Delete an Active Directory preferred DC configuration for an SVM and domain
DELETE /protocols/active-directory/{svm.uuid}/preferred-domain-controllers/{fqdn}/{server_ip}
Introduced In: 9.12
Deletes the Active Directory preferred DC configuration of the specified SVM and domain.
Related ONTAP commands
vserver active-directory preferred-dc delete
fqdn  |
string  |
path  |
True  |
Fully Qualified Domain Name.  |
server_ip  |
string  |
path  |
True  |
DC's IP address.  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655507  |
Failed to remove preferred-dc.  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
