Delete an Active Directory account for an SVM
Deletes an Active Directory account for a specified Storage Virtual Machine (SVM) when you need to remove its association with that directory service.
HTTP method and endpoint
DELETE /protocols/active-directory/{svm.uuid}
Introduced in
ONTAP 9.12
Usage notes
Deletes the Active Directory account for a given SVM.
Related ONTAP commands
vserver active-directory delete
Important notes
Active Directory account deletion is asynchronous. Response contains Task UUID and Link that can be queried to get the status.
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
password |
string |
Administrator password required for Active Directory account creation. |
username |
string |
Administrator username required for Active Directory account creation. |
Example request
"password": "testpwd",
"username": "admin"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655414 |
Failed to remove Active Directory machine. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
active_directory_delete
password |
string |
username |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
