REST API reference
Delete an Active Directory account for an SVM
Deletes an Active Directory account for a specified SVM. Use this operation to remove an account when it is no longer needed or when reconfiguring Active Directory settings for the SVM.
HTTP method and endpoint
DELETE /protocols/active-directory/{svm.uuid}
Introduced in
ONTAP 9.12
Usage notes
Deletes the Active Directory account for a given SVM.
  • vserver active-directory delete
Important notes
  • Active Directory account deletion is asynchronous. Response contains Task UUID and Link that can be queried to get the status.
svm.uuid
string
path
True
Request Body
Name Type Description
password
string
Administrator password required for Active Directory account creation.
username
string
Administrator username required for Active Directory account creation.
Example request
  "password": "testpwd",
  "username": "admin"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655414
Failed to remove Active Directory machine.
655431
Username cannot be empty.
655432
Password cannot be empty.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
active_directory_delete
password
string
username
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
