reconfigure SNMP traphosts. An SNMP traphost is a host machine that is configured to receive SNMP traps from ONTAP. An SNMP traphost can be an SNMPv1/SNMPv2c traphost or an SNMPv3 traphost. ONTAP sends SNMPv1/SNMPv2c traps to an SNMPv1/SNMPv2c traphost over the SNMPv1/SNMPv2c protocol. Similarly, it sends SNMPv3 traps to an SNMPv3 traphost over the SNMPv3 protocol.
Retrieves a list of SNMP traphosts in the cluster, sorted by IP address
# The API:
GET "/api/support/snmp/traphosts"
# The call:
curl -H "accept: application/hal+json" -X GET "https://<mgmt-ip>/api/support/snmp/traphosts?order_by=ip_address"
# The response:
"records": [
    "host": "scspr0651011001.gdl.englab.netapp.com",
    "ip_address": "10.235.36.62",
        "href": "/api/support/snmp/traphosts/scspr0651011001.gdl.englab.netapp.com"
    "host": "scspr0647726006.gdl.englab.netapp.com",
    "ip_address": "10.235.36.139",
        "href": "/api/support/snmp/traphosts/scspr0647726006.gdl.englab.netapp.com"
    "host": "scspr0651055012.gdl.englab.netapp.com",
    "ip_address": "10.237.245.106",
        "href": "/api/support/snmp/traphosts/scspr0651055012.gdl.englab.netapp.com"
"num_records": 3,
    "href": "/api/support/snmp/traphosts?order_by=ip_address"
Retrieves a list of SNMP traphosts in the cluster for which SNMP user is 'snmpv3user1'
# The call:
curl -H "accept: application/hal+json" -X GET "https://<mgmt-ip>/api/support/snmp/traphosts?name=snmpv3user1"
# The response:
"records": [
    "host": "scspr0653246020.gdl.englab.netapp.com",
    "user": {
      "name": "snmpv3user1",
          "href": "/api/support/snmp/users/800003150558b57e8dbd9ce9119d82005056a7b4e5/snmpv3user1"
        "href": "/api/support/snmp/traphosts/scspr0653246020.gdl.englab.netapp.com"
"num_records": 1,
    "href": "/api/support/snmp/traphosts?user.name=snmpv3user1"
Adds an SNMPv1 or SNMPv2c traphost
# The API:
POST "/api/support/snmp/traphosts"
# The call:
curl -H "accept: application/json" -H "Content-Type: application/json" -X POST "https://<mgmt-ip>/api/support/snmp/traphosts" -d '{"host":"10.140.128.48"}'
# The response:
201 Created
Adds an SNMPv3 traphost
# The API:
# The call:
curl -H "accept: application/json" -H "Content-Type: application/json" -X POST "https://<mgmt-ip>/api/support/snmp/traphosts" -d '{"host":"fd-geoycpi-uno.gycpi.b.yahoodns.net", "user":{"name":"snmpv3user1"}}'
# The response:
201 Created
