Create or retrieve SNMP traphosts
Configure and retrieve SNMP traphosts to manage how ONTAP sends SNMP traps to designated host machines. Use these endpoints to set up SNMPv1/SNMPv2c or SNMPv3 traphosts, ensuring proper communication over the respective protocols.
Overview
This SNMP endpoint is used to retrieve, configure and reconfigure SNMP traphosts. An SNMP traphost is a host machine that is configured to receive SNMP traps from ONTAP. An SNMP traphost can be an SNMPv1/SNMPv2c traphost or an SNMPv3 traphost. ONTAP sends SNMPv1/SNMPv2c traps to an SNMPv1/SNMPv2c traphost over the SNMPv1/SNMPv2c protocol. Similarly, it sends SNMPv3 traps to an SNMPv3 traphost over the SNMPv3 protocol.
Retrieves a list of SNMP traphosts in the cluster, sorted by IP address
# The API:
GET "/api/support/snmp/traphosts"
# The call:
curl -H "accept: application/hal+json" -X GET "https://<mgmt-ip>/api/support/snmp/traphosts?order_by=ip_address"
# The response:
"records": [
"host": "scspr0651011001.gdl.englab.netapp.com",
"ip_address": "10.235.36.62",
"href": "/api/support/snmp/traphosts/scspr0651011001.gdl.englab.netapp.com"
"host": "scspr0647726006.gdl.englab.netapp.com",
"ip_address": "10.235.36.139",
"href": "/api/support/snmp/traphosts/scspr0647726006.gdl.englab.netapp.com"
"host": "scspr0651055012.gdl.englab.netapp.com",
"ip_address": "10.237.245.106",
"href": "/api/support/snmp/traphosts/scspr0651055012.gdl.englab.netapp.com"
"num_records": 3,
"href": "/api/support/snmp/traphosts?order_by=ip_address"
Retrieves a list of SNMP traphosts in the cluster for which SNMP user is 'snmpv3user1'
# The call:
curl -H "accept: application/hal+json" -X GET "https://<mgmt-ip>/api/support/snmp/traphosts?name=snmpv3user1"
# The response:
"records": [
"host": "scspr0653246020.gdl.englab.netapp.com",
"user": {
"name": "snmpv3user1",
"href": "/api/support/snmp/users/800003150558b57e8dbd9ce9119d82005056a7b4e5/snmpv3user1"
"href": "/api/support/snmp/traphosts/scspr0653246020.gdl.englab.netapp.com"
"num_records": 1,
"href": "/api/support/snmp/traphosts?user.name=snmpv3user1"
Adds an SNMPv1 or SNMPv2c traphost
# The API:
POST "/api/support/snmp/traphosts"
# The call:
curl -H "accept: application/json" -H "Content-Type: application/json" -X POST "https://<mgmt-ip>/api/support/snmp/traphosts" -d '{"host":"10.140.128.48"}'
# The response:
201 Created
Adds an SNMPv3 traphost
# The API:
# The call:
curl -H "accept: application/json" -H "Content-Type: application/json" -X POST "https://<mgmt-ip>/api/support/snmp/traphosts" -d '{"host":"fd-geoycpi-uno.gycpi.b.yahoodns.net", "user":{"name":"snmpv3user1"}}'
# The response:
201 Created
