REST API reference
Delete the Active Directory preferred DC configuration for an SVM and domain
Deletes the Active Directory preferred Domain Controller configuration for a specified SVM and domain. This is typically done when you need to remove a specific DC configuration from the system.
HTTP method and endpoint
DELETE /protocols/active-directory/{svm.uuid}/preferred-domain-controllers/{fqdn}/{server_ip}
Introduced in
ONTAP 9.12
Usage notes
Deletes the Active Directory preferred DC configuration of the specified SVM and domain.
  • vserver active-directory preferred-dc delete
fqdn
string
path
True
Fully Qualified Domain Name.
server_ip
string
path
True
DC's IP address.
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655507
Failed to remove preferred-dc.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
